2003 acura cl s type
Im totally lost wuth this transmission deal. I just need to know what trannys are compatable with the cl s type . So i can get this car fixed .please help me and if it shifts sometimes till it gets warm could it be the control modual.
3.5 psi
Put in an accord trans from 06-07. All information is found here: https://acurazine.com/forums/second-...n-swap-905115/
The following 2 users liked this post by gnuts:
justnspace (04-20-2018),
TylerT (04-19-2018)
Go to Car-part.com and put in your vehicle and it will only pull up all available parts that are an exact replacement. Great tool to use and if you want to buy a replacement transmission its a great tool for that as well.
This Forum's SEARCH FEATURE is your FRIEND. If you search 2G transmission, you will be able to compare the symptoms your car is exhibiting, to forum members who have experienced the same or similar symptoms, as well as what attempts were made to address them. There is a wealth of information, here-in, regarding this issue. In a nutshell, installation of an 06 or 07 Honda AV6 transmission, is the accepted method to correct 2g transmission failures.
NSX-Tuner
01-03-2015 07:28 PM
