Notices
Drivers seat.......Wont recline!!!!!
Old 09-04-2006, 08:35 AM
Registered Member
TOPHER33884's Avatar
Exclamation Drivers seat.......Wont recline!!!!!
Guys,
I need some insight! I have a 01' CL-S, and my girlfreind put my drivers side seat up when she drove a few times, and it would stick, and then go back to normal position. now the damn thing is stuck in the upright position........and advice how to manually set this back till I can get it into the shop?
TOPHER33884 is offline
Old 09-04-2006, 10:02 AM
Registered Member
I had this happened to mine at least few times. I just kept moving the switch back and forth until it started to move backward. Does your seat recline forward? If so, you might want to take a chance and recline it a bit forward, and then try to recline it backwards. My switch got stuck once like that, but now its working fine.
It it does not help, get ready for the rape by the dealer.... its about $700....
russianDude is offline
Old 09-04-2006, 10:34 AM
East Coast Boost.!
if you get an ETM and a power tester, it wouldn't be that hard to figure out what the problem is. Could just be a fuse or the motor could be bad. Who knows. Goodluck
Titand19 is offline
Old 09-04-2006, 11:54 AM
Registered Member
From what I heard, we have one component that moves everything in a seat. So if something stops working, they have to replace the entire unit, which is very expensive.
Old 09-05-2006, 08:47 AM
Registered Member
McChicken's Avatar
I had the same issue a while back. What I did was lift the 'side handle' used to get into the back seat. Let the seat slide all the way forward. Then, with some extra force 'click' the seat-back into the upright position. After the seat slides back I was able to recline the seat again...
McChicken is offline
Old 09-05-2006, 09:07 AM
Registered Member
RaviNJCLs's Avatar
Mine does that too.
If I let it slide forward and then just push it back, it sometimes will not return to it's pre-set position. If I firmly, but not forcefully push the back of it til it clicks it works great. I don't have to let it go all the way forward. Just lift the handle, let the seat move forward a little and push it back til it clicks.
Hopefully this works.
RaviNJCLs is offline
Old 09-05-2006, 10:14 PM
Registered Member
Angry
i got a 01 CL type S, and my driver side seat isn't moving either! how matter what i do or try, still won't be able to fix it. suggestions anyone?
jzhu625 is offline
Old 09-05-2006, 10:22 PM
Moderator Alumnus
BigLizard's Avatar
hopefully your seats aren't stuck in the gangsta lean position
BigLizard is offline
Catfisha (08-21-2012)
Old 09-05-2006, 10:35 PM
Registered Member
OneFlyCL's Avatar
it happened to my passanger seat once...... so i juss took the seat cover off wacked it with a hammer a few time and it juss started working again. I know its not the best solution but it worked for me
good luck lol
OneFlyCL is offline
Old 09-05-2006, 10:36 PM
Moderator Alumnus
BigLizard's Avatar
good luck lol
Sweeeeeeeettt...
duck tape and hammers always work
Old 09-05-2006, 10:48 PM
Registered Member
MinimalFear's Avatar
Mine makes a clicking sound as it remains in one position. A quick trip to the dealer and a $450 estimate to fix! Motor reportedly was bad. That does not make sense as the motor works, but some metal bar is broke. I know as I removed the seatback and went on a search & destroy mission. Decided to do the scrapyard thing figuring another seat would be as easy as a dealer rip off, err...repair.
So far no luck finding a seat!
MinimalFear is offline
Old 09-06-2006, 11:15 AM
Registered Member
OneFlyCL's Avatar
yea that's excatly what happened to mine....a little click and it goes nowhere. Juss try maybe u'll get some luck with the hammer
OneFlyCL is offline
Old 09-06-2006, 12:34 PM
Registered Member
RaviNJCLs's Avatar
Read my first post and try that.
Old 09-11-2006, 03:05 PM
Registered Member
One Fly CL solved my problem. He was spot on with the solution. I unbolted the seat, listened for the click, zeroed in, removed the plastic cover.
I found the gear cluster that spins to rotate the seat back backward / forward and removed the three bolts that secure it to the seat frame.
Off the seat and tested- it workewd fine. So much for the bullshit Dealer assertion - it needed a new $450 motor.
One whack to the seat back frame, where it met a mate wheel - and the seat works as good as new!
Congrats for spot on CL advise!
DEALERS SUCK
or more accurately stated
TURNERSVILLE ACURA IN SOUTH JERSEY - - - S-U-C-K!
Tony Pace
Williamstown, NJ
Old 09-11-2006, 04:06 PM
Former Sponsor
rondog's Avatar
I had this happen a few times, at first I used to take apart the plastic to expose the gears, then I set a flat head screw driver on the gear, then hit it with a hammer while the switch is being mpressed, that got it out of the jam. But lately, i just get in and if wifey gets it all stuck again, I lean back on it real hard while pressing the switch, feels like it's gonna break, but then it lossens up and moves again, but you have to lean back HARD.
rondog is offline
Old 04-11-2012, 04:26 PM
Sprayallday
xclaudio24's Avatar
I just bought a new motor it is in the mail. I took the seat apart where am I looking for the jam? Does anyone have pics?
xclaudio24 is offline
Old 04-12-2012, 01:18 AM
New Member
mikeh001 is offline
Old 04-12-2012, 07:24 PM
Sprayallday
xclaudio24's Avatar
It is stuck in one spot it slides just won't recline
Old 04-12-2012, 08:08 PM
Love the VAG
civicdrivr's Avatar
Received 4,697 Likes on 2,866 Posts
Its the big gear that the motor connects to. Use a screwdriver to break it loose and then grease them.
