03 CL-s swap 93 civic AEM speedo. - AcuraZine - Acura Enthusiast Community
Notices
Old 03-11-2019, 07:44 AM
New Member
To start off my setup.
I have a 1993 civic with a full manual 03 CL Type s swap in it.
I am running a stock built CJs wiring harness to use stock ecu. Everything worked great no issues.
I switched over to AEM 6051 with the Boomslang jumper harness. Everything currently works other than the speedometer. I'm no showing any Vehicle speed in the AEM tuner or on the dash.
any help is greatly appreciated.
Civiceg_type_s_ is offline
Old 03-11-2019, 02:45 PM
New Member
I'm not really worried about my cluster I'm just trying to get it to show VSS in the software. I'm not getting any feedback.
I currently have these pins plugged
AEM. Engine side
D9. SG3 sensor ground
D11. Mainshaft speed sensor
D10. Countershaft speed sensor
D12. Has nothing in it.
Old 03-11-2019, 03:05 PM
PFI speed on youtube showed how to get around this issue, I think...lemme find it for you
justnspace is offline
Old 03-11-2019, 03:06 PM
Old 03-11-2019, 03:12 PM
New Member
I've watched that video a million times already... haha
they never really specify where the D9 pin goes on the engine and so forth.
I've tried everything but still no VSS on the Software. Aem isnt seein any of it
Old 03-11-2019, 03:19 PM
comment on the video!!!!! Brent is awesome and loves to help out
Old 03-11-2019, 03:26 PM
New Member
I have been emailing Jamie and they haven't gotten back to me yet. But hopefully they can help.
The Following User Says Thank You to Civiceg_type_s_ For This Useful Post:
justnspace (03-11-2019)
Old 03-11-2019, 03:43 PM
Registered Member
AEM. Engine side
I'm not sure if any of this will help you; so I'm just throwing it out there for you to consider.
I'm looking at the Boomslang AEM 6051 2001-2003 Acura CL Manual Transmission schematic (pinout; or whatever it's called ) they (Boomslang) provide when one purchases their harness to connect the AEM 6051 to the CLS6 wiring harness.
This is what it states for the items you have listed above:
6051; Function; CL
D9 SG3 E7
D11 Mainshaft Speed B16
D10 -
D12 Clutch Switch E17
For the Counter shaft Speed it has
6051; Function; CL
C29 Countershaft speed B7
I can't see anything that specifically says 'speedometer'; however, it may be here labeled as some other 'function'.
zeta is offline
Old 03-11-2019, 03:47 PM
Registered Member
There is a 'VSS Out' on the schematic:
6051; Function; CL
A9 VSS Out E26
Maybe that's your Speedo??
zeta is offline
Old 03-11-2019, 03:50 PM
New Member
6051; Function; CL
D9 SG3 E7
D10 -
6051; Function; CL
is there any way I can get you to send me the pinouts to the boomslang harness?
Old 03-11-2019, 03:58 PM
Registered Member
Originally Posted by 2ndgentl View Post
I don't have a file or working scanner, just a hard copy, at the moment; however, the guy above just received his and he left pictures. Maybe it will help?
zeta is offline
Old 03-11-2019, 04:15 PM
New Member
awesome.... thank you for sharing the pics. Hopefully this should help. I have found one that's wrong.
currently I have D10 going to B7 and nothing in C29. Hopefully I swap that and she works.
Old 03-11-2019, 04:47 PM
New Member
I found a few other things wrong compared to the diagram.
C8 going to A11(should be A12)according to diagram...
C20 going to E11(should be A11)
C29 has nothing. (Should be B7)
Old 03-12-2019, 03:53 AM
Unregistered Member
Karanx7's Avatar
https://acurazine.com/forums/second-...pm-fix-878358/
That should clear up the problem for the speedo. Essentially, the AEM should provide sensor ground to D12, but it doesn't do that for whatever reason. D9 is a close by sensor ground, so you can splice into that. This will provide D12 with sensor ground and allow the speed sensor to work.
Karanx7 is online now
The Following User Says Thank You to Karanx7 For This Useful Post:
zeta (03-12-2019)
JohnsonCG
Second Generation CL Discussion (2000-2003)
14
02-01-2013 09:02 AM
ryebreadisme
09-05-2006 09:50 PM
TypeSKid
CL Street Encounters
06-04-2002 10:46 PM
jimster716
Ramblings
02-04-2002 08:44 PM
RidinLow
First Generation CL Discussion (1997-1999)
15
08-13-2001 12:48 AM
Quick Reply: 03 CL-s swap 93 civic AEM speedo.
