problem no horn, cruise control, steering wheel controls
my horn, cruise control and steering wheel controls dont work after i got my tranny replaced...i dont wanna take it back to get it fixed because i dont want to be without a car so i wanna try and fix it myself..any suggestions why i have this problem
That seems like a good place to start. Its all the electrical signals running from the steering wheel. double check the connectors leading from the steering wheel (or better yet, from the firewall around the transmission.)
If I had to guess, I'd say that likely the steering column was disconnected from the rack to lower the subframe to do the trans R&R. If the column was allowed to turn freely while disconnected, it can easily damage the cable reel at the top of the column which contains the conductors for all the circuits mentioned. Does the airbag/SRS light stay on too?....as it's wiring runs through the cable reel as well.
The cable reel is at the top of the steering column. You have to remove the airbag, steering wheel, and column covers to replace it. It's a sealed unit with a flat ribbon cable coiled inside that allows the steering wheel to rotate and still have electrical contact with the column harness. You won't be able to "see" a problem with it.
Can I 100% tell you it's going to fix your issues sight unseen???...No.
im trying to figure out what caused all these issue with the tramny being replaced..i cant think of any scenarios...is there a way to check the controls on the steering wheel and horn without changing the reel
Charlespsu
09-02-2015 09:54 AM
