kk's build thread #2
iCrap (03-27-2015)
#362
ROTAREDOM
I bet some people would pay $150
opboarding (03-29-2015)
#363
TSX AMG Type //M i-VVT
^ i bet some tard on Cu2 Squad would pay like 500
xtcnrice (04-09-2015)
The following 2 users liked this post by kostantinos:
iSeeYouTwo (04-14-2015),
xtcnrice (04-13-2015)
#376
I like the 2nd or 4th wheel
Will match roof rack
#379
How wide ?
#381
Gotcha
I think more concave it is will depend on which design looks better imho
#383
Can't wait to see it either way
If you did go with 10 wide, wouldn't you have to do some good amount of fender work ?
#386
Yeah I saw your new wheels and look really sunken in or is it the angle ?
I really want the look puppet master has. I just can't decide between 19 or 18
#388
VTEC just kicked in, yo!
The rears are a tad sunk surprisingly, but mostly the angle I think. But not really. I might try 15mm spacers for shits and giggles since I have a pair, but it might overly poke at that point. I'm pretty content with how they look though.
2012wagon (04-20-2015)
#390
Look at puppet master
8.5 wide +30
I would do that
Where you ordering from ?
8.5 wide +30
I would do that
#391
+40 will be sunk for sure. +35 will be ok for fronts, but rears will still be sunk. Are any of your fenders rolled, and if not, do you plan to? IMO you won't ever achieve flush in the rears if you don't at least roll them. Fronts are fine since they're rolled from the factory.
#393
Roll rears and go 19x8.5 +30. Puppetmaster has no rubbing in the rear with his setup after a rear fender roll.
On 245/35/19, you will be more or less exactly the same in overall diameter (including tires) as Puppetmaster being on 245/40/18. If you want to achieve a look like his, 19x8.5 +30 on your 245/35/19 will be fine (obviously your wheels will look a bit larger, and tires will be a bit thinner... but the overall diameter will be almost exactly the same).
Puppetmaster:
18" = 457.2mm
245/40/18 = 98mm of sidewall
Overall diameter = 457.2mm + 2*98mm (you will need to include the tire side wall twice when doing overall diameter) = 653.2mm
Your setup:
19" = 482.6mm
245/35/19 = 85.75mm
Overall diameter = 482.6mm + 2*85.75mm = 654.1mm
1mm difference from Puppetmaster's setup in terms of overall diameter. If this is the look you're searching for, you'll be fine.
Puppetmaster:
18" = 457.2mm
Your setup:
19" = 482.6mm
245/35/19 = 85.75mm
xtcnrice (04-21-2015)
#395
However do note his ride height. If you plan to lower it more than he does, you may rub in the front. We can't really tell from his pics whether there's much poke up front on 18x8.5 +30, but I certainly have a bit of poke on 18x9 +30. My setup would theoretically have about 6-7mm more poke than his, but I haven't measured the exact amount of poke at my current ride height.
#396
Lol if they do sit perfectly then maybe you can give me a nice deal on those LHD bixenons ![Tomato](https://acurazine.com/forums/images/smilies/tomato.gif)
I really want them, but I spent too much this year already
. If you still have them by next year I might consider grabbing them off you. But obviously you don't wanna hold onto them for that long lol
#399
I need functional and doing like puppet master
Do the +30
If it doesn't work sell them to me![Smile](https://acurazine.com/forums/images/smilies/smile.gif)
Like you I hate his offset stuff
Like Dave 88 new wheels look great even with higher offset
Can you do +30 and no roll if you don't lower it enough ? Since you are at 19 and not 18 like puppet slammage might not be necessary ?
Not sure where in RI you live, but when we lived in downtown providence the roads were nasty
Do the +30
