TL D-Town Love
#44
Tokin up in
Ok so now that we got a crew of TL's ready to cruise down 36 into Boulder after a lunch at BW's in Superior. Should we set up a date now or wait? I'm thinking Saturday March 27th you down with that? if so add your name to the list:
U Guys mind if a CL joins in? If so ill add my name
1. TailoredTL-S
1. TailoredTL-S
#52
Tokin up in
Only the real G's kik it in Aurora
#54
That turbo though.....
I could honestly care less when we have this cruise, as long as its in the spring and on a weekend I'm down, gotta get that fo sho
#68
Former Whiner
I'm only putting logical thought and no first hand experience or certainty here.
Lower number offsets = further out towards fender, ie +22 is ballin offset and your wheel lip will be flush with fender.
OEM offset is 45
Therefore +50 is definitely closer towards hub, which MAY lead to clearance issues with the front brembo calipers.
Here's a quick analysis, all offsets are lower than +45
http://www.tirerack.com/wheels/resul...ion&sort=Brand
OEM offset is 45
#70
True....hmmm I want them but money's tight lol
#74
B A N N E D
i'd say it cost her around $6,588 for those unnatural beauties
http://www.realself.com/Breast-implants/cost
and you were looking into that , cause either you have paid for a set before, or want a set yourself
first of all, are you manual or auto, so really the brembo brakes or not???
#75
As for the rims, if you have the TL-S with the Brembo BBK in the fronts, they must just barely clear. If you have a standard base TL, they will clear with no problems. Since your stock rims are a +45, theses C5 are only 5mm more in offset. Also, you have to take in consideration of the spoke design. Some spoke design have a little more clearance then others.
#78
B A N N E D
edit: so yes those wheels should fit, only thing to watch for would be the clearence on the inside, and if too little a couple of spacers will fix that
