Aftermarket Radius Rod Bushings Poll - AcuraZine - Acura Enthusiast Community
Notices
View Poll Results: Performance Radius Rod Bushings Poll
Yes, I'd be all over this
60.00%
Maybe, depends on costs
40.00%
No, not interested
0%
Voters: 10. You may not vote on this poll
Old 07-30-2011, 10:46 AM
Lead Footed
RUF87's Avatar
Exclamation Aftermarket Radius Rod Bushings Poll
It's been about 1 1/2 years since we've visited the topic of having some performance radius rod bushings made for 2nd Gen TLs.
If you are interested in this mod please respond accordingly.
1) Yes, I'd be all over this
2) Maybe, depends on costs
3) No, not interested
Ruf
RUF87 is offline
The Following User Says Thank You to RUF87 For This Useful Post:
CLSspeedx (08-05-2011)
Old 07-30-2011, 11:52 AM
Registered Member
StreetKA's Avatar
i noticed that i have alot of wheel movement when i let my brother drive my car while he was leting clutch of the wheel started to move alot back and forth im not sure if that can be caused by mounts or only radious rod bushings
sounds like another 2 years of development
StreetKA is offline
Old 07-30-2011, 01:08 PM
Lone Wolf
brian6speed's Avatar
I would be interested. I have the moog improved design ones that I havn't installed yet so not sure if they are an improvement. They are alot stiffer than stock ones tho just by feel.
brian6speed is offline
Old 07-30-2011, 01:52 PM
put it in your mouth
civicdrivr's Avatar
Yesyesyesyesyesyesyesyesyesyesyesyesyesyesyes.....
All it would take is a mold and pouring some polyurethane. Theres nothing to the stock bushings, just a big chunk of rubber.
Moog makes radius rod bushings?
civicdrivr is offline
Old 07-30-2011, 05:42 PM
Lone Wolf
Yes, I bought mine from rockauto. They are called strut rod bushings. In the pic below the blue are the moog and the black one is stock. The stock one I can easily flex in my hand. The moog one I can't flex at all.
Old 07-30-2011, 06:12 PM
civicdrivr's Avatar
Interesting. I saw those on their site but their name for them threw me off. The Accord shares the same part, so the should fit. Good thing, Ive got a set of ES (I think) bushings off an Accord sitting in my garage
Old 07-30-2011, 08:21 PM
Registered Member
StreetKA's Avatar
Thanks Brian i will try that out too. To be honest im not sure where is this bushing placed but i will find it. It just sucks to work on my car because all the bolts are so rusted.
StreetKA is offline
Old 07-30-2011, 08:55 PM
Lone Wolf
You remove the black plastic piece under the engine bay and you will see them.
Old 07-30-2011, 10:21 PM
Registered Member
That Moog kit (#K9733) looks very interesting for $26.99 at RA.
If they are the same, when you get a chance, please post up the ES part # for further research.
BTW, has anyone actually ever replaced the radius rod bushings on the CL-S?
The manual states the following:
1. Raise the front of the vehicle, and make sure it is securely supported. Remove the front wheels.
2. Remove the clips and splash guard.
3. Remove the flange bolts to disconnect the radius rod from the LCA.
4. Remove the self-locking nut, washer, and front side bushing.
5. Remove the radius rod, collar, rear side bushing, washer, and shim.
6. Install new bushings in the reverse order of removal, and note the following items:
-Use a new self-locking nut on reassembly.
-Note the direction of installation for the front side bushing and the rear side bushing.
The reason I ask is because those flange bolts are a MFer to work with since space is tight in that area due to the axle. Making socket/wrench positioning difficult for removal/reinstall and final torque to 119lbf-ft.
I guess one could pop the lower ball joint for more flexability, however.
zeta is offline
Old 07-31-2011, 03:11 PM
wham bam thank you ma'am
Rajca's Avatar
i got the same ones that brian has. just need to install them. but if we can get stiffer ones. or solid ones like the had for the preludes a while back, id be down
Rajca is offline
Old 07-31-2011, 05:34 PM
Registered Member
StreetKA's Avatar
is it kit for both sides i guess ? am i right ?
StreetKA is offline
Old 07-31-2011, 06:21 PM
Registered Member
The tapered end of the larger one points to the front of the car and the tapered end of the small one points toward the rear, two for each side.
If your caster angle is out of normal limits the manual states to:
'Adjust the caster angle by increasing/decreasing the adjustment shims.
Note these items during adjustment:
-Do not use more than two adjusting shims.
-One adjusting shim changes the caster angle by 35` and the caster angle can be adjusted by 1 degree 10` maximum.
-One adjusting shim is 3.2mm (0.13in.) in thickness.'
zeta is offline
The Following User Says Thank You to zeta For This Useful Post:
Old 07-31-2011, 09:16 PM
civicdrivr's Avatar
Those flange bolts are a royal pain in the ass to remove. When I replace the RR bushings, Im going to replace my lower control arms too since those bushings have 140k on them, and hopefully it will make it easier to remove those bolts. I will be doing that probably within the next month or two.
