Quarter Mile Time Compilation
#561
All motor
#562
AZ Community Team
Received 7,770 Likes
I blew my previous best time out of the water...I went last night to New England Dragway Street night. Weather was perfect, 53 degrees...spare tire and all junk removed from the car...paddle shift mode, VSA off, NO brake torquing. First race of the night I managed to run a 14.28 at 98.4 mph! Throughout the night, I never ran slower than a 14.6. I must have did about 20 runs at least. Totally surprised the hell out of me. My automatic Type-S has over 120,000 miles on it and it runs like a dream! Even chirps into 2nd sometimes. Managed to take out a brand new (stock) WRX, a modded wagon WRX, brand new CTS, a 300C Hemi, neck and neck with late 80's cobra, neck and neck with an old Chevelle, beaten by a 12 second Evo, beaten by a Camry SE V6, destroyed a few Civics, beat a newer Golf R32, and lost to a modded newer WRX.
I think that is the best (basically) stock 5AT TL-S time posted.
I'll be in Concord in a week or two. We should race .... 14.2x v 14.3x.
But I'll be in some rental or another.
#563
All motor
Just wanted to 'update,' although I haven't been to the track again since last time. But I put the date/time/track into the DA calculator on dragtimes last night. The corrected run for my 14.00 @102 was 13.86 @103 Although I didn't actually run a 13, I will keep an asterisk next to that night.
And by the way, I tried launching on the street a few times last night with 4500-5K clutch slips. I will definitely be launching at the track like that next time out.
BostonSilverTypeS (06-12-2012)
#564
Finally made some runs at beech bend 1/4 mile. I ran my fastest time of 14.30@98.69. There was a modded 6mt 350z running identical time and et. Also had multiple 14.35's, once with 9.28 1/8 and other 99.34mph trap. I'm happy with the results but definitely have to make the trip again this fall when temps drop. Hopefully couple more mods as well.
Here's the slips. Plugged the info in drag times DA calculator and got 13.94@101.28.
The following 2 users liked this post by cdc86:
BostonSilverTypeS (07-17-2012),
Sonnick (07-25-2012)
#565
Under construction
#566
amazing times man....def do some mods...you dealing with a nice healthy motor....
#567
thanks guys. really impressed with the traps but was hoping for times closer to 6mt guys. feel pretty quick 1st-2 but 3rd tq falls off badly. taking way too long 3rd-finish. knowing that stock exhaust is really hurting
next visit will include the egr delete, underdrive pulley, rv6 exhaust and of course ditch these oem mxm4's
looking to break 14's with 2.1 60ft on a good night
#568
Under construction
#569
Received 2,599 Likes
Look at some dyno curves...going to redline might not be the best plan if the motor is struggling to add revs. My car is manually shifted at 6250 against a 7000 reline for the best times.
#570
^thats a big thing on a lot of turbo cars but I think ours need to be completely revved out...and on the autos especially, it would be horrible to hit 4th in the 1/4mile
#571
All motor
CDC considering it was hot, you did well. Once it cools off I'm sure you will trap 101+, especially with your new mods. That's without PCDs! That should be added to your list as well...
#572
Btw nice 335, once the juicebox installed, it's a completely different car!
just to clarify my current mods: aem v2, tb coolant delete, port n polished manifold+runners, port matched p2r tbs+gaskets and maxxbore tb, rv6 precat deletes+v3 jpipe bolted to stock dual tip exhaust.
#573
All motor
Despite the torque dropoff, you do NOT want to shift into 4th in the 1/4. You will run slower without a doubt. 4th gear for the 5AT is very long and because of this, you would fall out of VTEC and have essentially little grunt crossing the 1320. Ideally, when you cross the traps, you want to be crossing at the same RPM where your power peaks. For the auto, you may actually be crossing the traps in the area of your peak HP.
I didn't realize you had the PCDs as well. Either way, that's a great trap for the 5AT.
You're saying you get a ton of wheelspin at the line. How do you launch?
#574
I do short burnout avoiding puddle and stage very slowly. once staged I throw into N with foot on brake and do high rev until break pedal tension gives. Then SS mode, break torque rev to 2k rpm release with launch. I had some 2.25 60's with that method so sticking to that routine. I'm looking into xlr8 motor mounts as well
#575
2003 Accord Coupe V6
I will be running at Qualcomm tonight in San Diego! It is only an 1/8th mile track but still should be fun! If anyone else is interested let me know! I saw a Acura TL out there on august 24th so I hope he is there again so I can run him. 1st time running with all my mods and 1st time near sea level! Can't wait!
Sonnick (09-07-2012)
#576
All motor
Good luck bro! Tyler, get your ass over there!
SatinSilverAV6 (09-07-2012)
#577
Here is one of the seven passes I made! The challenger and I were actually the first two cars down that side of the track! They run a total of 4 lanes. Timeslips aren't available as the damn printers weren't working most of the time. I have no idea what I ran but I am assuming I am in the low-mid 9's as my traps in the 77-78+MPH range from what my speedo said when I crossed the finish line. The challenger whooped my ass haha! I will upload more vids soon!
The actual race starts at 1:00 min.
http://www.youtube.com/watch?v=bxO2j...ature=youtu.be
#578
All motor
They couldn't tell you what you ran!!? Wtf....can you call? Maybe they saved it in the computer by car #? That's so frustrating. Nice vid.
SatinSilverAV6 (09-09-2012)
#579
Turd Polisher
#584
Went to the track last night and got a bunch of runs in. My best run was a 14.679 @ 96.03 which was my best run ever in the TL. I was really excited about it because the first time I went to this track was last winter when it was 55 degrees out. At the time my only mod was the v3 rv6 jpipe and I couldn't get the car down there faster than 15.3. Now I am running 14.6 in 83 degree weather which is a huge improvement for me. I can't wait for another 55 degree day this winter to see if I can get a 14.3 and get a full second off my original time!
