06 tl vs 350z
#41
IS350King (aka mazdaspeed3God, Manual Transmission, Gear Ratio)...I know who you are. But, I'm also nice.
You play nice, I be nice. And you won't get sent to orbit again. CAPISCE?!?!??
The following 2 users liked this post by Yumcha:
EvilVirus (04-17-2014),
paperboy42190 (04-16-2014)
#42
Generally speaking, the 1st gen is350 with TC off will rip any 3G TL 0-60. There were some tests that were getting into the upper 4 second range. They're geared deep. From higher speeds, it's a different story. The 2nd gen is350 is slower since it gained a couple hundred pounds with no change in power.
The following 2 users liked this post by anx1300c:
1black_seven (04-17-2014),
D's Up (04-17-2014)
#45
Sure, it might be geared and powered for 0-60 .. but considering it doesn't have a limited slip differential & only offered in auto makes it as boring as any other 4 door Lexus.
With equal drivers, I'd still put my money on the 6MT HR 350z.
I don't own MS3. It will be a close race, but the IS350 will still take the edge upto about 125 mph. From 125 up, the MS3 will have the slight advantage. You really shouldn't be going 150 mph races anyway as it's too dangerous.
anx1300c (04-17-2014)
#47
2nd gen IS350 is actually named "3IS". Yes they have increased curb weight and body size as well with a tad longer wheelbase. But the gearing in the 8-speed is quite good as it came directly from IS-F counterpart. 4th gear up are tighter than the previous gen. So this will make up some in the high speed rolling pulls. But I do not like the fact that the new gen IS350 is heavier. Weight always kills speed.
I am not interested in going to space. I like it down here on earth nice and warm.
Seriously speaking, I won't be far off competing against an Agera R from 0-60. This is true with a lot of cars. In light-to-light city blocks you will be better off with cars with shorter gears. Nissan GTR would be best.
#51
Even give them a 1 hour head start.
#52
Received 3,824 Likes
#54
Well, FWIW, he's "famous" here too.
#56
Lexus 2IS looks great. It's very elegant, sexy, and just beautiful. It has very tight cozy interior. It's more inviting. But the TL inside has too much space and a lot of headroom which I didn't like so much. The rear leg room is also too big. I like it shorter. The leather quality in the IS350 is amazing. You should consider getting one. If you use the paddle shifters wisely it can be a real treat. It feels almost as good as manual tranny.
#57
You want me to post pics of his cat's shaved puss?
justnspace (04-17-2014)
#58
All motor
And this.
#59
9 mpg.
I'm not saying IS350King/MS3God is entirely correct in everything he's saying but in all the time I've spent on Acurazine I've only seen one real kill story with an IS350 losing. It was some guy with a full bolt-on, 6MT MRP Type-S that was pretty quick at the time (pre-tuning for our cars). He barely managed to beat his brother's I/E IS350. I'm talking barely. IIRC, he would only start pulling him after 125mph. I'll see if I can find the thread.
#60
#61
Let's change his name to Krska... pussy banger
#62
driver for driver, stock vs stock, 350 DE or HR would piss all over a 07-08 TL. i own both so i have a bit experience.
#64
TL is a closer match to ES350
#67
#68
#71
No, it's reasonable to assume since it a much smaller car. The IS is RWD so it has added drivetrain weight. Remember too that Honda engineers are pretty experienced in producing a good driver's car. Well balanced in most respects.
#72
#74
It's almost more fair if a Lexus fanboi decided to match up the ES against the TL.
#75
ES350 is a mid to high 14's ride.. unless you're talking about roll racing, which is ghey. :gheylaugh:
#76
HOW SLOW IS THE FX50...?!?!?!??
#77
It's between an AM and Pagani
but all 3 are slower than the MS3, which is slower than the IS350 because of boost cut out on the lower gears.
and all 5 are faster than Agera R and LFA
#78
no way.. not even close.. we're talking buslengths.
#80
