03CLS6 Autocross/Track/Street Build Thread
Old 04-02-2015, 08:08 AM
  #401
Lone Wolf
brian6speed's Avatar
Roll Bar & Rear Seat Painting Part 1 - Preparation
Supplies to prep interior for painting.
Supply List
Mineral Spirits
Plastic Roll
Newspaper
Tape
Gloves
Paint Prep Wipes
Sandpaper
Wire Brushes
Dremel
Scissors
Sand Paper
Lights
Steel Wool
Pliers
Screw Driver
Mask
Glasses
Decided to paint rear seat area first, then mask rear seat and paint roll bar after to avoid overspray.
Masking begins. It is a long & tedious process.
Supplies to Paint Rear Seat Area.
Rear Seat Area after Paint.
Had a hole in floor from a chunk of metal road debree being flung at me on highway driving back from National Acura Meet. Had King Motorsports weld the hole up. I added some JB Weld to clean it up and painted.
Old 04-02-2015, 07:29 PM
  #402
Lone Wolf
Decided to replace the Seat to Chassis Hardware with Titanium since I seem to be replacing OEM quite frequently.
Weight saved .26 lbs.
Old 04-03-2015, 04:20 PM
  #403
Lone Wolf
Roll Bar Painting Part 2 - Primer
Finished masking for paint, then sprayed primer.
Old 04-03-2015, 09:25 PM
  #404
AZ Track Whore
vill0169's Avatar
Looking good man, can't say I'm looking forward to painting mine when it's finished!
brian6speed (04-04-2015)
Old 04-04-2015, 06:41 AM
  #405
Lone Wolf
Thanks. Yours will be even more of a pain since it is a full cage. Are you painting with the front and rear windshields removed or installed?
Masking takes a lot of time and patience. Another annoyance is working and crawling around plastic and roll bar. Probably hit my head on bar dozens of times. Hard to crawl under the bar when painting without touching and smearing paint. Then you can't breathe from the gas mask, the paint makes your eyes water really bad, and the space to paint is limited.
Should finish sanding primer and painting today. Will be happy to finish this project. Definitely not one of my favorite projects. Would rank it close to removing sound deadening.
Old 04-04-2015, 06:04 PM
  #406
Lone Wolf
Does anyone know where I can source one of these badboys? Would be great to use at my events.
Curry Acura Parts has it listed on their site, but the site does not let you put it in your cart. Emailed them, just waiting for a reply.
http://www.curryacuraparts.com/coolstuff
Old 04-06-2015, 04:53 PM
  #407
Lone Wolf
Still working on painting roll bar. Almost done.
My wheels won't arrive till the end of the month, so my 1st track day will be without new wheels or bbk. This should give me a good base to compare the bbk with racing pads too. Maybe use up my tires so I can buy fresh rubber for new wheels also.
Still a good amount of work to make it track ready in next 2 weeks.
Will be running Motul RBF 600 Brake Fluid at first event and switching to my Prospeed fluid when bbk is installed.
Old 04-07-2015, 02:31 PM
  #408
Lone Wolf
Ordered a pack of 5 Black M5 Countersunk Washers from Pro-Bolt Aluminium Countersunk Washers M5 Pack x 5 Black
Their prices are rather high, but they are one of the few sites that sell M5 Countersunk Washers in style I wanted.
Used 4 of them, 2 per side view mirror.
Old 04-07-2015, 02:33 PM
  #409
Baller of Uni
CLassy02's Avatar
Looking great Brian! You plan on attending Import Alliance in Kentucky this summer?
Old 04-07-2015, 02:54 PM
  #410
Lone Wolf
Roll Bar Painting Part 3 - Painting & Unmasking
Before painting, sanded primer with 600 grit sandpaper then cleaned.
So glad to be done painting. I kept applying coats, then going back with a flashlight looking for areas that weren't fully covered. After about 10 painting sessions I was happy. I think it turned out great.
The bar is so close to the sheet metal in some areas that it is hard to get full coverage with a spray can. It is a delicate balance between getting full coverage but also avoiding drips.
Here is the Primer & Paint used. You can buy it at Walmart or Menards. I used this matte black paint in the past and like how it applied. Ended up using 3 cans of primer & 4 cans of paint.
Unmasking
Painted
Used this Zaino Dual Action Paint Cleaner & Swirl Remover to clean up the little bit of overspray. Love this stuff, use it for all my paint correction also. Zaino is all I use on exterior besides 303 spray on vinyl and rubber.
Ordered these Split Collars from Split Collar for Harness Bar-Stable Energies about a month ago. Had to wait for them to be powdercoated. Finally arrived. These will prevent harnesses from sliding on the bar.
Old 04-07-2015, 03:04 PM
  #411
Lone Wolf
Hey whatsup. Been a long time since I saw you at National Meet.
Never been to Import Alliance or Kentucky. Wasn't planning on it.
