Notices
AcuraZine Shave Club
Old 03-22-2013, 08:31 AM
  #121
Regional Coordinator
(Mid-Atlantic)
97BlackAckCL's Avatar
Liked 3,017 Times in 2,131 Posts
Down... there?
97BlackAckCL is offline
Old 03-22-2013, 08:57 AM
  #122
The Dumb One
Rockstar21's Avatar
Liked 371 Times in 248 Posts
its a real jungle.
Rockstar21 is offline
Old 03-22-2013, 09:05 AM
  #123
David_Dude
Acura_Dude's Avatar
Liked 579 Times in 513 Posts
Acura_Dude is offline
Old 03-22-2013, 09:48 AM
  #124
Registered Member
maharajamd's Avatar
Liked 1,540 Times in 1,194 Posts
Originally Posted by TeknoKing View Post
I've tried Astra blade yesterday. And the bleeding has commenced, lol. I can only imagine the Feather, geez.
Do you use any oil as a preshave? The A. Crew one I don't like, it's not slick enough.
I'm learning to get a better shave by finally paying attention to how my hair grows. I have so many directions, it's ridiculous.
I only use my oil if I'm not shaving in the shower. In the shower it's hot and wet enough that good soap works just fine.
However, if I'm going to a formal event and actually want to go against the grain. I'll put on oil in between my first pass with the grain and my second pass against. Or I'll use oil if I'm shaving at the sink.
I use Taylor's oil as well. (Just a Taylor of Old Bond St fan boy really)
http://www.tayloroldbondst.co.uk/aca...nd-creams.html
As for hair growing in different directions. Just shave those areas individually. My cheeks are all downward, downward under my goatee, the adams apple area the hair grows inward, and outside of that area the hair grows outward. Either remember that or soap up those areas one at a time.
maharajamd is offline
Old 03-22-2013, 09:56 AM
  #125
Registered Member
Liked 273 Times in 158 Posts
Thanks, I shave only at a sink...
If I try in the shower, I may look like this:
TeknoKing is offline
Old 03-22-2013, 10:16 AM
  #126
Registered Member
maharajamd's Avatar
Old 03-22-2013, 10:18 AM
  #127
(Mid-Atlantic)
Old 03-22-2013, 10:19 AM
  #128
Registered Member
ucf_bronco's Avatar
Liked 547 Times in 385 Posts
ucf_bronco is offline
Old 03-22-2013, 10:57 AM
  #129
David_Dude
Acura_Dude's Avatar
Old 03-22-2013, 02:20 PM
  #130
Registered Member
$17 bux for Two Taylor of Old Bond Street Shaving Cream Bowl (Sandalwood)
http://slickdeals.net/permadeal/9179...age=5#comments
Old 03-22-2013, 02:54 PM
  #131
KaMLuNg's Avatar
Liked 914 Times in 664 Posts
is their an advantage of using a DE vs an old school straight blade?
is it just speed by having both sides as opposed to just one?
KaMLuNg is offline
Old 03-22-2013, 02:57 PM
  #132
Unofficial Goat
The Dougler's Avatar
Liked 107 Times in 87 Posts
DE is easier to use, Straight razor will get you a closer shave be requires time and technique. DE while slightly different than your mach 12, only takes a couple shaves to get your technique down. Straight is the king daddy of the shave, followed by DE, then all the other junk.
The Dougler is offline
Old 03-22-2013, 03:08 PM
  #133
Registered Member
Straight and DE are about the same. Straight is unforgiving and can kill you. DE will hurt you and it will let you know that you iz stooooooopid.
Straight is the best for pros who have a steady hand and lots of time dedicated to prep work. Straight is manly! But my ER visits are not that well covered by my insurance.
Old 03-22-2013, 03:54 PM
  #134
Liked 2,182 Times in 1,296 Posts
I stopped even doing DE shaves because I lag in the morning and end up not having enough time. If you get a good enough electric, it's a bit pricey but you end up getting a surprisingly close shave and you never nick yourself.
But I want to get back into this... straights are badass.
Costco is offline
Old 03-22-2013, 04:16 PM
  #135
Needs more Lemon Pledge
stogie1020's Avatar
Liked 1,772 Times in 1,055 Posts
Took me about a full month of shaving to get it down to a no-blood scenario, and even now I occasionally nick myself. Usually gone by the time I get out of the shower, though.
stogie1020 is offline
Old 03-22-2013, 04:27 PM
  #136
Pre-Registered Member
Liked 246 Times in 150 Posts
After reading this thread, I am glad I use Gillette Sensor Excel, no prep work needed, 5 min or less and I am done with shaving.
odessa is offline
Old 03-22-2013, 04:42 PM
  #137
Most of us have been there, done that.
The prep work part of it becomes sort of a ritual and it's relaxing once you get the shaving part down. Eventually the post-shave irritation, bumps, ingrown hairs... they all go away.
I would never go back to a cartridge razor, not even if they made them dirt cheap.
Costco is offline
Old 03-22-2013, 04:58 PM
  #138
David_Dude
Acura_Dude's Avatar
Old 03-23-2013, 08:27 AM
  #139
all work and no play
MWalsh9152's Avatar
Liked 134 Times in 97 Posts
Originally Posted by CUNextTuesday View Post
This is my biggest problem! My neck beard grows every which way.. there seems to be no order at all down there. >_<
mine grows all different directions too, the only way I can get a close shave is to go with, then against the grain, then side in as well.
