6speed CL-S and 6speed AV6
4drs just wanna have fun!
Originally Posted by Allout
Might be a difference in the crank triggers on the flywheel. I know there was a difference between the one used on the CL-S6MT and the 3rd gen TL.
Unregistered Member
Originally Posted by Accord_V6_400m
??? Do you have a four cylinder engine or did you somehow adapt its 5spd to our J32's
Originally Posted by manafourme
No I have a 03 CL-S 6speed. I was searching on ACT's website and found that they made street and racing clutches and a lighten flywheel for the AV6 6speed trans. So I'm wondering if the clutch and flywheel will work on the CL-S 6speed trans.
Unregistered Member
The little boxes on the side that say year,make,model,and engine. Click on 2002 for the year. Then Honda for the make. Choose Accord EX as the model. And last choose engine click on V6 3.0 N FI (J30AI) the page will come up.
you will still need the CLS flywheel or one designed for it and im not sure if the av6 trans has the sensor location?
The only flywheels that will work I know of are the oem/oem replacement or the aasco. I would think the question to ask would be if other clutches will work with our flywheels?
Can you buy a clutch for a 3rd gen tl, or v6 accord and use our oem flywheel or aasco with it?
Whats up with RDX owners?
A 7th gen Accord V6 tranny will bolt up, but it doesnt have the crank sensor hole or an LSD. The gearing is identical. You will need to modify the shift change levers (one of the cables mount on the opposite side vs the CL-S6 and the front torque dampener bolt holes are not drilled/tapped but the mounting bosses are there.
RSpyder
09-30-2015 12:46 AM
STL TL-S
09-23-2015 08:52 PM
Skirmich
09-15-2015 06:41 PM