The ES part number is 16.7103 but they are just the bushings, they dont include the sleeve or any washers. They were ~$20 for the set.
I got them here:
http://www.energysuspensionparts.com...prod=16%2E7103
Theyre pretty good, I ordered a few things from them.
The Following 2 Users Say Thank You to civicdrivr For This Useful Post:
CLSspeedx (08-02-2011), zeta (08-01-2011)
Old 08-01-2011, 12:54 PM
Registered Member
As stated by civicdrivr the (radius rod busings) OEM part numbers for the 02 Accord share the same part numbers for the 03 CL-S.
I got them here:
I just ordered a set of ES 16.7103's ($17.99) with a prelube tube (2.99) just in case. If my shit has not been blown away from a hurricane this time next week, I will try to get them installed ASAP. Will post here with any issues and details of the install.
In addition, ES has the Moog kit #K9733 on thier website supporting the 02 Accord Coupe as well for $35.94. I was going to get those but decided to opt for the ES since I was not at all impressed with Moog's inner/outer LCA bushings when I tried them.
zeta is offline
Old 08-01-2011, 04:34 PM
Lone Wolf
Someone buy the master bushing kit for the 2001 prelude sh and see what fits our car. If noone else does I might eventually do it.
Old 08-01-2011, 05:57 PM
Registered Member
You would have to start at the '96 master kit first since that is the last year for the radius rod set-up on the Prelude. The ES 16.7103 is applicable to that model year (96).
zeta is offline
Old 08-01-2011, 06:10 PM
civicdrivr's Avatar
Thats only the SH model that uses the horizontal bushing setup. The base model still used the conventional radius rod setup.
Old 08-01-2011, 06:31 PM
Lead Footed
RUF87's Avatar
Ah, my 98 Prelude still has a radius rod set up so I may just take one the front and compare them . . . as soon as the temps drop a little bit. It's about 110+ in the garage.
Just checked . . . the 98 Prelude and 2nd Gen CL/TL have the same part number . . .
Ruf
RUF87 is offline
Old 08-01-2011, 06:40 PM
Registered Member
Ruf
lol, Ops, the SH was the only model I checked. You guys are good.
zeta is offline
Old 08-01-2011, 07:15 PM
Registered Member
Ruf
98 base Prelude:
51381-SX0-013 011 002 BUSH, FR. RADIUS ROD (RR) (HOKUSHIN)
51391-SX0-013 012 002 BUSH, FR. RADIUS ROD (FR) (HOKUSHIN)
03 TL/CL:
51381-S84-A01 BUSH, FR. RADIUS ROD (RR)
51391-S84-A01 BUSH, RADIUS ROD (FR)
They share the first five digits; however, they appear to differ slightly in the parts diagrams.
After awhile, to me anyways, it seems like those numbers all blur together similarly.
zeta is offline
Registered Member
anthracitecl's Avatar
I'm down for this!!
My car did same thing before. My buddy told me that i have wheel movement back and forth. so i removed radius rod for checking. sure enough my bushings were bad. I replaced w/moog bushing kit. and kit doesn't come with locking nuts. I had to buy 2 new self-locking nuts. after that we checked if there's still movement. There wasn't movement. That's like 1.5year ago. maybe 2. I think it's time to check again.
anthracitecl is offline
The Following User Says Thank You to anthracitecl For This Useful Post:
zeta (08-01-2011)
Old 08-01-2011, 07:29 PM
Registered Member
There you go, that's great feedback! Now it's been confirmed that the Moogs are a viable alternative as well.
zeta is offline
Old 08-01-2011, 08:33 PM
Registered Member
Skatin's Avatar
Just ordered a set of Moog's today.
Skatin is offline
Old 08-01-2011, 10:38 PM
Lead Footed
RUF87's Avatar
Now that we know the bushings are the same for the CL/TL as certain model year Accords and Preludes maybe we'll find some more options.
Here's one that I found. It would be good to know how the Moog and these match up.
http://www.redlinemotive.com/store/r...tion=000783109
Ruf
RUF87 is offline
Old 08-01-2011, 10:43 PM
Lead Footed
RUF87's Avatar
Okay, I just caught this the Moog K9733 are strut mount bushings, but you guys say they are the same spec as the radius rod bushings?
Just want to make sure because if they are not the exactly the same I'm not going to mess with them.
Ruf
RUF87 is offline
Old 08-01-2011, 11:39 PM
civicdrivr's Avatar
MOOG calls the radius rod bushings the strut rod bushings. Its misleading.
Old 08-01-2011, 11:47 PM
Registered Member
Ruf
From what I can find on RockAuto and per brian6speed above, the Moog K9733 kit is for CL/TL 'radius rod' use. The confusion pertains to the symantics of the description, meaning 'strut rod' bushing kit.
For instance, Moog #K9492 is in regards to the upper front suspension 'strut mount kit' meaning 'shock/strut' mount rubber. see link below.
http://www.rockauto.com/catalog/moreinfo.php?pk=225530
zeta is offline
Old 08-02-2011, 02:01 AM
Lead Footed
RUF87's Avatar
And to add to the confusion . . . they show 2 steel rod inserts which would typically be for the lower strut. So with both the picture and the decription being goofy I'm not ready to buy off on it. Either they made mistakes on the description and picture or they are incorrect. Let's double check this as changing them out is a bit of a pain.
