AC Problem
Well, there's a leak somewhere. it's a pressure system. If it's low on freon , then it's leaking out. Likely a O ring from somewhere. You'll have to get it leak tested. There's a Dye that's added & will leak out from wherever the leak is & should be easy to spot.
from there fix the leak & recharge.
SidhuSaaB
05-30-2020 12:40 AM
Fool
03-10-2016 08:42 PM
