Notices
Ebay gasket kits
Old 01-07-2018, 06:58 PM
Registered Member
Liked 22 Times in 14 Posts
Ebay gasket kits
Anyone ever use cheap kits like this?
Fit 00-03 Acura T C 3.2 MDX Honda 3.5 Head Gasket Set J32A1 J32A2 J35A3 J35A4 | eBay
Doing a low budget junkyard 3.5 build using only new rings to put CL-S pistons in the j35a3 block and new head gaskets.
I plan on using DNJ rings because the price is right, anyone have bad experience with these?
If anyone knows a good source for cheap head gaskets that work well let me know that would be great thanks.
613CLS is offline
Old 01-07-2018, 08:47 PM
Registered Member
mattcl-s's Avatar
Liked 36 Times in 35 Posts
Head gaskets dont normally cost a fortune hit up an auto store and get good gaskets i wouldnt cheap out in that area
mattcl-s is offline
Old 01-07-2018, 08:50 PM
Registered Member
thisaznboi88's Avatar
Liked 601 Times in 446 Posts
Check rock auto. Haven’t heard issues with dnj are you decking the heads
thisaznboi88 is offline
The following users liked this post: thisaznboi88
613CLS (01-08-2018)
Old 01-08-2018, 12:21 AM
Registered Member
Gonna just check the heads with a straight edge if they're within spec then no machining. Really trying to do it for cheap so far ive gotten the j32a2 basically free off a parts car i bought and made a few bucks off as well.
J32a3 i pulled bottom end from junkyard for 200$. Gonna plastigage the bearings hopefully its still tight enough.
Trying to get this thing in the car running for as cheap as possible. All the pennies add up.
Then ill have my original j32a2 out of the car to build another one if needed when i find another j35a3, its old enough to find lots in junkyard no problem. most of them there for tranny failures.
Poor mans sports car lol
613CLS is offline
Old 01-08-2018, 05:14 AM
Registered Member
Rock auto it is. Piston rings and complete engine gasket set for 200 shipped to Canada. What a fuckin deal
That might leave some money left over for cheap headers and a Zex kit
613CLS is offline
The following users liked this post: 613CLS
justnspace (01-08-2018)
Old 01-10-2018, 03:33 PM
I Wanna Beer
TheWeez's Avatar
Liked 72 Times in 59 Posts
Totally agree. Trying to save a couple dollars could end up needing a LOT of work to pull things and do the head gasket again (or worse). They're cheap for a quality one.
eBay gaskets are hit and miss. Not worth the risk.
TheWeez is offline
Old 09-30-2018, 02:19 PM
Registered Member
Liked 2 Times in 2 Posts
Did you end up using the dnj head gasket ??
AcuraMikey is offline
Old 10-01-2018, 08:54 PM
Registered Member
I went with felpro. No problems so far.
613CLS is offline
HeartTLs
01-21-2015 12:10 PM
shibalyeun
04-22-2012 02:16 PM
Neejay
02-07-2012 08:59 PM
deadlyklappy12887
04-26-2010 07:26 PM
jfkhan
08-06-2009 11:58 AM
Quick Reply: Ebay gasket kits
