Notices
Couple of mods for the near future
Old 04-18-2018, 05:44 PM
Registered Member
mattcl-s's Avatar
Ill be finally getting some decent weather here in MN i might be able to do some work on the car, couple of mods, and standard maintainence Over the next month or so i will be adding
polished lower manifold runners picked up at a junkyard for super cheap
Pnp throttle body
valve cover gasket
o ring for power steering pump...again!
and i have acura legend 2 piston calipers on order
here are a couple of pics of what i have going on so far
mattcl-s is offline
Old 04-18-2018, 05:54 PM
Registered Member
mattcl-s's Avatar
Also need to take headers off and paint them with a high heat coating
mattcl-s is offline
Old 04-18-2018, 06:19 PM
Registered Member
not to plug my listing, but I have listed some CL parts if you have money and want some nice performance parts.
good luck with your project
bkrupp is offline
Old 04-18-2018, 06:58 PM
Registered Member
mattcl-s's Avatar
no worries i will have a look in the BM
Thank you
mattcl-s is offline
Old 04-25-2018, 06:22 PM
Registered Member
mattcl-s's Avatar
Update i have finished earlier than expected. I only ran into a couple of problems which i was expecting broke 2 fuel injectors removing them from the lower runner and the TB that I polished had broken piece of plastic where it holds the throttle cable in its spot so i had to swap mine off of my car and onto the new one. I also went a head and did another polish with a rotary tool and a drum sanding bit in the IM only because the first time i did it i didnt do a very good job so i cleaned up my work a lil bit. So now the only thing inhave left to do is the legend brake caliper upgrade probably in the next couple of weeks but i was able to get the hard stuff out of the way for now, i will probably go back later this year and replace the last 3 injectors after taking everything apart this car is surprisingly easy to work on, so here are some pictures i tried to remember to take while doing this
Broken injector 1
Looks a little bit better
The TB installed
Cleaned the egr port
Put the back runner on while waiting for parts to come
Dirty
Most of everything reassembled
Fuck this bolt haha
Still not the best but better than before
mattcl-s is offline
Old 05-01-2018, 06:12 PM
Registered Member
Nice!
The broken piece on the TB may be the cruise control cable. Mine broke but instead of a new TB I used some wire to keep it captive. I worry about it but years have gone by.
Im getting ready to have headers and new exhaust installed, cai I’ll do and in the back of my mind have a Ron Jon body kit installed.
What do you know about a bushing kit or like an energy suspension kit? I would have a shop do it which will probably be expensive.
You planning on a turbo or SC?
Keep postin’ - I’m followin’
potter223 is offline
mattcl-s (05-03-2018)
Old 05-01-2018, 06:14 PM
Registered Member
f’n tablets
Registered Member
fín computers
Old 05-02-2018, 05:57 AM
Registered Member
Those injectors are always a PITA to get out without breaking. I broke a few when i did mine good thing i had a spare motor to pick from.
613CLS is offline
Old 05-03-2018, 05:40 PM
Registered Member
mattcl-s's Avatar
Originally Posted by potter223 View Post
Nice!
Im getting ready to have headers and new exhaust installed, cai Iíll do and in the back of my mind have a Ron Jon body kit installed.
Keep postiní - Iím followiní
i bbelieve it was the cruise cable too. Thats cool dude just make sure you use a HIGH heat paint( I like VHT paint)before you jnstall your headers i didnt do that when i did mine and have to take them back out again this will keep heat level down under the hood. And sorry i dont know anything about bushing kits my suspension is stock.
turbo? Nah engine has over 200xxx im just keeping it running and doing simple and subtle mods
I am going to do the legend brake caliper upgrade in the next couple of weeks that will be my next mod
mattcl-s is offline
Old 05-04-2018, 11:19 PM
Registered Member
I just searched that. Nice DIY. I had a 2dr 1990 legend 5sp before the CL. My dealer is having a timing belt job special (water pump, tensioner, etc) for like $1700. The car has over 220k miles and I did it once around 110k like 6 years ago. Think itís time to do it again? Iím trying to prioritize. The Ron Jon kit keeps falling to the bottom of the list.
I ordered some 2003 smoke headlights on the marketplace on here this week and am waiting for them to arrive.
Old 05-05-2018, 06:39 PM
M90booosted
03-6/6's Avatar
1700 and its a special? LOL. walk away.
good progress OP. i never have liked taking the LIM off. PITA.
03-6/6 is offline
Old 05-14-2018, 03:27 PM
Registered Member
mattcl-s's Avatar
Timing belt and water pump should run 1000$ at the absolute most parts and labor
thank you 03-6/6. Ill keep updating when i make some more progress
mattcl-s is offline
Old 11-22-2018, 12:43 PM
Registered Member
mattcl-s's Avatar
Im back! I took along break there doing these mods i said i was going to do well...I got around to doing the Legend caliper upgrade easy install and haven't had any issues yet
mattcl-s is offline
Old 03-07-2019, 04:32 PM
Registered Member
mattcl-s's Avatar
I got around to doing some more work on the CL during the winter months here a few photos from the progress
Tein street advance z coil overs
Rpf1 17x8.5 40mm
bfgoodrich sport comp g2 245/45/17
New valve cover gaskets and intake manifold plenum gasket set
I wasnt happy with the way i painted the valve covers the first time, so i removed all the paint and re did them with VHT wrinkle red it turned out much better. I also spray the intake manifold with VHT silver metalic but it turned out more blue....oh well it dont look bad. Now the snow needs to melt so i can take this thing for a rip its been way to long of a winter here
mattcl-s is offline
Old 03-10-2019, 07:08 PM
Registered Member
lateralus's Avatar
love the valve cover/intake mani paint job..
lateralus is online now
Old 03-10-2019, 07:52 PM
Registered Member
mattcl-s's Avatar
Thanks man!
mattcl-s is offline
Old 03-10-2019, 11:41 PM
Registered Member
lateralus's Avatar
did you bake the valve covers to help with the wrinkling affect ? i cant wait till its warmer so i can do mine... found another cls6 i'm slowly rehabbing..
Old 03-12-2019, 09:04 AM
Registered Member
mattcl-s's Avatar
you could do it that way but i just used a heat gun
mattcl-s is offline
lateralus (03-12-2019)
Old 03-12-2019, 10:15 PM
Registered Member
lateralus's Avatar
whenever you get a min could you get more shots of the valve cover/intake mani... i'm super digging that silver/blue ,,, I like the silver/blue and the offset black pieces..
Old 03-15-2019, 12:04 PM
Registered Member
mattcl-s's Avatar
I found out today that my wheel/tire set up is going to need some fender rolling those 245/45 tire is rubbing quite a bit since i lowered the car
mattcl-s is offline
Old 03-15-2019, 12:30 PM
Registered Member
mattcl-s's Avatar
mattcl-s is offline
lateralus (03-15-2019)
AbovePrime.
10-16-2007 10:42 AM
SilverCL225hp
Second Generation CL Discussion (2000-2003)
26
09-18-2002 10:57 PM
ebednarz
First Generation CL Discussion (1997-1999)
18
06-28-2002 08:37 AM
ebednarz
06-25-2002 12:48 AM
Quick Reply: Couple of mods for the near future
