car shuts off randomly
Old 08-07-2012, 11:10 PM
bang47's Avatar
hey while im driving at low speed and sometimes at 60 my car just turns off randomly, i just recently changed my air value control also, can anyone please help me!!!
Old 08-08-2012, 10:05 AM
Hot Ass!
Catfisha's Avatar
I assume it was a new IACV....maybe it's defective? Is your idle rough?
Old 08-08-2012, 10:11 AM
Hot Ass!
Catfisha's Avatar
What prompted you to change the valve in the first place?
Old 08-08-2012, 11:23 AM
lowrd on tein CS biatch
CL-S progression 01's Avatar
the iacv won't cause the car to shut off when driving. sounds like a fuel pump relay orr main relay??
these seem to be the 2 most common ways our cars fail to stay running.
Old 08-08-2012, 12:14 PM
6mt swapped..smart
AnthraciteTypeS's Avatar
The IAC could cause the car to shut off- mine has in the past. When you push the clutch in the rpms dip and just don't "catch" themselves and the car dies. It's only happened once or twice, but definitely possible
Old 08-08-2012, 12:17 PM
forgot to ask if it was auto or not i assumed auto
Old 08-08-2012, 12:45 PM
bang47's Avatar
It is auto. My car was idling rough. Has gotten better since I replace the air control. Thought it would slove the problem. And it hasn't. And its starting to piss me off lol
Old 08-08-2012, 01:26 PM
Lives in Boost
CL-Future's Avatar
Have you had any electrical work done recently? Car alarm, audio video, etc? It could be a short or like mentioned earlier a fuel/main relay problem.
Old 08-08-2012, 06:20 PM
bang47's Avatar
My alarm system was installed couple years back. I had stero system. But took out my speakers and just have the wires covered up
Old 08-08-2012, 08:16 PM
Whats up with RDX owners?
civicdrivr's Avatar
Received 8,142 Likes on 4,809 Posts
Check your grounds, specifically in the engine bay.
Old 08-08-2012, 08:54 PM
Lone Wolf
brian6speed's Avatar
On my manual when I had a vacuum leak, if I put the car in neutral the rpm's would drop to 0 and engine would shut off, but you have an auto.
Old 08-09-2012, 11:10 AM
bang47's Avatar
Thanks guys. Appreciate the help. Would def try all the suggestions
Old 08-17-2012, 05:47 AM
Sniffles's Avatar
check fuel pump. my gf cl-s shut off randomly too and it turned out to be the fuel pump. or the sensor. my old audi had that problem and i would either have to wait 5 min with my gas cap open or just open the gas cap lol
Old 08-19-2012, 04:58 PM
J-series addict
yungone501's Avatar
There's only one component on the J32 that electronically controls the idle speed and stability: IAC valve. That doesn't mean the idle couldnt be affected by any mechanically issues. Especially those that the IAC valve couldn't compensate for...like a large vacuum leak. I see J32's all the time in my shop most commonly for 2 reasons: misfires and idle problems.
I see many defective IAC valves especially when bought aftermarket. I've learned it's best to go with OEM. There's three circuits on the IAC. One will be a power (with engine running), the other a ground and last is the ECMs signal to actually control the valve. It's easy to test power and ground but the signal requires a bit more finesse when using a standard DVOM (voltmeter) and any scanner that has powertrain functionality control. If you're pulling any type of code that pertains to IAC circuit (in specific), then chances are your issue is not directly related to the IAC valves circuitry such as the harness and/or ECM. Although you could still have an electrical issue.
As I mentioned earlier, there many other mechanical issues that could be contributing to your issue. Vacuum leaks, air-distribution issue to IAC supply (clogged/dirty), throttle body valve (dirty/clogged), intake blockage (generally associated with low power), just to name a few.
Old 08-19-2012, 06:16 PM
civicdrivr's Avatar
^ The IACV wont cause the car to stall at speed. It only controls idle.
OP - Looking over this thread again, Im surprised it hasnt been asked yet. Any check engine lights?
Old 08-19-2012, 06:58 PM
J-series addict
yungone501's Avatar
I thought he had stated that when he pushed his clutch in it stalled but I now see that was someone else's response.
OP, no codes or MIL?
Old 08-20-2012, 05:40 PM
14thandeuclid's Avatar
Alternator could be shot? Maybe a bad ground.
Have you scanned for codes yet ?
Old 08-28-2012, 07:17 AM
o1s
o1s's Avatar
mine used to do this. it ended up being the main relay.
02-25-2020 09:57 AM
handsom-hustla
11-13-2015 05:04 PM
SpraykwoN
ILX
09-23-2015 11:44 AM
Stu2414
4G TL Problems & Fixes
08-30-2015 07:30 PM
Quick Reply: car shuts off randomly
