YR RSX vs. 2011 BMW 335xi N55 w/ Mods
Getting it Done
335i usually run about 13.4.-13.5 at give or take a bit 104mph, so that 335xi needed driver mod FOR SURE.
I'm impressed and have told a lot my buddies to check our RSX as it's amazingly quick. Well done and great kill, I really really wanna run you, wish you were more local.
pretty impressive runs, as always.
My good friend has had a couple of RSX-S's and I will say from a roll they can do some damage with work and a tune for sure. This video doesn't surprise me too much because the runs were from a roll. They just are so rev-happy. the 1/4 mile comparison is tough because it's hard to get an RSX out of the hole where the 335 is AWD and making peak torque so low in the rpm band. Any time I've driven those cars even on the freeway just cruising - I never hit 6th because if I had to hit the gas, the car doesn't go anywhere. It really doesn't pick up till 4k.
always fun to watch these vids
Nice runs, Yonkers.
The car is still on a stock clutch/flywheel with the new cams/intake setup, so I am sure once I swap that out the car is going to feel and move a lot better b/c it will grab the next gear, not slip and the lighter flywheel will make the car rev faster, which is always good for an all motor car.
Here's a vid before I did the cams and new intake setup -
Car was still quick, but you can see he had me MPH wise, there was nothing I could do, lol.
But yeah, like you said, they need to be above 4-5K RPM to get moving. Powerband is whenever VTEC kicks in, till redline...rinse and repeat.
Basically my point is, I haven't seen many N55's over 400whp that easily. If I had to guess, my buddies car in this video was making 330-350whp at best. Then again it's a N55 w/ stock intake, stock intercooler, on 93 pump gas just running a Vishnu map, instead of being pro-tuned.
This vid I posted in Post #6 is wrong, it's against my other buddies N54 335i
This is a vid of my buddies N55 335xi when it was stock and before I did my cams/intake setup and any weight reduction mods -
InFaMouSLink
10-27-2015 06:52 PM
