AV6 transmission swap questions
Greetings comrades! So I know that a J32A2 ECU will run an AV6 transmission ok, but are the transmission wiring harnesses the same? Here's my problem: when converting my car to manual, the automatic wiring connectors were severed. I couldn't find a J32A2 harness anywhere, the best I could do was a J30A4 harness. Does anybody know, will this work with my J32A2 ECU? I'm putting in an MRDA trans (which is basically an AV6 auto), so they should become good friends at least
Secreta Manny
03-02-2019 09:40 AM