Only car meets/shows I have planned is National Acura Meet. Might go down to Tennessee for FocusFest and to drive the Tail of the Dragon. Not sure yet. Might do 1 or 2 car shows in Chicago area, but that is about it. Car shows aren't really my type of scene. Will be my busiest car related summer yet.
Old 04-07-2015, 08:04 PM
  #412
3.5 psi
gnuts's Avatar
That's a lot of work, props, turned out great.
brian6speed (04-07-2015)
Old 04-08-2015, 08:51 AM
  #413
Baller of Uni
CLassy02's Avatar
Yeah no lie man. I've lived in TN for two years now and still haven't made it to the Tail of the Dragon. I really need to.
Old 04-08-2015, 10:09 AM
  #414
Lone Wolf
I didn't even realize you lived in TN when I posted that.
Old 04-08-2015, 10:22 AM
  #415
Dharma Member
ahxChun's Avatar
seen some ze40 on FB that someone was selling,
Volk Ze40
18x9 +25
18x11 +15
would the x9 work for you?
there is also a square set x9 +45 but im not sure if its still available.
Old 04-08-2015, 02:53 PM
  #416
Baller of Uni
CLassy02's Avatar
Yeah unfortunately TOTD is still 3 ish hours away because Nashville is in CST and TOTD is EST. If you go let me know I really want to get out there. Merc could use some good driving.
Old 04-08-2015, 04:26 PM
  #417
Lone Wolf
Volk Ze40
18x9 +25
18x11 +15
Thanks for looking. No square setup for me, reverse staggered. Already purchased rear wheel set that I will use on the front at the beginning. I am pretty set on getting 18x9 +35 for next 2 wheels. No other size makes sense for me. +25 would stick out too much. Will probably need to pull front fenders. Could go with 18x8.5 + 42 square but that is boring and limits tire size to 255. The 18x9 +35 will have a more concave face then my other 2 wheels (18x8.5 +42). Eventually want to run 265 or 275 front tires and 245 rear tires.
I will let you know. Focusfest is on 8-28 so kind of far off. Hopefully TOTD won't be too crowded to have some fun.
Old 04-09-2015, 08:16 AM
  #418
Scottyknows007's Avatar
Is the reverse staggered to keep traction on the front end?
Old 04-09-2015, 10:57 AM
  #419
Lone Wolf
That is part of it. Bigger tire in front or stickier compound will aid in front end traction. So will a front splitter and downforce.
For the rear, that is basically just along for the ride, I do not need bigger tires. Rear wing & diffuser will help with grip and aero balance though. Smaller tires should help with aero efficiency, remove some weight, and be cheaper.
Rear grip is more needed at track than autocross. For autocross I have even been thinking of going with stickier tires up front than in the rear, hoping it will help car Rotate more. To really Rotate car properly I have to master left foot braking. In those cases it seems like weaker brakes are better. When you use your left foot to Brake without being used to it, you use it like an on/off switch. This means you will always be slamming the brakes everytime and sending your head through the windshield.
Pretty much any serious fwd track car I've seen runs reverse staggered setup.
Scottyknows007 (04-09-2015)
Old 04-09-2015, 03:53 PM
  #420
Lone Wolf
Applied 2 coats of Zaino Z2 Show Car Polish to Roll Bar. Finished it off with Zaino Clear Seal.
Here is the bracket for Flare.
This spot is perfect for mounting it. There is a threaded hole and a depression for that tab on the bracket to fit into.
Flare Mounted.
Fire Extinguisher Mounted. Thought this spot gave me the best access to it in case of an emergency.
Driver Harness Mounted to Roll Bar.
Old 04-09-2015, 11:51 PM
  #421
takin care of Business in
swoosh's Avatar
Received 4,732 Likes on 4,064 Posts
ohhh Lord....your car is coming along very well Brian...
see you at the meet
Old 04-10-2015, 06:56 AM
  #422
Lone Wolf
see you at the meet
Thanks. Looking forward to meet and seeing familiar faces.
Old 04-11-2015, 01:21 PM
  #423
Lone Wolf
So my cooling system seemed fine last time I drove it, but not today. This seems to be an ongoing issue.
My Radiator fan only turns on when a/c is on. According to manual this is a Radiator fan switch A issue. Is that the only cause it could be?
Don't think I can order a new part in time for my event, so might have to forfeit 225 bucks.
Old 04-11-2015, 07:10 PM
  #424
swoosh's Avatar
whats an AC?
Old 04-11-2015, 11:42 PM
  #425
Lone Wolf
whats an AC?
AC is what I have to run in order not to overheat engine instead of myself.
