03CLS6 Autocross/Track/Street Build Thread
#1402
Plans for this winter are more weight reduction (would like to get down under 2600 lbs), front splitter modifications, drag reduction mods, aluminum PCI side skirts with modification, fender venting modification and possibly custom flares, air intake duct, underbody panels, maybe rework rear diffuser, rear wing or trunk spoiler with oem wing, and begin planning and getting parts for 3.6 engine build or possibly rotrex sc.
If anyone is interested locally in my VIS carbon trunk send me a pm. It has no damage, but don't trust mounting a wing to it. Would possibly trade for oem trunk without spoiler and little cash on top.
#1404
Installed air intake duct, fender vents, and PCI side skirts. Car looks much more aggressive with side skirts. Will get some pics posted up soon.
I also have pics from track day to sort through and post.
Could post DIY on mounting side skirts if anyone is interested.
Working on lightening splitter support brackets atm, will post full car pics once front bumper is back on.
teh CL (12-11-2017)
#1407
Fender Venting: Brainstorming
Decided to just add fender louver vents for now. In the future could add more venting.
Here are few ideas.
Could also gap rear of fender, but would need to cut lip off.
Fender Louver Vent: Installing
Vent Mock-Up
Vent Opening Cut-Out
Mesh added to Fender Trim
Louver Vent Mounted with M3 Hardware
Here are few ideas.
Vent Mock-Up
teh CL (12-15-2017)
#1409
No this is to vent front wheel wells. Spinning tires build up a lot of high pressure that creates drag. Having venting gives that pressure a way to escape and reduce drag and maybe lift. This won't really reduce weight.
Have not had any brake issues doing 20 minute sessions, so don't see need to install ducting atm.
Downloaded track pics, just need to sort thru and upload to pb, then I'll post link.
teh CL (12-15-2017)
ProfessorFunk (12-22-2017)
#1422
After installing the 71R tires on rear, car tends to still understeer.
Ordered Hardrace LCA pillowball bushings and the UCA pillowball bushings. Gonna replace rubber bushings that come in Hardrace UCA's. My current setup is maxed at -2 front camber. Hardrace arms provide more adjustment which might help understeer.
Probably gonna up rear spring rate from 14k to 16-18. Might lower front from 12k to 10.
Cusco made a lsd for newer J Series Trans to run in Pirelli World Challenge Accords.
https://www.heeltoeauto.com/differential/cusco-type-rs-limited-slip-differential-1.5-way-honda-j-series-v6-transmissions-lsd-339-c15-cus.lsd-339-c15.html
Would need P2R final drive also. So lsd+fd+install is gonna be $4k.
#1423
http://www.powerrevracing.com/P2R-J-Series-4-1-Final-Drive-p/p355.htm
#1424
https://www.heeltoeauto.com/differen...d-339-c15.html
P2R J-Series 4.1 Final Drive
Has your experience with Hardrace parts been good? Looks like an interesting alternative to the normal brands that make parts for the CL.
#1425
No complaints or issues with any of their parts. They are pricey though. I've been running steering rack bushing, extended ball joints, lca's (oem lca with hardrace hardened rubber), uca pillowball bushings, 4 rear arms (pillowball), rear control arms (pillowball), and rear hub bushings (hardened runber) for 2 or more years.
#1427
If your interested in going with the 3.8 final drive. I'm going to be posting up a complete gear set w/ final drive from a 13' 6MT SH-AWD TL in the marketplace soon.
Shoot me a PM if your interested.
Oldsman71 (05-25-2020)
brian6speed (08-19-2023)
#1430
Whats up guys I'm back. Need to clean 2 years of dust off the ole CL and get to work again. Just need yo change oil and rear sway bushings and CL should be good to go. Gonna be picking up a 2023 subaru wrx as my daily soon after totaling my 2020 Wrx.
Covid put a damper on my racing and I switched hobbies for 5-6 years. Been having health issues and bad vertigo for years now which prevented me from working on car.
The following 2 users liked this post by brian6speed:
civicdrivr (08-21-2023),
CLtotheTL32 (08-22-2023)
#1432
Transmission Pro
#1433
#1434
Transmission Pro
2018-2020 (pre-facelift) had 6MT option -- stock gearing sucks but easy to put FK8 LSD / 4.11 final drive and FK8 5th and 6th in it.
the 10AT trans is awesome too.
#1435
#1437
The following 2 users liked this post by Thefireball:
619rcr (08-21-2023),
brian6speed (08-21-2023)