civicdrivr is offline
Old 04-16-2012, 04:30 PM
Registered Member
I'm having this same problem does any 1 have pic of the cover and motor
Darnell Morris is offline
Old 07-31-2012, 01:58 PM
3.2 CL-S Sundance Gold
Like civicdrivr said...IT IS NOT THE MOTOR (IF YOU HEAR ANY NOISE WHEN YOU PRESS THE BUTTON. IT IS THE LARGE GEAR THAT IS STUCK. I TOO TOOK A SCREW DRIVER AND UNHINGED THE GEAR THEN LUBED IT. ITS NOT HARD TO DO AT ALL. ALL U NEED IS A SCREWDRIVER...EASY FIX
Gregory_20706 is offline
Old 08-19-2012, 09:31 PM
Registered Member
danielmar's Avatar
Seat stuck in my 03cl-s
Hey guys. I know, what a pain. I took the whole seat out turned it upside down on a table and started disassembling. Took the side plastic cover off and saw the big gear that was mentioned in previous posts. Actually there is 2 side by side. I found if I lube them between the two sandwiched gears together and the did the screwdriver on the gear teeth and the flat blade screwdriver between the gears and tapped with a hammer it finally would/did loosen up. bear in mind I did run power to the seat recline motor to test all this while the seat was on table. Also reversing polarity to motor help to facilitate movement/lube infusion.
Hope this helps.
Daniel
danielmar is offline
Old 08-20-2012, 05:39 PM
Registered Member
Good writeup. Trying this later this evening
14thandeuclid is offline
Old 12-27-2012, 08:34 PM
New Member
My passanger seat got stock it goes back an forward but the recline system won't move, I just heard a click. After I saw your coments i decieded to remove the side panel to check the motor, I had a apoiment next day with the mechanic to fix it so I just didn't wanna be ripped off. After I removed the side panel took off three screws that holds the motor then I released it and press the botton back and forward. It worked fine. Then I heard to hit the gear with a hammer, but I was afraid to damage the gear so idecided just to spray wd40 around the gear and put it back together.... Same day at night I was giving a ride to a friend of mine, and sundenly he was adjusting the position of the seat!!!! Nice just spraing wd40 around the gear works great.
Mauro2477end is offline
Old 01-28-2013, 06:59 PM
Rollin the SRT8 or my CLS
Mr3.2S's Avatar
Mine passenger went out too, goes forward and back, but wont recline. Thanks for the info!
Mr3.2S is offline
Old 07-06-2014, 07:16 PM
New Member
02 CL type S driver seat recliner
I followed the advice of several people who used the old hammer and screw driver technique to free up the gear for the driver seat recliner. Almost assumed that the motor was bad. I pulled the motor/gear assembly and pushed the button. It worked fine so I new the gear was stuck. Seat is working again now after a lot of lube and banging the gear while the button was depressed. Brilliant! There is a lubricant called break free with Teflon in it. I used some of that so hopefully, the gear will stay free.
02clsowner is offline
Old 07-06-2014, 08:13 PM
M90booosted
03-6/6's Avatar
both my seats didnt recline. just slammed them back and forth a few times and now they work perfect again.
03-6/6 is offline
Old 07-16-2014, 03:44 PM
Registered Member
All these threads out here are about reclining. What about if the seat reclines but WON'T slide backward or forward..tried forcing it no luck...No motor noise nothing happens at all...But the recline works
What then?
johndo18 is offline
Old 07-17-2014, 11:40 PM
Registered Member
That sounds like a dead slider motor. Does the seat move if you pull the lever on the side to flip it forward?
Acidicheartburn is offline
Old 07-18-2014, 01:35 AM
Registered Member
Does seat have to be taken out to break loose and grease?
NighthawkBlue is offline
Old 06-09-2018, 05:42 PM
New Member
Thank you so much! It was my passenger side, and it was driving me nuts when hubs was driving!!
Heather Spence is offline
Old 06-10-2018, 03:32 PM
Registered Member
Dang thats a lot of problems listed ITT. Come to think of it the seller of my car is basically the same height as me and I have never adjusted the driver seat, so I have no idea if it actually works. The passenger seat goes back automatically when incline it forward to use the back seat.
Flexing my musCL-S is offline
Old 06-12-2018, 11:05 PM
Registered Member
I MADE A VIDEO ABOUT THIS!!
AcuraMikey is offline
kamskeez (08-28-2018)
Old 06-12-2018, 11:34 PM
Registered Member
I MADE A VIDEO ABOUT THIS!!!
Old 06-12-2019, 08:09 PM
New Member
Hope this helps.
Daniel
This worked splendidly for me! I also applied a liberal amount of WD40. I only unbolted the seat and partially removed it. I left the wires connected to test it.
I also lubed the passenger side too while I was at it.
dond123 is offline
joflewbyu2
Fifth Generation TLX (2015+)
97
05-01-2019 05:38 PM
F-C
Motorsports News
33
08-22-2018 09:53 AM
xsilverhawkx
09-28-2015 06:51 PM
rhdune16
09-28-2015 11:31 AM
chiu0nthls
3G MDX Discussion (2014+)
09-28-2015 03:46 AM
Quick Reply: Drivers seat.......Wont recline!!!!!