At the track I was racing my friend in his Jackson Racing Supercharged Cr-z. He was running 15.3 on most runs. He had the go-pro in his car so it nice to see the difference between 15.3 (where I was originally) and where I am now. The vids are unedited so feel free to skip through us BSing.
My car is 06 5AT with CAI, coolant bypass, outlaw IM thermal gasket, pnp runners, type s cats, and rv6 jpipe.
http://www.youtube.com/watch?v=mQNN9...ature=youtu.be
http://www.youtube.com/watch?v=2vE4o...ature=youtu.be
http://www.youtube.com/watch?v=-mDuD...ature=youtu.be
#585
All motor
Nice job dude! Huge improvement from last time. It's always nice to show improvement! Do you remember your trap speed/60' from the last time out?
3gstealth (09-22-2012)
#588
Test N Tune today.
Ran nine times. Decent MPH, shitty times. 8/9 I trapped 100-101, one time was just under 100 (like 99.80), best trap was 100.66. Times were 14.30's-14.50's, and all 60' times corresponded, as in 2.30's were 14.30 runs, 2.40's were 14.40's etc.
Traction was horrid, but whatever. I wish I hadn't swapped back to the stock wheels/BS Potenzas last week, because I'm pretty sure I could have hit 101-102 with the Forgestars/Contis. Have to wait till spring to see what those and the 3.7 manifold/TB swap are worth.
Highlights: Got killed by an SI with a S/C running 8psi, killed by a new Cobb tuned STI. RAPED by an 11.7/127 mph SRT-4. Lost to a Ford Lightning.
Beat an Integra and a Hemi Ram, LOL.
Closest race was a bolted 350Z, he out 60'd me by 3/10 and beat me by the same, but I was reeling him in very slowly after the 1/8. Also got out 60'd by a new Camaro RS with I/E. He beat me by a bit, but I was reeling him in pretty strongly after the 1/8. I had him by 3 mph at the finish. Then there was the ummm...Chevy HR SS, milk truck looking thing that was running 14.1's @ 98 on 2.00-2.10 sixty foot times. Again, I was reeling him in pretty well after the 1/8, but couldn't quite run him down.
I'll get some slips scanned or snap pics of them later. Fun day, all in, and hoping to kiss 102.00 next time out with the summer wheels and 3.7 swap!
#589
All motor
Not bad. Are you full interior? When you do the 3.7 intake manifold/TB swap I'd imagine you would see a 1.x MPH gain. With an untouched TB and manifold, I'd say gains should be around 10-12whp for the 6MT 3.2. With a bored TB and port matched manifold I'd say 12-15. If done at the same time as the runners I'd add 3-4 to that as well. Great mod.
.....Waits for Atlas to post his 'so far' () quickest bolt on/street tire J series.....very impressive. 60' is nuts.
#590
Yeah, full interior. Not into gutting the TL. Spare/tools removed, 1/4 tank and some decent weight loss from bolt-ons. Braille battery and 3.7 mani will knock off another 30 lbs.
What did Atlas run?
Honestly at this point, I don't even care that much about ET. I've got the Nitto DR's sitting around just waiting for a cheap pair of 17" wheels, but let's face it, no FWD Honda/Acura is ever going to be a remotely good stop light racer. Maybe once I do the manifold swap and then some cams, then I'll focus on ET more and look for some cheap/light (oxymoron) wheels.
What did Atlas run?
#591
Holy shit, just saw his sig!
"13.644@102.46 w/ 2.058 60'"
What did he do recently? Wasn't he like 14.0x @ 99-100 before?
And what's OEM curb weight on the 7G Accord Coupe 6-6?
You guys are reppin' hard!
#592
Don't bother with DRs. You'll remain stuck in the 2.0-2.1 range which is not better than what a decent driver should be able to manage on street tires.
#595
I managed consistent 2.15-2.20 60 foots with my 96 Maxima 5MT (open diff) launching at 4500-5000rpms on 7 y/o Goodyear RSAs 215/60R15 tires. When I first started racing the car, I was launching at 2500-3000rpms and getting too frisky with the clutch. It resulted in bog or excessive spin or a combo of both and very consistent 2.3-2.4 60 foots. What applied to that car applies to yours. Both have very similiar power to weight ratios. The Maxima was going 14.2-14.3s@100mph with 2.1 foots when it was sold. You TL should go 14.0-14.1@101mph with high 2.1/2.0 60 foots.
Sonnick (10-16-2012)
#596
All motor
In terms of PSI, what's a good place to start at on a street tire? I was thinking of starting at 28psi and airing down from there, but not going lower than 23-24psi. I plan on keeping the rears above 40.
#597
For the auto guys, I'd recommend airing up the fronts a bit to induce some spin in hopes of reducing bog.
#598
All motor
The following 4 users liked this post by Sonnick:
anx1300c (10-21-2012),
BEAR-AvHistory (10-23-2012),
BostonSilverTypeS (10-23-2012),
SatinSilverAV6 (10-23-2012)
#599
takin care of Business in
Received 4,732 Likes
sub'd
#600
Sonnick doing work at the track!
Dude, are you still on regular 215's or whatever for tires? That 3.7 intake/TB swap is no joke. You're into stock 335i/G37 sedan territory on a little 3.0.
You can't not do cams and tune at this point. You'll hit 12's with cams/tune/slicks.
Sonnick (10-21-2012)
