04-08 3.2 TL kill stories
Hi,
So I have a 2005 Acura 3.2 TL - 6spd - Manual.
Cai, pcds, full cat back , UR pulley.
This week 2 races... 2 wins :
2005 350z manual co-worker : 3rd gear pull.... neck to neck then....... bang right b4 4th and im about 3+ cars ahead smash 4th and im long ahead.
Bmw m3 unsure the year : mid 2000's manual : 3rd gear pull, he pulls a bit but then I start to even it out and.... he cant keep up, I pull away 2+ cars smash 4th and I keep pulling.... he was like wtf do you have done to that TL ?
Ahaahahahahahaha
Ahaahahahahahaha
Yes, the driver does make a difference.
I have been racing in competition for about 9yrs now @ the local events and province/out province events.
But in rolling races driver skill is much less needed vs from a stop....
Another one today : 2012 f-150 pick up v8 5L ( I know its a pick-up lol ) 360hp / 380tq.
The following 2 users liked this post by hektik02:
BEAR-AvHistory (09-04-2013),
EvilVirus (12-03-2013)
9 mpg.
Nice kills OP.
Ehh, it's not too outrageous. I've seen a base model 6MT with bolt-ons similar to OP's take out two E46 M3's. One was a modded SMG (Exhaust only) and the other a modded 6MT (Intake only). The TL pulled about 2.5 cars on both each time. Very consistent pulls over the course of 4-runs. He gave props to the M3's for being much closer to stock than he was and still being so quick and they gave props to him for making a sleeper out of his TL. I was in my S2000 and all three cars left me at a standstill after 100mph.
Nice kills OP.
Nice kills OP.
i dont see how a 333hp car will lost against a car with 256 unless all those boltons give it almost 100 crank hp. they both weigh the same if the m3 is a coupe. when my m3 was practically stock i raped a tl type s that appeared to be heavily modified. im not saying its impossible, id just find it hard to believe.
Received 2,599 Likes
I have run some E-46 M3's & they were way more competitive than any TL I have run against including my own. My daughters stock 330ci 6MT was a good matchup for my '06 TL 6MT.
Not to say it can't happen but the M3 must have not been running well. The car is strong enough to make up any bad driver mod except for a poor too high gear choice.
F23A4 (12-19-2013)
an m3 would def beat at tl-s no doubt, however with the right driver i dont think the tl-s would lose by THAT much. you'd probably pull a couple cars but not like multiple bus lengths. I find that a lot of ppl just leave the TL in D, which actually hurts a lot in these races. First there's the delay in downshift when racing from a roll, and in manual mode you get a rev slightly higher than in D(big difference because the 5at has such long gearing, you would want to maximize the rpm in each gear)
A fully bolted Type-S 6MT should be able to fight well from a roll. Here's an early e46 M3 trapping 103 mph, which is certainly on the low side. I've trapped 102, so I'd say with Flashpro, I could stay fender to fender with this car:
But then there would probably be a half dozen stock e46 M3's that would easily pull me on me. I don't know if they suffer from VANOS problems if they're older and not properly maintained, but it's plausible. There are also some e39 M5's that don't seem to run quite like they should.
BEAR-AvHistory (12-09-2013)
9 mpg.
mlody
12-04-2019 02:11 PM
Pham Alvan
03-16-2016 09:17 AM
