Fuel Injector Question
Old 10-06-2015, 04:12 PM
Scottyknows007's Avatar
Has anyone worked their way down to their injectors and know what the little PCV Valve looking piece is? (has a vacuum line running towards the battery on front and back) It sits through the fuel injector wiring harness into the intake runner?
If anyone has diagram of that area I can point out where it sits.
Thanks in advance!
Old 10-06-2015, 04:51 PM
Right above number 11 in the bottom left of the picture. There is a tiny hole next to the middle injector hole. what hooks up there with the vacuum line?
Old 10-06-2015, 07:39 PM
m_rgaan's Avatar
That pain in the ass left me with a vacuum leak for two weeks until I could source the part. If you've never touched the injectors or runners before, no matter how clean that engine is, it might just break off. It's annoying as heck. It's #5 2001 Acura CL TYPS 5AT TUBING
Old 10-07-2015, 06:24 AM
Lone Wolf
brian6speed's Avatar
That is air assist to the runners.
On my car those holes are welded closed and other parts removed. It is not needed.
Old 10-07-2015, 08:01 AM
Ahh thank you!! I looked everywhere for it .. but it was under tubing! To re install did you have to remove the runner? Or did you just push them through the bracket? It seems like they twist into place and there is not alot of side clearance (Valve covers in the way)
Really? so what exactly does this part do?
Acura9915
02-24-2020 01:27 PM
Kevin Sami
09-22-2015 09:59 AM
cali boy 91
09-19-2015 01:57 PM
jpm3071
09-18-2015 04:51 PM
michaellong77
1G CL Problems & Fixes
09-11-2015 12:54 AM
Quick Reply: Fuel Injector Question
