AcuraZine - Acura Enthusiast Community (https://acurazine.com/forums/)
-   2G CL (2001-2003) (https://acurazine.com/forums/2g-cl-2001-2003-50/)
-   -   Ebay gasket kits (https://acurazine.com/forums/2g-cl-2001-2003-50/ebay-gasket-kits-965944/)
613CLS 01-07-2018 06:58 PM
Ebay gasket kits
Anyone ever use cheap kits like this?
Fit 00-03 Acura T C 3.2 MDX Honda 3.5 Head Gasket Set J32A1 J32A2 J35A3 J35A4 | eBay
Doing a low budget junkyard 3.5 build using only new rings to put CL-S pistons in the j35a3 block and new head gaskets.
I plan on using DNJ rings because the price is right, anyone have bad experience with these?
If anyone knows a good source for cheap head gaskets that work well let me know that would be great thanks.
mattcl-s 01-07-2018 08:47 PM
Head gaskets dont normally cost a fortune hit up an auto store and get good gaskets i wouldnt cheap out in that area
thisaznboi88 01-07-2018 08:50 PM
Check rock auto. Haven’t heard issues with dnj are you decking the heads
613CLS 01-08-2018 12:21 AM
Gonna just check the heads with a straight edge if they're within spec then no machining. Really trying to do it for cheap so far ive gotten the j32a2 basically free off a parts car i bought and made a few bucks off as well.
J32a3 i pulled bottom end from junkyard for 200$. Gonna plastigage the bearings hopefully its still tight enough.
Trying to get this thing in the car running for as cheap as possible. All the pennies add up.
Then ill have my original j32a2 out of the car to build another one if needed when i find another j35a3, its old enough to find lots in junkyard no problem. most of them there for tranny failures.
Poor mans sports car lol :beetroot:
613CLS 01-08-2018 05:14 AM
Rock auto it is. Piston rings and complete engine gasket set for 200 shipped to Canada. What a fuckin deal :electric:
That might leave some money left over for cheap headers and a Zex kit
TheWeez 01-10-2018 03:33 PM
Totally agree. Trying to save a couple dollars could end up needing a LOT of work to pull things and do the head gasket again (or worse). They're cheap for a quality one.
eBay gaskets are hit and miss. Not worth the risk.
AcuraMikey 09-30-2018 02:19 PM
Did you end up using the dnj head gasket ??
613CLS 10-01-2018 08:54 PM
I went with felpro. No problems so far.
