DEC6 manual transmission synchronizer options
Old 02-24-2018, 01:38 PM
InspireJ32A's Avatar
Greetings, comrades. Quick question: has anyone here ever experimented with syncros for the 2003 CL/2004 and on TL 6-speed manual? My 3rd gear syncro doesn't seem to be feeling very good, so far my only option seems to be an original 23444PYZ326 sleeve set. Perhaps there's a cheaper way to go? Cuz the specified part costs crazy expensive with shipping to my country, which is a big letdown, as you can imagine... Maybe it can be substituted with a similar part from a different Honda/Acura model, like the TSX? We used to get the CL9 Honda Accord here, which is the same as your first gen Acura TSX, are any internal parts of the 6-speed gearbox for that car interchangeable with the Acura CL/TL? Maybe someone here demolished a manual trans like mine and is parting it out? If so, I'd gladly take a 3rd gear syncro and maybe a dog clutch off your hands. Thanks in advance!
Old 02-24-2018, 02:07 PM
Latent car nut
horseshoez's Avatar
Received 2,005 Likes on 1,407 Posts
You are way-WAY over thinking this issue; go buy three quarts of ACDelco Synchromesh Friction Modified and replace your transmission fluid; problem solved.
Old 02-24-2018, 02:10 PM
Lone Wolf
brian6speed's Avatar
You can' replace a synchro, you have to replace whole gear.
Old 02-24-2018, 02:11 PM
I've looked into it, dude (I did a quick forum search), and found some info on the Synchromesh TF, the only problem is that nobody in my country keeps that stuff in stock...(((
Is the third gear interchangeable with any K-series Honda like the Accord/TSX?
Old 02-24-2018, 02:13 PM
Sorry, I was wrong, I actually found some. It's the GM Synchromesh that you have to order from the States.
Old 02-24-2018, 02:14 PM
Lone Wolf
I doubt it, 3rd Gen tl 3rd gear should work though.
Old 02-24-2018, 02:15 PM
Latent car nut
horseshoez's Avatar
Just make sure the Synchromesh you order is the "Friction Modified" variety; the other stuff is worthless in our transmissions. By the way, it is no longer called "GM Synchromesh", the product is now labeled "ACDelco Synchromesh".
Old 02-24-2018, 02:16 PM
My box is actually from a 3-gen TL
Old 02-24-2018, 02:17 PM
This is it, right? https://motoroil24.ru/catalog/type/p...d-offer-11305/
Old 02-24-2018, 02:18 PM
Latent car nut
horseshoez's Avatar
Nope, wrong stuff, it absolutely must say "Friction Modified" on the label.
Received 1,736 Likes on 1,392 Posts
InspireJ32A, If you can get that ACDelco 10-4014 transmission fluid over there, that would be a great first start and least expensive?
In addition, the attachment I provided below is the 'Service Bulletin 08-018' that addresses a '3rd gear issue' Acura found back in 2008.
It has the model lines where the issue was found and also provides alot of different part numbers associated with said models. Maybe that will help, as well.
Also, I noticed in one of your pictures on your 'Intake' thread that you don't have a 'shift boot' on your stick shift. The guys on the thread below do that sort of stuff and I believe they are HQ'd in Europe, so it will be less expensive to ship to the RF.
https://www.redlinegoods.com/CL0103shiftboot.php
File Type: pdf
InspireJ32A (02-24-2018)
Old 02-24-2018, 02:19 PM
teh CL's Avatar
I have a trans I'm picked up recently for parts. Not sure exactly what your looking for though.
Old 02-24-2018, 02:20 PM
It does say Friction Modified in fine print. I'm guessing this is it.
Old 02-24-2018, 02:22 PM
https://www.acurapartswarehouse.com/...mainshaft.html - the part labeled as number "3" on the parts diagram
Old 02-24-2018, 02:23 PM
It looks like I found some - https://motoroil24.ru/catalog/type/p...d-offer-11305/
Old 02-24-2018, 02:24 PM
Latent car nut
horseshoez's Avatar
Okay, I stand corrected, the label is slightly different than what we have over here but the part number is correct.
teh CL's Avatar
Ok, that works. The trans was already opened up when I bought it but I can make sure it's all there and let you know.
Old 02-24-2018, 02:25 PM
We do get Opels around here, I'm guessing that's what this fluid is for.
Thanks man!
Old 02-24-2018, 02:29 PM
That's actually an old photo, I've put in a boot since then (slightly modified one from a Prelude)
Old 02-24-2018, 02:36 PM
I'm thinking that that is the 'old' part number and will cross-over to the new one shown on the service bulletin 23444-RDE-315 if you have to buy new?
