Wideband gauge ??
I'm sure they're is a thread about this
But I'm gonna try and install a wideband/lamda gauge. I've never done any wiring or install like thiss...so if anyone can post a thread or their diy for me thanks👌 |
It's just a key on + ,a ground ,and install the sensor before the cat.
So would that be before each pre cat?
Or at my test pipe? |
Originally Posted by richardparker
(Post 15712814)
Wrong section to ask this in. You would get more responses if it was in the performance section. Ask Mods to move it
That depends if you have pre-cat deletes or not. On mine, I installed the bung and the sensor of the J-pipe, but I have free flowing pre-cat deletes. If you don't, you wanna install it before the pre-cat...hmmm...but I'm not sure where.
Originally Posted by Duronn
(Post 15725664)
I have no clue, I dunno if its the same size but you need the O2 sensors. Why do you need a wide band?
(Post 15728275)
Well according to the AEM wideband instructions, you're gonna have to mount it before the precat: "For accurate readings, the sensor must be mounted before catalytic converters and/or auxiliary air pumps." If you don't have pre-cat deletes, you may wanna ask a muffler shop if they can make a hole & weld close to the O2 sensor since thats the only reasonable place.
(Post 15728304)
