2001 Acura CL and CL Type S Problem. Need Help!
Old 01-17-2019, 05:25 PM
7th Gear
Mad0424's Avatar
I have 2 Acura Cls, one being a type S and the other just a premium. Anyways, the problem i’m having is the car just stops accelerating. I was driving on the highway prefectly fine then all of a sudden I went to go speed up a bit and the car wouldn’t move. Almost like the car was out of power. The car was still on and running, but just wouldn’t go anymore. I’m having the same issue on my premium Cl too. Just out of nowhere within a day of eachother they had the same issue. I scanned both cars with my Snap On scanner and nothing popped up as far as the transmission goes. On top of that, that cars haven’t had any transmission problems ever. I always let the cars warm up before I drive it, so I don’t think it’s the fact that its cold or anything. When i first start the cars and drive them the second I start them, theyre shifting through all the gears fine and there’s no issues. It’s almost as if the problem starts occuring when the cars warm up. I don’t know if its a random thing that it keeps happening or what. I’m just pretty stuck and can’t seem to figure out or wrap my head around the fact that this problem is occuring in both cars at almost the same time. Is it possible that the trannies could’ve went without warning or any prior issues like that? The only things I haven’t done to either car is chnage he tranny fluid and filter, and I dont know if that would help it or not. I just need some feedback and was wondering if anyone on here had an idea of what could be wrong. Both cars are ATs by the way. If anyone could help ut would be greatly appreciated, thank you!
Old 01-17-2019, 05:34 PM
Received 8,583 Likes on 6,630 Posts
change the fluid and report back.
Thefireball (04-22-2021)
Old 01-18-2019, 07:19 AM
johnboy1313's Avatar
The next time it happens, pull the gear selector back carefully one position. If you have drive again, it's possible that your torque converter lockup solenoid is clogged or sticky due to worn clutches.
+1 on change the fluid and report back. Drain what you can, measure the volume that you drained, pour that much new fluid back into the trans, drive it around for a day or two, then repeat once or twice more depending on when the fluid was last changed. It might not hurt to locate that solenoid valve and clean it, (google is your friend).
Edit: It's called the "Torque Converter Clutch Solenoid" in the SM.
Old 01-18-2019, 09:52 AM
I dug a little more, I don't think I'm right. It could be a solenoid valve that needs to be cleaned, but probably not the TCC solenoid. I'd still do the drain and fills at least. Let us know how it turns out.
Old 01-18-2019, 04:29 PM
7th Gear
Mad0424's Avatar
I’ll be changing the fluid and checking out the solenoid over the weekend while I have the time and i’ll let you guys know how it turns out. Thanks everyone for the feed back!
Old 01-19-2019, 11:53 AM
01acls's Avatar
I would change the trans filter and change atf to Valvoline Max Life (100 percent). If the car drives after the services then at XADO trans reconditioning additive EX120.
Old 01-19-2019, 12:33 PM
7th Gear
Mad0424's Avatar
So I just took out the solenoid and the filters seem clean. Nothing in the screen. However there is a large amount of tranny fluid that’s sitting in the area of the solenoid when I removed it. Is it normal to have a good amount just sitting there?
Old 01-19-2019, 12:38 PM
7th Gear
Mad0424's Avatar
As for my other CL, it turns out that the transmission did just go randomly without any sign. The torque converter got locked up and the transmission is shot. When I scanned it, the torque converter and the gear ratio is off. All that nonsense, but as far as my Type S goes. None of that is popping up when I scan it, but it’s still having the same issue. The Type S is where i’m sitting at the solenoid with the excessive amount of tranny fluid.
Old 01-19-2019, 02:32 PM
01acls's Avatar
Which solenoid are you referring to that may be leaking? The tranny should be dry, if there's a leak then maybe fix that first before doing anything else.
FYI, you should also do the Stop n Go when changing 100 percent of the ATF.
Old 01-19-2019, 02:51 PM
7th Gear
Mad0424's Avatar
There was an excessive amount of tranny fluid when i removed the TCC Solenoid. I know there’s suppose to be fluid there, but when I removed it. It was basically overflowing with tranny fluid. There’s no leak on the transmission itself. And i’ll do the stop and go if this actually fixes the problem. If it doesn’t, then the car is obviously going nowhere lol
Old 04-21-2021, 09:32 AM
6th Gear
Alfred Torres's Avatar
2001 Acura 3.2 CL type-s
[QUOTE
my car started doing the same. Iv been researching and it seems that these cars are known for this issue. When the car gets warmed up the gears start slipping, or will just go out of gear and will not be able to accelerate. Sometimes it will take it's time going into gears like reverse and drive. Anyhow, seems that the transmission lines are not big enough and not allowing enough fluid into the gears. I'm going to change all transmission solenoid valves which seem pretty easy. I'm also going to change transmission control solenoid. I'll most likely change the transmission lines from radiator housing with bigger lines and hopefully that with cure the issues. I'll get back when I have completed with the results. This will be a whole lot cheaper than having to buy a new tranny. Plus when it is not hot it seems to drive perfect with no issues until it warms up then it will begin to act up. So this tells me the tranny is fine and the issue is most likely the pressure solenoid for the tranny. On the transmission if you look closely you can see where the gear solenoid are numbered.
TL-evateYourRide
01-03-2019 06:11 PM
preludeshfan
08-06-2006 09:40 AM
gnay_RENAMED
09-13-2002 01:32 PM
ACURACR
06-01-2001 09:01 PM
kensteele
05-10-2001 10:23 PM
Quick Reply: 2001 Acura CL and CL Type S Problem. Need Help!
