DEC6 manual transmission synchronizer options
Greetings, comrades. Quick question: has anyone here ever experimented with syncros for the 2003 CL/2004 and on TL 6-speed manual? My 3rd gear syncro doesn't seem to be feeling very good, so far my only option seems to be an original 23444PYZ326 sleeve set. Perhaps there's a cheaper way to go? Cuz the specified part costs crazy expensive with shipping to my country, which is a big letdown, as you can imagine... Maybe it can be substituted with a similar part from a different Honda/Acura model, like the TSX? We used to get the CL9 Honda Accord here, which is the same as your first gen Acura TSX, are any internal parts of the 6-speed gearbox for that car interchangeable with the Acura CL/TL? Maybe someone here demolished a manual trans like mine and is parting it out? If so, I'd gladly take a 3rd gear syncro and maybe a dog clutch off your hands. Thanks in advance!
Latent car nut
Received 2,005 Likes
You are way-WAY over thinking this issue; go buy three quarts of ACDelco Synchromesh Friction Modified and replace your transmission fluid; problem solved.
Latent car nut
Just make sure the Synchromesh you order is the "Friction Modified" variety; the other stuff is worthless in our transmissions. By the way, it is no longer called "GM Synchromesh", the product is now labeled "ACDelco Synchromesh".
Latent car nut
Nope, wrong stuff, it absolutely must say "Friction Modified" on the label.
InspireJ32A, If you can get that ACDelco 10-4014 transmission fluid over there, that would be a great first start and least expensive?
In addition, the attachment I provided below is the 'Service Bulletin 08-018' that addresses a '3rd gear issue' Acura found back in 2008.
It has the model lines where the issue was found and also provides alot of different part numbers associated with said models. Maybe that will help, as well.
Also, I noticed in one of your pictures on your 'Intake' thread that you don't have a 'shift boot' on your stick shift. The guys on the thread below do that sort of stuff and I believe they are HQ'd in Europe, so it will be less expensive to ship to the RF.
https://www.redlinegoods.com/CL0103shiftboot.php
InspireJ32A (02-24-2018)
https://www.acurapartswarehouse.com/...mainshaft.html - the part labeled as number "3" on the parts diagram
Latent car nut
But hondaworld.ru's cross-list shows that this is for a 08-11 Accord coupe. If I remember correctly, it's the same basic box?
Here it is for an '08 Accord 6 speed, #2 on the link below:
https://www.oemacuraparts.com/auto-p...nshaft-v6-scat
I'm thinking since it's listed on the TSB?
If you look at the top of the TSB it states that it applies to 3G:
2004-07 TL with M/T - ALL
Then, it looks like it even goes into the 4G TL with M/T within a certain VIN range.
I think you would be 'good to go' IF you had to buy new.
If the AC Delco fluid doesn't do me any good - I'm going for it.
Just got the car back from the shop, had some trouble with my shifting (sometimes the gears would just all refuse to go in). The shop said that the flywheel isn't in very good shape, but that doesn't affect clutch activation apparently, Had a faulty throw-out bearing replaced, poured in some AC Delco Syncromesh FM - third gear still goes in with a crunch...((( I have a feeling something in the gearbox fell off and is maybe causing these headaches (including vibration when starting from a stop). But I'm definitely gonna try and replace the 3rd gear set.
Hey man. I was just browsing Acurazine and found a post from a guy who took a TL trans apart after Syncromesh, and was complaining about increased wear and swollen seals. Thankfully, I've only been driving for a few weeks, and I've just got the upgraded 3rd gear set delivered, so I guess I'll be returning to Honda Original after I restore the transmission. Just got it to the shop for a 3rd gear set replacement and 2-mass to 1-mass flywheel conversion.
I was going to inquire as to what the status was in getting your new '3rd gear set'; however, I figured you would post about it when you were ready. Let us know how well it all turns out, preferably with pictures, lol.
I've been running the Syncromesh since Dec 2015 when I had my differential bearings/clutch/PP/FW replaced with no perceived issues as of yet. IMHO, I think it is really more of a personal preference thing. If possible, can you find the thread the guy is posting about 'swollen seals' and such? I'd like to see the discussion.
zeta (03-17-2018)
Ok, so here's my setup - SAAB 9-5 2.3T pressure plate (pretty much identical to the one provided in the XLR8 kit), Acura Legend disc (Aisin), and the 3rd gear set from the TSB. I'll be converting my stock flywheel to 1-mass (welding in together and balancing it out). I'll do a follow up as soon as everything's finished and functional.
zeta (03-17-2018)