I have a friend that it looks like a weather model of a hurricane when his beard grows in, I wouldnt wanna have to deal with that shit!
MWalsh9152 is offline
Old 03-23-2013, 09:18 AM
  #140
David_Dude
Acura_Dude's Avatar
Old 03-23-2013, 12:50 PM
  #141
Registered Member
maharajamd's Avatar
Nothing beats a straight blade shave. And it's really not that hard to master. But having to maintain the blade sucks.
I've tried several electric razors. That method is just not for me.
And I agree with you guys, the ritual part of wet shaving becomes very enjoyable.
Old 03-25-2013, 08:27 AM
  #142
(Mid-Atlantic)
I shaved this morning
/thread
Old 03-25-2013, 08:31 AM
  #143
Registered Member
I shaved before bed, still smooth this morning
But I have some razor burns, I don't think proraso cream is for me, it's not slick enough. :/
Old 03-25-2013, 02:15 PM
  #144
stogie1020's Avatar
I reluctantly agree with you. Good stuff.
Old 03-25-2013, 03:50 PM
  #145
MWalsh9152's Avatar
glad to see you listened when I suggested it to you before.
I just ordered a Merkur Barber Pole and Feather blades yesterday, lets see if I can hurt myself
  #146
Registered Member
maharajamd's Avatar
Woohoo!
Need to contact Merkur and start getting a cut.
Old 03-25-2013, 03:51 PM
  #147
MWalsh9152's Avatar
Old 03-25-2013, 05:34 PM
  #148
stogie1020's Avatar
I find a lot of the slickness has to do with how much water you can get it to retain on your face. I typically lather, go with the grain, lather, go against the grain, then lather again and go across the grain. Each time I lather, I make sure there is a good bit of water on my face. It makes a big difference for me in keeping razor bumps down.
Old 03-25-2013, 06:33 PM
  #149
David_Dude
Acura_Dude's Avatar
Originally Posted by Maharajamd View Post
Woohoo!
Old 03-26-2013, 07:19 AM
  #150
Infiniti FX
1StGenCL's Avatar
Liked 568 Times in 418 Posts
Wow, Jefford, that is a lot of passes. I'm always afraid of bumps when I go against the grain.
I have to shave everyday but just go cartridge for the ease but need to read through this thread and move on to DE I guess.
1StGenCL is offline
Old 03-26-2013, 08:16 AM
  #151
Registered Member
I'm still experimenting. I found this morning my shave was very smooth, I've used Aveeno sensitive skin shaving cream, and with new Astra blade it was nice and smooth, I also dialed down the Futur to 2nd settings, I didnt get a close shave as I usually do, but I have no burns or cuts. Once I'll find the blades I like, it will be nice. My neck takes all of the beating :/
I do three passes, with the grain, across and then against.
Old 03-26-2013, 08:24 AM
  #152
Registered Member
I shave daily, advantage with DE if you shave at night and do a nice relaxing close shave, you won't have to shave in the morning. The difference is night and day with DE so far, it's time consuming, but I think the results will pay off. I'm a noob, but so far so good.
PS Spoke to a few Art of Shaving barbers while I was smelling and trying everything, they recommended me the Futur or any adjustable vs anything else, as you can truly adjust the aggressiveness. My cheeks can take anything, which I can easily shave on any settings/razor, my neck however, 2-2.5 is the most my neck can withstand without nicks.
Merkur 180 or HD, start with a setting around 3-3.5, which is aggressive for noobs, this is why most butcher themselves (and why Merkur blades are recommended, these things are very dull)
Old 03-26-2013, 08:34 AM
  #153
David_Dude
Acura_Dude's Avatar
I'm learning so much
Old 03-26-2013, 08:42 AM
  #154
Registered Member
maharajamd's Avatar
I'm glad you like your Futur. I liked the shave but found it hard to do trim work with the massive head it has.
Remember too, the Futur is the most expensive DE AoS sells I do believe. Lol.
Old 03-26-2013, 08:59 AM
  #155
Registered Member
Everything they sell is overpriced . I didn't buy anything from them, all from Amazon with lots and lots of reading. I like the heavy feel to Futur. I use my fusion for precise trimming, the single blade on the back.
Old 03-26-2013, 11:41 AM
  #156
KaMLuNg's Avatar
i am such a noob... maybe when im on vacation, i can practice with a straight blade..
KaMLuNg is offline
Old 03-26-2013, 12:31 PM
  #157
Unofficial Goat
I just ordered a travel pouch for mine so I don't have to worry about slicing my hand open trying to retrieve it out of my toiletries bag. Has anyone had issues travelling with a DE razor? Seems like something the TSA would ban.
Old 03-26-2013, 01:40 PM
  #158
Registered Member
maharajamd's Avatar
^I'm not sure it would fly carry-on but I've never had any problems with checked luggage...
Old 03-26-2013, 02:02 PM
  #159
(Mid-Atlantic)
Renamed the thread for all you coin purse shavers out there
Old 03-26-2013, 02:04 PM
  #160
Unofficial Goat
I only fly carry-on. I guess worst case they make you throw out the blade, which is not a big deal.
Quick Reply: AcuraZine Shave Club
