Notices
2007 Acura TL base model auto trans in 01 Acura cl type s
Old 05-13-2019, 02:52 PM
New Member
Hey my transmission in my 2001 cl type s auto is toast can I use a 2007 Acura TL auto base transmission?
holung is offline
Old 05-13-2019, 03:04 PM
Registered Member
horseshoez's Avatar
No, won't bolt up to your engine; look for a transmission from a 2006-2007 V6 Accord instead; the transmission should have a manufacturing code of BAYA on the case.
horseshoez is online now
Old 05-13-2019, 03:26 PM
New Member
just curious why would it not bolt up if they use the same engine?
holung is offline
Old 05-13-2019, 04:44 PM
Registered Member
horseshoez's Avatar
They aren't the same engine.
The following 2 users liked this post by horseshoez:
TheWeez (05-13-2019), thoiboi (05-13-2019)
Old 05-13-2019, 11:19 PM
Registered Member
Rapture's Avatar
from what I remember I think it's 2004 - 2006 TLs that fit
Rapture is offline
Old 05-14-2019, 09:04 AM
I Wanna Beer
TheWeez's Avatar
Which would be silly as those transmissions have the same design issues that cause failure that the automatic CL experiences.
As horseshoez said, go with a transmission from a 2006-2007 V6 Accord instead.
TheWeez is offline
Old 05-14-2019, 10:32 AM
Received 5,846 Likes on 4,687 Posts
egggzactly.;
Even if it did fit, why would you put a known bad engine into it? sort of defeats the purpose, no?
thoiboi is offline
Old 05-14-2019, 03:03 PM
Registered Member
Even though I understand this thread is in regards to automatic transmissions, in the interest of thoroughness , the 2004-2006 TL 6-speed manual transmission WILL fit the 2G J32A2 bell housing as well; however, if one wanted to use that transmission on a CLS6 specifically, they would have to add the transmission side crank sensor to run with said manual CL's ECU and reconfigure the transmission gearshift lever on the tranny housing since they are different.
zeta is offline
Xios
02-06-2018 11:42 PM
ak20eg
05-15-2014 06:15 PM
eur0diesel
Third Generation TL (2004-2008)
01-20-2012 12:17 PM
daricl
05-12-2009 12:58 PM
tarponman85
11-03-2007 04:03 AM
Quick Reply: 2007 Acura TL base model auto trans in 01 Acura cl type s
