105K Mile Service
105K Mile Service
Does anyone have an idea what the 105K mile service costs? I'll probably end up doing everything myself except for the timing belt, but I thought it would be interesting to find out what the whole kit and kaboodle would run.
Administrator Alumnus
Have you put the entire 105,000 miles on the car? Curious to how things have been for you? Transmission and other problems throughout ownership???
I don't think too many people here have crossed that magical 100k mark.
I NEED MONEY!
Wow, What year are you driving? What major problems did you run into besides the transmission? I suggest trading it in, cause the CL is not worth keeping if you don't have the warranty on it. Mainly because of all the problems that have been happening, we find new one about every week.
I'm at 102K miles right now. I bitched and screamed for the first 60K miles because I had quite a lot of issues although they were covered under warranty. I also had the transmission replaced at 62K. Since then I haven't one single issue with the car. Well, that's not exactly true - the rear view mirror auto dim feature hasn't worked since 90K but since my windows are tinted it isn't much of an issue. All told, I have spent nothing on the car other than normal maintenance that I have done myself - the Acura service manual is awesome! My plan is to keep her until 200K or until the tranny goes. If the tranny goes again, I'll replace it and run her another 20-30K before dumping her.
Stock CLS Meister
Price of Maintenance here 105k
Flush/replace Coolant $12.00 $48.30
Change Engine oil $11.75 $13.80
Rotate Wheels & tires $0.00 $20.70
Inspect Steering $0.00 $6.90
Inspect Brake system $0.00 $20.70
Inspect Exhaust system $0.00 $3.45
Inspect Parking brake $0.00 $3.45
Inspect Brake lines, hoses & connections $0.00 $1.38
Inspect Cooling system hoses & connections $0.00 $6.90
Inspect Fluid levels $0.00 $3.45
Inspect Suspension $0.00 $3.45
Inspect Fuel lines, hoses & connections $0.00 $3.45
Inspect boots & seals Drive axles $0.00 $6.90
Replace Oil filter $6.60 $6.90
Check Idle speed $0.00 $6.90
Inspect Valve clearance $0.00 $3.45
Replace Spark plugs $94.80 $48.30
Replace Timing belt $51.80 $262.20
Subtotal: $176.95 $470.58
Estimated total cost: $647.53
Copyright Edmunds.com, Inc.
OUCH!
OUCH!
OUCH!
OUCH!
War Eagle!!!
mada51589
05-03-2022 08:54 PM
Zonian22
11-14-2015 01:20 PM
asahrts
09-04-2015 05:55 PM
