Notices
02 Mdx intake velocity stacks question
Old 02-22-2018, 08:08 PM
Registered Member
Liked 1 Time in 1 Post
I have read the 02 MDX longer velocity intake plenum stacks seem to be a mod that is sometimes added. Can I do this with my stock plenums or are they too long and I will lose airflow? I have polished my stock j32a2 upper manifold and wondered if this was a good mod.
toyotawild is offline
Old 02-23-2018, 11:06 AM
3.5 psi
gnuts's Avatar
Liked 761 Times in 615 Posts
yes pretty sure they bolt on. From what I remember they shift the power to give more torque down low. I think Brian6speed has done this. What mods do you have now? This would be one of the last things I would tackle as far as power mods.
gnuts is offline
Old 02-23-2018, 12:05 PM
Registered Member
I was purchasing a bunch of acura parts online for my timing belt change and valve adjustment, so I just ordered the stacks so I wont pay shipping again. Just want to make sure I'm not going backwards with the stacks.
My mods are on cl-s 6spd: UR crank pulley, pnp upper/lower intake manifolds, p2r intake mani spacer, 4 inch cai. Next mods will be manzo headers, cat delete, 72mm t-body. Any other recommendations?
The following users liked this post: toyotawild
justnspace (02-23-2018)
Old 02-23-2018, 12:30 PM
3.5 psi
gnuts's Avatar
definitely do headers next. After that you're pretty much bolted. Do some weight reduction or swap in a J35A3 engine
gnuts is offline
Old 02-24-2018, 11:20 AM
Lone Wolf
brian6speed's Avatar
Liked 486 Times in 391 Posts
I used to run mdx stacks before 3.7 IM, but I had P2R plenums. Not sure about running them with stock plenums, would need to dyno test to find out.
If you guys don't already know, P2R is selling big tube header now. It does not have bend to clear rear mount on 6 speed though. 6 speed would need to modify rear mount.
P2R is selling plenums again, but pricey. See if anyone still makes or sells plenum spacers.
I' recommend running lwfw over crank pulley.
brian6speed is offline
Old 02-24-2018, 03:04 PM
Registered Member
Adam Kovach's Avatar
Liked 15 Times in 13 Posts
Brian,
The big tube headers will clear if you run the auto rear mount bracket and rear motor mount. Sean from P2R confirmed that and is selling those 2 pieces for $160.
Adam Kovach is offline
The following users liked this post: Adam Kovach
zeta (02-24-2018)
Old 02-24-2018, 09:03 PM
Registered Member
Show me these headers.
Old 02-25-2018, 08:52 AM
Lone Wolf
Originally Posted by Adam Kovach View Post
Brian,
Yea I know, just didn't waste my time typing it.
Old 04-01-2018, 05:58 AM
Registered Member
Liked 10 Times in 10 Posts
Just did the mdx stacks
I have I/h/a oil exhaust work and plenum and throttle body spacers and I did stacks from the mdx today with the stock plenum and I noticed a power gain from a stop. Definitely does increase torque on stock plenums. P2r plenums next? Or the big tube headers r sick if they sell the auto mount and bracket too. Here's some pix even tho I forgot one of the mdx plenums themaelves. They stick out probly 2 inches where the cls just flares the runners.
Cleaning and painting the top plate. Had to grind parts for hood clearence from using a oem mdx plenum spacer.
Removal and high heat paint on the top plate
Our stock cls manifold funnels next to a spare mdx manifold i used for parts. (The mdx ones stick out a good 2 inches but not close to the end of the oem plenums.
Finished product
Jonathan Hill is offline
Old 04-01-2018, 10:34 AM
Registered Member
Liked 7 Times in 4 Posts
If you go to the thread supercharger build I posted a month or so ago I have all the pics of the headers!
A Bogey is offline
Old 10-02-2018, 05:29 PM
Registered Member
Liked 31 Times in 27 Posts
Hey guys. I'm also running the P2R headers. They're not bad, but I had to modify them quite a bit to fit my car. Here are some pictures for those interested.
Recently I had the collector pipe modified, looks like this now:
As far as gains are concerned, I installed the P2R headers together with a 2.5 inch Fujitsubo exhaust, that helped me shave a good second from my car's time accelerating from 0 to the 112 mph speed limiter. The collector pipe mod gave me maybe another 0.3-0.5 second, but it feels like much more than that. The car flies now, after sorting the collector pipe. I'm not too impressed wiith the dyno number - my car recently put down 250 wheel (my mods include a 3-inch intake, 70 mm TB, J37A1 intake manifold, P2R headers with custom downpipe, Fujitsubo exhaust). I did dyno it on Russian gasoline, maybe that was the problem. It's not as good as what you guys get in the States for sure.
InspireJ32A is offline
Old 10-02-2018, 06:29 PM
Liked 5,791 Times in 4,643 Posts
Maybe now you can fix that oil leak
thoiboi is offline
Old 10-02-2018, 06:38 PM
Registered Member
That's residual oil left after my VTEC gasket let go. I replaced it, obviously. They don't live long for some reason. Maybe it's just my driving style (my engine spends more time in VTEC than it does idling). How do you say in America? Oh yeah, "I'm way ahead of you")
lifted tl
1G TL Performance Parts & Modifications
02-16-2013 05:07 PM
YetiTL
Fourth Generation TL (2009-2014)
06-03-2010 06:03 PM
RUF87
15
11-14-2009 11:11 AM
RUF87
Second Generation CL Discussion (2000-2003)
15
10-31-2009 01:55 AM
JJ4Short
Ramblings
11-20-2007 08:35 PM
Quick Reply: 02 Mdx intake velocity stacks question