Old 04-12-2015, 11:51 AM
  #426
swoosh's Avatar
its a track/diet car, delete that ish already
Old 04-13-2015, 09:16 AM
  #427
Lone Wolf
Eventually. You try driving 9 hours straight to National Meet in 90 degree weather. Keep in mind exhaust heat gets inside the car also so it is kind of like a sauna. Tried that once and my shirt was completely drenched with sweat. Always reminded of Top Gear episode with James naked in the race car.
I like to run A/C at autocross events to keep me cool between runs, otherwise you get really hot and sweaty.
Old 04-13-2015, 09:20 AM
  #428
Lone Wolf
When idling, what temp should the radiator fan kick on with or without cooling mods?
If I let my car idle without A/C it gets to 190 degrees before both fans kick on for less than 1 minute and drop temp down to 180-185. Then it goes up to 190 and process repeats.
If I leave A/C on temp never goes above 170.
Shouldn't the radiator fan come on seperate? Mine are either both on or none. My fans also never run after shutting car off.
Old 04-13-2015, 09:40 AM
  #429
swoosh's Avatar
The temp you mentioned looks/sounds about right....with my MS3, I have it programmed to kick the fan on after 180degs and stay on until its back down to 175...
Let me keep an eye on my fan(s) and see how/when they come on
Old 04-13-2015, 11:34 AM
  #430
Lone Wolf
Yea let me know. Trying to figure out if I really have an issue or not.
Have been driving with the Pspec SS on the shortest throw setting. It seems like that setting is too short for the clutch/master cylinder to sync/function right. Going with a longer throw and extending the shifter as far up as possible. Will report back after a few drives.
Old 04-13-2015, 01:24 PM
  #431
Lone Wolf
Definitely shifts better with Pspec throw set in one of the middle positions.
Think I will wire up both fans to a switch on my dash panel so I can run them whenever I'm in traffic or idling.
Old 04-13-2015, 02:21 PM
  #432
Received 1,736 Likes on 1,392 Posts
This is WITH the Mugen cooling mods.
When I perform the 'idle relearn' procedure, for instance, after disconnecting the battery for whatever reason, I just start the car, let it idle with NO A/C and/or with as little electrical load ON as possible.
Keeping an eye on the ScanGuageII water temp function, the temp slowly rises to 186 degrees before I hear the radiator fan ONLY come on. The Radiator fan stays ON until the temp. goes down to around 175-180ish then shuts OFF (Maybe 60-90 secs). It's hotter than two Hells down here in FL, hehe.
It will do this consistently for as long as I let it, usually three times, to 'relearn' the idle. Then I will turn ON the A/C to check that it works and BOTH fans usually turn on at the same time.
However, I have never left the A/C on, at idle, long enough to observe when and if the fans shut down together or separately, sorry.
brian6speed (04-14-2015)
Old 04-14-2015, 01:32 PM
  #433
Lone Wolf
Flushed Brake Fluid and power steering fluid and replaced with Honda PS Fluid and Motul Brake fluid. The steering feels a little better.
Ordered other 2 Volk wheels, but won't arrive till June or july. Price has gone up almost 100 per wheel since I purchased first 2.
Old 04-18-2015, 09:40 AM
  #434
Lone Wolf
Ordered this Lisle Funnel to burp coolant. It makes avoiding over-spill easier. It comes with multiple attachments. One fits Honda radiators.
Amazon.com: Lisle 24680 Spill-Free Funnel: Automotive Amazon.com: Lisle 24680 Spill-Free Funnel: Automotive
Did burp procedure again, but no more air was found in system.
Old 04-18-2015, 09:50 AM
  #435
Lone Wolf
Removed a box of parts from trunk of car and set it on floor. Forgot about it and backed the car into the box. The tow hook saved the bumper, besides for a few small paint cracks I noticed under the tow hook.
Decided to cut that section off and reshape it.
Noticed that the bumper beam foam support and plastic bumpers were loose in bumper area and not really doing much besides collecting rocks.
Removed the plastic bumpers and foam. 1.1 lbs removed.
Here is just one pile of the rocks that fell out of rear bumper when removing foam.
Old 04-20-2015, 10:58 AM
  #436
Lone Wolf
Rescheduled my 4-22 track day to 9-16.
Only 3 events scheduled for May.
May 3 - Autocross Boomers Stadium Schaumburg
May 13 - Track Day Blackhawk Farms Raceway
May 17 - Autocross Boomers Stadium Schaumburg
Old 04-20-2015, 11:17 AM
  #437
swoosh's Avatar
good work dude
brian6speed (04-20-2015)
Old 04-20-2015, 01:15 PM
  #438
n3o
n3o's Avatar
Words cannot express how happy your build thread makes me.
Old 04-20-2015, 03:14 PM
  #439
johndo18's Avatar
I agree....your detailed explanations make your threads both enjoyable and educational
Old 04-21-2015, 05:54 AM
  #440
Lone Wolf
Thanks for kind words everyone.
Should have another update to post later today.
Quick Reply: 03CLS6 Autocross/Track/Street Build Thread
