03CLS6 Autocross/Track/Street Build Thread
Old 10-18-2017, 10:31 PM
  #1401
Lone Wolf
brian6speed's Avatar
Did track day at BlackHawk today. Video from last session.
Old 10-20-2017, 12:25 AM
  #1402
Lone Wolf
Plans for this winter are more weight reduction (would like to get down under 2600 lbs), front splitter modifications, drag reduction mods, aluminum PCI side skirts with modification, fender venting modification and possibly custom flares, air intake duct, underbody panels, maybe rework rear diffuser, rear wing or trunk spoiler with oem wing, and begin planning and getting parts for 3.6 engine build or possibly rotrex sc.
If anyone is interested locally in my VIS carbon trunk send me a pm. It has no damage, but don't trust mounting a wing to it. Would possibly trade for oem trunk without spoiler and little cash on top.
Old 10-23-2017, 09:33 AM
  #1403
6mt swapped..smart
AnthraciteTypeS's Avatar
Pm'd you Brian
Old 12-11-2017, 11:03 AM
  #1404
Lone Wolf
Installed air intake duct, fender vents, and PCI side skirts. Car looks much more aggressive with side skirts. Will get some pics posted up soon.
I also have pics from track day to sort through and post.
Could post DIY on mounting side skirts if anyone is interested.
Working on lightening splitter support brackets atm, will post full car pics once front bumper is back on.
teh CL (12-11-2017)
Old 12-11-2017, 06:14 PM
  #1405
M90booosted
03-6/6's Avatar
post the diy!!
Old 12-11-2017, 06:42 PM
  #1406
Lone Wolf
Originally Posted by 03-6/6
post the diy!!
K, will do. Need to get better pics first.
Old 12-14-2017, 05:44 PM
  #1407
Lone Wolf
Fender Venting: Brainstorming
Decided to just add fender louver vents for now. In the future could add more venting.
Here are few ideas.
Could also gap rear of fender, but would need to cut lip off.
Fender Louver Vent: Installing
Vent Mock-Up
Vent Opening Cut-Out
Mesh added to Fender Trim
Louver Vent Mounted with M3 Hardware
teh CL (12-15-2017)
Old 12-14-2017, 06:46 PM
  #1408
rockstar143's Avatar
Received 19,915 Likes on 14,457 Posts
this is to cool the brakes? any weight savings also?
Old 12-14-2017, 08:28 PM
  #1409
Lone Wolf
No this is to vent front wheel wells. Spinning tires build up a lot of high pressure that creates drag. Having venting gives that pressure a way to escape and reduce drag and maybe lift. This won't really reduce weight.
Have not had any brake issues doing 20 minute sessions, so don't see need to install ducting atm.
Downloaded track pics, just need to sort thru and upload to pb, then I'll post link.
Old 12-15-2017, 07:36 AM
  #1410
I like your vids.
Cool, didn't realize that...
did you notice an actual difference in how it drives from doing that?
You're gonna end up with an Atom car...bare bones. Cool.
Old 12-15-2017, 10:15 AM
  #1411
Lone Wolf
I like your vids.
Thanks. Have not driven it since installing fender vents or side skirts. I won't notice anything from driving it. Not much left to do weight wise(for street driven car), so next step will be adding more power with 3.5 or 3.6 build.
Old 12-15-2017, 10:36 AM
  #1412
Lone Wolf
Few pics from track day in October.
teh CL (12-15-2017)
Old 12-15-2017, 01:11 PM
  #1413
Funny but seeing it in bits and pieces made me cringe...
but seeing the big picture now, it looks pretty cool.
Old 12-16-2017, 11:17 AM
  #1414
Oldsman71's Avatar
Wow Brian. I hardly recognize your car now. Looks like you added a roll cage at some point too.
Old 12-16-2017, 12:42 PM
  #1415
Lone Wolf
Yea front changes look of the car. I just have half a cage, not full cage. How you been?
Old 12-16-2017, 09:41 PM
  #1416
does it?
Old 12-17-2017, 11:14 AM
  #1417
Lone Wolf
does it?
Just a bit. Should be able to take car out of garage today to get pics of side skirts. I can't seem to get good pics with car in garage.
Old 12-18-2017, 04:28 PM
  #1418
Lone Wolf
Side Skirts Installled
Still working on Side Skirt DIY, but here are some pics till then.
Old 12-21-2017, 08:03 AM
  #1419
I know it's more about function than form but have you considered doing a silver plastidip over your fab'd pieces to at least give the appearance a uniform look?
Old 12-22-2017, 12:47 PM
  #1420
Lone Wolf
No, I like silver and black. My cars new mascot is Silverback gorillla. Gorillas are fwd just like my car.
Old 12-22-2017, 01:11 PM
  #1421
that's the funniest thing you've ever said, guaranteed.
ProfessorFunk (12-22-2017)
Old 02-20-2018, 06:33 PM
  #1422
Lone Wolf
After installing the 71R tires on rear, car tends to still understeer.
Ordered Hardrace LCA pillowball bushings and the UCA pillowball bushings. Gonna replace rubber bushings that come in Hardrace UCA's. My current setup is maxed at -2 front camber. Hardrace arms provide more adjustment which might help understeer.
Probably gonna up rear spring rate from 14k to 16-18. Might lower front from 12k to 10.
