2003 CL 6 speed in a 2004 Odyssey
#281
I'd like to make it look finished. I think I can cover most of it with the door pocket and maybe use some JB weld and steel wool to fill in the voids. Maybe cover it with some resin or something. I'm even worse at upholstery than I am at fabrication.
#282
Received 7,772 Likes
Maybe just filler and then Super-77 some thick vinyl or even leather over it? If only you had leather seats to match...
#283
Looks awesome by the way. You're really killing it!
johnboy1313 (08-08-2017)
#284
Well, she's all legal. Title, plates, and insurance added today. I plan to drive it to work tomorrow.
Have I mentioned how much fun it is to drive? Holy sh!t.
#288
It runs great. The only problem I have is that the 4th gear syncro is bad. I get a little grind if I don't double clutch 4th gear. I wish I had opened the trans up while I had it out and taken a look at things, but it's too late now. I'm not gonna drop the trans again for a while if I can help it. Maybe I'll address it the next time I do the clutch.
#289
Latent car nut
Received 2,005 Likes
#290
I've read where that stuff has led to more problems in the long run.
#291
Latent car nut
As others have indicated, quite the contrary really; some folks have been to the point of having the synchros replaced, or worse, the tranny rebuilt when they finally tried ACDelco Synchromesh Friction Modified (beware, there is also a non-Friction Modified version of Synchromesh as well, do NOT use that version). Funny thing, all follow up reports, even after an additional 100,000+ miles indicate the tranny is still shifting flawlessly (assuming a MTF drain/refill every 30,000 miles).
johnboy1313 (08-09-2017)
#295
#296
Latent car nut
Well, I suppose only ten ounces of Honda MTF is better than a full fill of Honda MTF. That said, were it me I'd buy a third quart of Synchromesh and use the Honda MTF to lubricate squeaky door hinges, pour into a hive of ground wasps, or even use it as a cure for dishpan hands; I just wouldn't put it in a Honda manual transmission.
#298
Latent car nut
#299
horseshoez (08-09-2017)
#301
Is it supposed to work right away or does it take some time. I just changed the fluid this afternoon and have only put a couple miles on it. Only got to 4th gear three times.
#302
Latent car nut
Crap! Serious bummer.
When I put the Synchromesh in mine it transformed the transmission in like the first 100 yards; not *quite* "right away", but pretty darn close.
#304
Mainshaft Assembly Clearance Inspection begins on page 13-35 in the Helms Manual.
There is a note that states: If replacement is required, always replace the synchro sleeve and hub as a set.
Does that mean you would have to purchase #3 ($407.73) Gear Set Counter-shaft Second; to get the sychros you need, and possibly #6 ($78.50) Gear, Counter-shaft Forth to remedy your issue?
https://www.acuraoemparts.com/auto-p...ntershaft-scat
#306
you might not be able to fix your problem with just a straight fluid change, but it's a cheap enough potential fix to try.
#308
No, don't mix them. It's a waste of the GMSMFM. You now have diluted fluid which really isn't doing what it was intended to do. It really is an all or nothing fluid change. Also, are you sure the viscosities are the same?
#309
Back at it guys. I'm almost certain the engine and trans are coming out again. After all I've done, my wife isn't that impressed. She doesn't want to drive a second gen Odyssey for the rest of her life, no matter how awesome it is. I shoulda jumped on a chance to get cheap parts for the trans but I didn't, like a chump, so I'm going to be buying new. I'm going to open the trans up, like I should have before I installed it, to examine the damage before I order any parts, then I'm gonna rebuild it myself. I might find a different engine too. I haven't made up my mind if I want more power or better fuel economy. Either way, I'm guessing the 3.2L is gonna go. Feel free to post all the advice you've got regarding building a good motor.
I'll make sure to take some pictures.
#311
J35 or J37 would probably be best
or LS
or LS
#313
I'm going to open the trans up, like I should have before I installed it, to examine the damage before I order any parts, then I'm gonna rebuild it myself. Feel free to post all the advice you've got regarding building a good motor.
Check out the link below for pictures of the inside of a 05 TL 6spd. On page 69 starting at post #2741 and continuing on #2742 and #2743.
https://acurazine.com/forums/3g-tl-p...718808/page69/
Then in post #2751 the banned forum member NVA-AV6 gives some 'good tips' on what to look out for when working on the MT.
Continuing on to post #2755, he shows pictures of the inside of the 03 CLS 6spd tranny.
Hopefully, as part of your preplanning those pictures will give you an idea of what 'stuff' looks like.
The following 2 users liked this post by zeta:
johnboy1313 (09-25-2018),
teh CL (09-30-2018)
#314
I may have spoken too soon. Sometime shortly after my last post, my wife's van gave her troubles so she switched to the shiftervan. After a week or so of driving it, she loves it. I've got to investigate an intermittent P0335 code on her van that I think is related to a broken or shorted wire in the harness somewhere. I'm hoping to find it right away and punt that van down the road. It looks like I won't be pulling the drivetrain out of the shiftervan after all.
#315
Love it when a plan comes together! ATeam.gif.
#316
Nice to have another j32 swapped odyssey. Too bad my van didn't last long as it was wrecked badly. I may try another swap again soon👍🏻
#319
So I’m about to be doing a 6sp swap in an 03 Odyssey.. Do you have pics on how you mounted the clutch pedal under the dash? Also, I’m assuming the wiring is different t from 02-04 than it is the 99-01 Odyssey vans as far as green plug and using the CL harness to run the van.
#320