Ruf
RUF87 is offline
Old 08-02-2011, 10:03 AM
Registered Member
I just found my receipt for Moog bushing kit. It shows part# K9733. I paid $38.70
Old 08-02-2011, 10:12 AM
Senior Airman
slowcl-s's Avatar
They also have Prothane bushings available and are a little bit cheaper: http://www.energysuspensionparts.com...asp?prod=81202
Which are better Energy Bushings or Prothane?
slowcl-s is offline
Old 08-02-2011, 07:29 PM
'03 ABP YA4-S 6MT
http://www.amazon.com/Moog-K9733-Bus.../dp/B000C5A1HK
$29.84 including shipping from amazon
http://www.amazon.com/Energy-Suspens.../dp/B000CNAVL8
$21.03 (cheaper than other sites but need cart to be over $25 for free amazon shipping)
i think i'm going with the energy ones though.. and just reuse the collar and washers
rp_guy is offline
Old 08-04-2011, 05:26 PM
Registered Member
I just received my set of ES #16.7103 radius rod bushings today. They look exactly like the set depicted on the link below:
If the picture on ES' website had something next to them to show their scale, it would be apparent that these are in fact the correct size for radius rod applications.
In addition, holding these in my hands and comparing them to brian6speeds pictures above, the Moogs do, IMHO, appear to be the same size. I can barely get the 16.7103's to bend when trying to squeeze on them like in the photo above. I'm impressed and will try and get them installed ASAP.
zeta is offline
CLSspeedx (08-04-2011)
Old 08-04-2011, 05:56 PM
Registered Member
CLSspeedx's Avatar
Good to know thanks zeta! I'm going to work on my suspension after I get my car from the transmission shop. I'm planning on getting new radius rods and think I'll change out the bushings... Good luck getting them installed!
CLSspeedx is offline
Old 08-04-2011, 07:39 PM
Recently turned 18
Blitz's Avatar
Full write up with detailed pictures for those of us slightly mechanically challenged.
Blitz is offline
Old 08-04-2011, 09:14 PM
Registered Member
lol, refer to post #9. Those steps are straight from the manual. As mentioned in that post, step 3; removal of the flange bolts to disconnect the radius rod from the LCA will pose as the largest hurdle. If you are not familiar with this area by prior work exposure, it would be best to let a local shop perform the job. Depending on the types of tools available to the individual, it could be real easy or labor intensive because access to those bolts for wrenching is very tight.
zeta is offline
Old 08-04-2011, 09:48 PM
Registered Member
Skatin's Avatar
Dude you have a very hairy hand!!! Hahaha...
Skatin is offline
Old 08-04-2011, 10:09 PM
Registered Member
StreetKA's Avatar
are u a girl ?
StreetKA is offline
Old 08-05-2011, 01:57 AM
Lead Footed
RUF87's Avatar
It is definitely easier to do when the lower control arm is dropped. It's a real pita . . . I may check Harbor Freight and see if they have a extra long wrench. It was real easy when I had the axles out.
Ruf
RUF87 is offline
Old 08-05-2011, 05:12 PM
Registered Member
I installed these ES radius rod bushings today and it went very smooth. Took the car for a quick spin and it felt tighter/firmer. I did'nt go to crazy because the next step is to get an alignment to see if the caster is in the green. Logically, everything SHOULD be within normal limits with just the new bushing install; however, I have learned that my front suspension can be finicky when I go and mess with it.
The old stock bushings were SOFT, just like in brian6speeds photos above. They were not cracked/split or deteriorated, just contorted from being compressed/used for the last 125K or so. 80K of those 120K have been with the added weight of a S/C'er, so that has to be factored into the overall effect on the whole suspension geometry as well. They needed to be replaced.
I added to step #3 to indicate what I had to do to get the RR arm off the LCA, YMMV.
a. Detach the outer tie rod end.
b. Detach the endlink from the swaybar.
c. Detach the strut damper fork from the strut and LCA and set it aside.
d. Detach the lower balljoint, I used the socket handle between the LCA & Knuckle method.
e. Swing the knuckle assembly, supported by a jack, forward slightly. This will move the axle forward and away from the LCA area where the RR flange bolts reside.
f. I used a 19mm impact socket on a long 1/2" breaker bar while slightly pushing down on the LCA to loosen them. Once they are removed from the LCA, follow the remaining steps below.
4. Remove the self-locking nut (I replaced mine, torque to 40 lbf-ft), washer, and front side bushing.
When all suspension components have been reassembled, be sure to preload the suspension before torqueing all of their related fasteners.
Good Luck!
zeta is offline
The Following 2 Users Say Thank You to zeta For This Useful Post:
Neejay (11-09-2011), ProfessorFunk (12-26-2018)
Old 08-05-2011, 05:58 PM
Lone Wolf
wtf, are you a girl or a 10 year old boy who hasnt hit puberty yet.
Quick Reply: Aftermarket Radius Rod Bushings Poll