Cusco made a lsd for newer J Series Trans to run in Pirelli World Challenge Accords.
https://www.heeltoeauto.com/differential/cusco-type-rs-limited-slip-differential-1.5-way-honda-j-series-v6-transmissions-lsd-339-c15-cus.lsd-339-c15.html
Would need P2R final drive also. So lsd+fd+install is gonna be $4k.
Old 02-20-2018, 06:34 PM
  #1423
Lone Wolf
http://www.powerrevracing.com/P2R-J-Series-4-1-Final-Drive-p/p355.htm
Old 02-20-2018, 08:13 PM
  #1424
bkrupp's Avatar
https://www.heeltoeauto.com/differen...d-339-c15.html
P2R J-Series 4.1 Final Drive
Has your experience with Hardrace parts been good? Looks like an interesting alternative to the normal brands that make parts for the CL.
Old 02-20-2018, 10:03 PM
  #1425
Lone Wolf
No complaints or issues with any of their parts. They are pricey though. I've been running steering rack bushing, extended ball joints, lca's (oem lca with hardrace hardened rubber), uca pillowball bushings, 4 rear arms (pillowball), rear control arms (pillowball), and rear hub bushings (hardened runber) for 2 or more years.
Old 05-08-2018, 08:08 AM
  #1426
Lone Wolf
Been so long since I've been on here, had trouble remembering my password. If anyone is looking for parts message me, need to clean out my storage.
Old 06-13-2018, 11:41 AM
  #1427
teh CL's Avatar
If your interested in going with the 3.8 final drive. I'm going to be posting up a complete gear set w/ final drive from a 13' 6MT SH-AWD TL in the marketplace soon.
Shoot me a PM if your interested.
Old 05-19-2020, 09:47 AM
  #1428
Quarantuning
SlickShiftNall6's Avatar
Bumping this thread for those who may have missed it. I think Brian bought a new Civic Type R. Would be interested in any updates if you are still out there Brian.
Oldsman71 (05-25-2020)
Old 05-25-2020, 06:46 AM
  #1429
Oldsman71's Avatar
Yeah I haven't seen anything from Brian in a long time. Hope he is well. The work he did on this CL is acurazine HOF worthy in my opinion.
brian6speed (08-19-2023)
Old 08-19-2023, 01:29 AM
  #1430
Lone Wolf
Whats up guys I'm back. Need to clean 2 years of dust off the ole CL and get to work again. Just need yo change oil and rear sway bushings and CL should be good to go. Gonna be picking up a 2023 subaru wrx as my daily soon after totaling my 2020 Wrx.
Covid put a damper on my racing and I switched hobbies for 5-6 years. Been having health issues and bad vertigo for years now which prevented me from working on car.
The following 2 users liked this post by brian6speed:
civicdrivr (08-21-2023), CLtotheTL32 (08-22-2023)
Old 08-19-2023, 01:46 AM
  #1431
Lone Wolf
Thanks, appreciate it.
Old 08-19-2023, 02:52 AM
  #1432
Transmission Pro
Bense's Avatar
Welcome back
Old 08-19-2023, 03:56 AM
  #1433
Lone Wolf
No civic type R, too expensive. Had a 2014 focus st, then 2020 wrx, now i'm getting a 2023 wrx premium(just waiting for check from insurance). I thought about getting new civic si, but hard to justify when honda is upcharging and subaru is offering $1557 off msrp on 2023 Wrx. Too be honest I'm not really a fan of newer cars and miss driving CL on street. CL is just so much more fun than a stock wrx.
Old 08-19-2023, 11:54 AM
  #1434
Transmission Pro
Bense's Avatar
Why not something like a 10g Accord Sport 2.0T?
2018-2020 (pre-facelift) had 6MT option -- stock gearing sucks but easy to put FK8 LSD / 4.11 final drive and FK8 5th and 6th in it.
the 10AT trans is awesome too.
Old 08-19-2023, 04:46 PM
  #1435
Lone Wolf
I thought about buying used, but never bought used before. Not sure I want to find other ppls problems. My insurance policy has a "New Replacement" clause for enough to cover $30k. I like WRX just wish it had better steering feel and a honda shifter.
Old 08-19-2023, 09:15 PM
  #1436
Lone Wolf
I'm gonna have to remove AEM ecu and go back to stock so I can pass emissions. Wish I never installed it to be honest. Gains on N/A 3.2 were so minimal, plus it idles bad.
Old 08-20-2023, 07:16 PM
  #1437
619rcr's Avatar
I'm sure someone would buy it if you list the AEM, being discontinued and all.
Old 08-20-2023, 10:20 PM
  #1438
Lone Wolf
Ah I didn't know it was discontinued, stopped following car stuff about 6 years ago.
Old 08-21-2023, 10:57 AM
  #1439
I am dumb
Thefireball's Avatar
ah i didn't know it was discontinued, stopped following car stuff about 6 years ago.
I need it. I want it. I can't afford it.
The following 2 users liked this post by Thefireball:
619rcr (08-21-2023), brian6speed (08-21-2023)
Old 08-21-2023, 08:11 PM
  #1440
Lone Wolf
Are most ppl running aem in states without emissions or are they swapping ecu's every year?
Quick Reply: 03CLS6 Autocross/Track/Street Build Thread
