Anyone know physics or thermal dynamics?
I'm trying to figure out how much heat my exhaust produces. I'm not all that interested in exact temperatures, but more of the workings of it. Basically, will using a larger piping which obviously creates a larger chamber for exhausts, lower the exhaust temperature in general? Does this make sense? Also the larger the exhaust piping the more it flows creating less pressure. So will this also drop temperates? don't ask why i want to know, i just want to know. ;]
ridin slow'n'low
I'm not sure how it would work in an open exhaust system, but in a closed system such as a cylinder, increasing volume (such as by moving the piston out) will decrease the gas' temperature.
I would assume that in an open system such as an exhaust system, larger diameter would increase total volume, which in my opinion would only increase the time it takes for the exhaust piping to warm up, but once its fully warmed up, I don't think there will be a significant temperature difference.
Also, gases travel faster at higher temperatures. I don't see why you would want a cooler running exhaust. The advantage to using wider pipes is to fit more exhaust gases in it.
I'm a Vagiterian.
Yes. It will produce less temperatures. Think of it kinda like a radiator. The more surface area there is for wind/air to hit, the cooler the temperatures will be. Also, if you have your exhaust polished, it'll reduce heat as well. Let me know if you have any other questions.
<--- science and physics geek.
Blown is Best
Originally Posted by CleanCL
what about on hoses? my headers are already jet hot coated which i think is better than header wrap.
Increasing air flow under the hood would keep things cooler but too much will cause turbulence and additional air flow resistance for the car if not done properly. (increased drag coefficient.)
i have heard of people removing the rear seal above the firewall. this allows air to flow out the rear, but not causing drag because you are only creating an exit point to increase flow. i've heard this reduces underhood temperatures significantly with the only negative consequence that there is a increase in cabin noise. but my exhaust is so loud now, i dont think that matter.
thanks for the info allout. yea, im not big on the physics stuff :\ it's just that when i was working with the radiator, the hoses create a ton of heat, and as you all know they sit directly under the throttle body. granted the heat contained in the hoses would go thru the radiator, at this point that doesnt bother me bc my radiator is a monster. lol. i always thought there was a point to aftermarket radiator hoses such as www.samco.com and other places but maybe none of it is really what i think it is, but merely just creating a durable/strong/long lasting hose.
would wrapping the intake tubing in a reflective heat shielding reduce temperatures inside the intake?
Moderator Alumnus
I don't want to sound weird, but before I put on the custom cat back on the exhaust gases were not as hot as they are now. With opening up the exhaust system you're allowing the hot gases so to escape faster. The mid pipe is extremely hot after the engine has been running for a while, and even hotter if I'm keeping the RPMs up for a while; I can smell the steel burning off any dirt that was collected on the pipes.
I'm a Vagiterian.
I was thinking to wrap the hoses with the wrap. But wrapping with reflective wrap would keep the heat from heat-soaking the hoses. I'd also say adding a switch to your fans to keep them running more would help as well.
Moderator Alumnus
well what is your system exactly? i think my system is pretty wide open, it may be a bit much open, but i think it does the job for now. i feel like it's flowing a lot, but your post says the mid pipe is getting hotter than stock.
Moderator Alumnus
B A N N E D
Originally Posted by ljmushock
wow... im gonna sit this thread out, too much mumbo jumbo
Blown is Best
Originally Posted by GreenMachine
Don't you think that having the Mugen mods on his car helps the most? Why need another switch? I understand what you're talking about though, but it doesn't seem necessary.
Agreed - Mugen Mods work to keep coolant temps down. Turning the fans on even sooner would work to keep more air flow under the hood to purge heat.
Blown is Best
wrapping the intake tubing might help a bit. If you're using an icebox, most piping is plastic which is a pretty good insulator compared to a metal CAI tube. There's quite a bit of air flowing through the intake and I'm not sure how much energy can be transferred in the time it passes through the intake. You're sucking in 3.5 liters of air every two rotations of your crank.
For efficiency, a hood scoop would be the most direct CAI punched through the hood. It would be butt ugly but...
I'm a Vagiterian.
Well.... MntBkr had an Eclipse style bump in his hood, and that looked cool. So who knows
(And yes, I know the bump was for his direct port nitrous.)
proffesion...axle breaker
this is why alot of drifters do the JDM hood pop to the rear of hood, to let some of that rising heat escape through that gap....I did it to my current car. It makes sense to me, hot air rises, without a opening, its trapped and just builds.
as for the direct CAI, how bout a tube that bends down and goes out to the roadlamps/inserts, and take them out and have a horn/ velosity stack there.
i have the icebox which already tubes downward and has a funnel facing the road lamp area. and my front bumper flows nicely. i'm looking into ways of pushing more air to that area without hurting the radiator/condenser.
mrkingstonvi
02-22-2016 01:53 PM
AcuraKidd
09-25-2015 11:18 PM
09-17-2015 09:01 PM
