Clock light bulb 2002 Acura TL
Old 10-04-2017, 09:03 AM
5th Gear
Myothercar's Avatar
Where can I get one?
Old 10-04-2017, 09:10 AM
Received 8,575 Likes on 6,626 Posts
Dealer or www.oemacuraparts.com or eBay or amazon
Old 10-08-2017, 08:51 AM
5th Gear
Myothercar's Avatar
Thank you for the info!
Follow up in case it helps anyone:
I was not able to find a clock bulb from any source for less than the dealer ($6).
I replaced a number bulbs in my dash switches--many bulbs can be changed by pushing the switches forward through the dash panel (you may not need to take the dash panel all the way out to access a bulb) but if you do not disconnect the switch you are working on, be sure to use a non-conductive screwdriver to twist the new bulb in.
There are tiny metal filaments that wrap around the base of these light bulbs. The metal blade of the screwdriver will contact the filaments and short your new bulb for you. There are proper tools for this, but I used a plastic knife from take-out food.
Old 10-24-2017, 01:25 PM
Squag27's Avatar
Does anyone have a part number for the oem bulb?
Old 10-24-2017, 02:02 PM
Received 1,732 Likes on 1,390 Posts
Look down in the 'tags' on this page.
Old 10-28-2017, 01:36 PM
5th Gear
Myothercar's Avatar
sure, the part number for the clock lightbulb is 35850-sz3-911. Current dealer price is $8.70.
be aware: other button style lightbulbs in the dash are different part numbers from the clock.
ImBroke (10-29-2017)
Old 10-29-2017, 04:55 PM
ImBroke's Avatar
Originally Posted by Myothercar
part number for the clock lightbulb is 35850-sz3-911. be aware: other button style lightbulbs in the dash are different part numbers from the clock.
Good information here. I put in a different dash bulb, and my clock is dimmer than the climate display. Going to the dealer to get the correct bulb tomorrow.
Old 10-29-2017, 05:20 PM
Make sure you get (#2) part # 35505-S0K-A01; SOCKET ASSY., BULB (T4.2) (9.5V 100MA), because according to the link below, that is the correct bulb for the clock (#20).
https://www.oemacuraparts.com/auto-p...at/switch-scat
Old 10-30-2017, 10:07 AM
ImBroke's Avatar
I saw that, but was wondering if that was just for the socket, and not the bulb.
Old 10-30-2017, 11:35 AM
Registered Nonmember
TheMightyQuinn's Avatar
I replaced my clock light. put everything back together and then a couple of other lights went out. I ended up replacing all dash lights with LEDs since it was cheaper than chasing down incandescent bulb failures repeatedly
Old 10-30-2017, 04:31 PM
The 35850-sz3-911 bulb the OP posted in her update response in post #6 is for the #26; SWITCH ASSY., AUTO CRUISE MAIN on the link below. I believe that bulbs color is GREEN.
https://www.oemacuraparts.com/auto-p...er=35850sz3911
rets
01-01-2013 09:50 PM
BuLtL00
03-20-2007 10:33 AM
DanMan1464
11-04-2004 04:02 PM
TL_Type_S
05-18-2001 02:45 AM
Quick Reply: Clock light bulb 2002 Acura TL
