Notices
2003 CLS6 Clutch Pedal Adjustment
Old 04-15-2019, 05:59 PM
Registered Member
smcafee's Avatar
Liked 9 Times in 8 Posts
I'm trying to adjust the clutch pedal on my 2003 CLS6 and need some insight from other manual trans owners.
In adjusting the clutch master cylinder pushrod (in/out) to get the recommended 6" pedal height, there are two nuts on the shaft that are jammed for locking.
  • I can only get a wrench on the outer nut and thus can't unlock them. What procedure is needed to access and loosen the nuts? (Turning one just turned both).
  • What is the small gold-ish cylinder between the pushrod and the clevis? I'm concerned that if I turn the pushrod with the nuts jammed tight, which can be done, something inside this cylinder will be damaged.
smcafee is offline
Old 04-15-2019, 06:26 PM
Registered Member
Liked 458 Times in 394 Posts
I have not done this adjustment myself, so I don't have any personal experience. With that said, I do know, very well, that it is tight quarters up there where you are working.
The attachment below is the clutch pedal adjustment procedure for the CLS6, per the helms manual, so maybe it can help answer some of your questions. You may need to acquire some 'shorty' metric wrenches to get two up there to break the jam nuts.
Also, while you are there be sure to check the condition of the three 'pedal stopper pads' if they are the originals. They tend to deteriorate and crumble over time. If the one for the clutch (Inhibiter) switch goes, it will leave you stranded unable to start the car.
https://www.ebay.com/itm/Genuine-OEM...-/400628441899
File Type: pdf
zeta is offline
Old 04-16-2019, 02:01 PM
Registered Member
smcafee's Avatar
Thanks for the info. I have the manual as well. I'm looking for someone to ID the gold cylinder attached to the pushrod.
smcafee is offline
Old 04-16-2019, 03:43 PM
Registered Member
I'm not exactly sure what that 'gold cylinder attached to the pushrod' does; however, I did contort myself under the dash of my CLS6, to educate myself, and I only observed ONE 12mm nut, at the gold cylinder side of the push rod, that is present.
This jives with what the helms adjustment procedure indicates.
Therefore, I'm not seeing the 'second' jam nut 'for locking' you are referring to in your original post?
zeta is offline
TSX1012m6
Second Generation TSX Discussion (2009-2014)
12-15-2016 08:50 AM
komplexZ
2G TSX Problems & Fixes
07-07-2016 06:09 PM
CivicB18B1
07-23-2011 10:47 PM
artbran
03-05-2009 10:12 PM
dfreder371
Second Generation CL Discussion (2000-2003)
17
06-22-2003 02:16 PM
Quick Reply: 2003 CLS6 Clutch Pedal Adjustment