Old 02-24-2018, 02:40 PM
Well, it's much cheaper, this could actually do the trick.
zeta (02-24-2018)
Old 02-24-2018, 02:41 PM
But hondaworld.ru's cross-list shows that this is for a 08-11 Accord coupe. If I remember correctly, it's the same basic box?
Old 02-24-2018, 02:46 PM
I'm thinking since it's listed on the TSB?
Here it is for an '08 Accord 6 speed, #2 on the link below:
https://www.oemacuraparts.com/auto-p...nshaft-v6-scat
Old 02-24-2018, 02:49 PM
Well, I don't think the service bulletin can be wrong... I'll start with replacing the clutch master cylinder (it's a bit wonky, and the problems with the syncro literally got really bad today after the CMC started screwing with me) and trying the AC Delco transmission fluid, if that doesn't work - I guess a new sleeve set it is.
Old 02-24-2018, 02:55 PM
teh CL's Avatar
Wonder if the that would work with the older 6spds?
It's for the 08+ Accord & 07-08 TL-S which I'm sure was beefed up for the 3.5 motors.
Old 02-24-2018, 02:57 PM
I'm sure it will, if the SB cites it as a replacement part for the old TL/CL
Old 02-24-2018, 02:58 PM
If you look at the top of the TSB it states that it applies to 3G:
2004-07 TL with M/T - ALL
Then, it looks like it even goes into the 4G TL with M/T within a certain VIN range.
I think you would be 'good to go' IF you had to buy new.
Old 02-24-2018, 03:00 PM
If the AC Delco fluid doesn't do me any good - I'm going for it.
Old 02-24-2018, 03:07 PM
If you are referring to the '03 CLS6, then yes.
Old 02-24-2018, 03:08 PM
teh CL's Avatar
Learn something new ever day..
Old 03-01-2018, 02:49 PM
Just got the car back from the shop, had some trouble with my shifting (sometimes the gears would just all refuse to go in). The shop said that the flywheel isn't in very good shape, but that doesn't affect clutch activation apparently, Had a faulty throw-out bearing replaced, poured in some AC Delco Syncromesh FM - third gear still goes in with a crunch...((( I have a feeling something in the gearbox fell off and is maybe causing these headaches (including vibration when starting from a stop). But I'm definitely gonna try and replace the 3rd gear set.
Hey man, have you gotten around to looking through your parts bin for a 3rd gear set (assuming you're willing to sell it)?
Old 03-03-2018, 06:20 AM
teh CL's Avatar
I have it, just haven't had the time to confirm all the pieces are there. I'll shoot you a PM tomorrow.
Old 03-06-2018, 02:30 PM
johnboy1313's Avatar
My fourth gear syncho is grinding just the slightest bit. The above synchromesh made no difference whatsoever.
Old 03-17-2018, 03:36 PM
Hey man. I was just browsing Acurazine and found a post from a guy who took a TL trans apart after Syncromesh, and was complaining about increased wear and swollen seals. Thankfully, I've only been driving for a few weeks, and I've just got the upgraded 3rd gear set delivered, so I guess I'll be returning to Honda Original after I restore the transmission. Just got it to the shop for a 3rd gear set replacement and 2-mass to 1-mass flywheel conversion.
Old 03-17-2018, 04:07 PM
I've been running the Syncromesh since Dec 2015 when I had my differential bearings/clutch/PP/FW replaced with no perceived issues as of yet. IMHO, I think it is really more of a personal preference thing. If possible, can you find the thread the guy is posting about 'swollen seals' and such? I'd like to see the discussion.
I was going to inquire as to what the status was in getting your new '3rd gear set'; however, I figured you would post about it when you were ready. Let us know how well it all turns out, preferably with pictures, lol.
Old 03-17-2018, 04:14 PM
https://acurazine.com/forums/3g-tl-p...d-gear-881735/ - post number 8 from the top. As for photos - hang on, just a moment
zeta (03-17-2018)
Old 03-17-2018, 04:17 PM
Ok, so here's my setup - SAAB 9-5 2.3T pressure plate (pretty much identical to the one provided in the XLR8 kit), Acura Legend disc (Aisin), and the 3rd gear set from the TSB. I'll be converting my stock flywheel to 1-mass (welding in together and balancing it out). I'll do a follow up as soon as everything's finished and functional.
zeta (03-17-2018)
Quick Reply: DEC6 manual transmission synchronizer options
