2nd gear replacement
Old 09-02-2017, 06:59 PM
Lone Wolf
brian6speed's Avatar
Since it looks like gears for CL are discontinued, will a 3rd Gen TL 2nd gear work or should I just swap to 3rd Gen TL tranny?
Old 09-02-2017, 09:26 PM
Received 1,735 Likes on 1,391 Posts
Brian, I just did a part # check on the CL-S6 Countershaft Second Gear Set; 23432-PYZ-305 and it appears that the '04 through '08 manual transmission TL's share the same part # and price $407.73.
In addition, you may want to message BenseBuilt on Facebook and inquire about his gearing options. If you have to replace second gear, while they have the tranny case open, it may be worth considering final drive options as well. Not sure if you want to go that far or even if that sort of thing is allowed for autocross. Just thinking out loud.
Old 09-03-2017, 01:50 AM
Lone Wolf
Nice, thanks for looking it up. I did a quick search and didn't see CL part number. The issue with final drive is that I already hit rev limiter in 2nd during autocross. If I didn't do autocross I would install Final drive. Not sure what the issue is with 2nd gear, don't have any issues with other gears or gears in my Focus. Wish there was a bulletproof 2nd gear.
Old 09-04-2017, 10:50 AM
M90booosted
03-6/6's Avatar
you broke second? its odd they started discontinuing cl parts lately...
Old 09-04-2017, 01:40 PM
Lone Wolf
I didn't break it, but can't shift above 5k without it grinding. I forget name of piece that needs replacing, but you can't replace that one part without replacing whole gear. Replaced 2nd gear 2 years ago but it is acting up again. I have seen other ppl on Facebook complain about same issue. Won't be able to get CL parts much longer, if plan on keeping car better stock up.
Old 09-07-2017, 08:18 AM
fsttyms1's Avatar
Received 3,063 Likes on 2,119 Posts
Odd. I have zero issues with 2nd. I have a syncro for 3rd starting to wear out as i get the occasional grind into 3rd. But with 300k or so on the trans i guess that can be expected.
I need a stronger clutch though with the 275s and the 3.7 motor, and a new shift cable, as mine decided it wanted to snap on me the other day.
Old 09-10-2017, 02:27 AM
Soseductivesf's Avatar
what motor did you use? I'm debating on going with the 3.5 and keeping my heads, Im and throttle body
Old 09-10-2017, 09:00 AM
Lone Wolf
Yea have heard about 3rd gear grinding, but no issues for me there yet. Would like to install k tuned shifter and cables but some ppl have had issues with cables. Wish I could fit 275's. Are you on oem clutch? Xlr8 clutch is working good for me.
Think I'm gonna work on custom front fenders this winter. Wish I had your fab skills. Probably start out shaping foam over oem fender and making fiberglass flares. Aftermarket flares just don't fit well or look good at all. Also thought about buying 3rd Gen tl fender and hacking it up. Could weld lower part of 3rd Gen to upper part of 2nd gen.
Old 09-11-2017, 10:55 AM
M90booosted
03-6/6's Avatar
i had the 1-2 gear set replaced in my 14 accord 6/6. second was so bad with only 50k on it. had it done under warranty. much better now. my cl i think is still smoother shifting than my accord and it has 234k miles on it.
