K23a1 Build
Old Jan 26, 2015 | 02:00 PM
  #521
kraz3RdX's Avatar
sending the gasket to a place so they can make a flange and my boy is making me a custome steel manifold... and if you are looking for one we can work on the price for ya after we test and tune and you see results... i have a 60-1 garret turbo with tail wastegate and blowoff valve i'll be installing... doing the intercooler and piping this week and will be recieving flashpro friday... iv have the car for only a year, got bored of it being slow... iv had a full vibrant exhaust since day 1 lol.... shit is fun ass hell... i got the base model front wheel drive one... weight reduction
Old Jan 26, 2015 | 02:26 PM
  #522
kraz3RdX's Avatar
sidewinder by the way... now question... the turbo cams that you put in it... was it k20 or k24 turbo cams? i was thinking about putting some k20 stage 2 all motor cams to BEEF IT UP
Old Jan 26, 2015 | 02:29 PM
  #523
TheWrench116's Avatar
FLETCH
all motor cams will most likely have to much overlap. which will hurt power. talk to the guys at BC about cams. and start your own build thread with lots of pics.!.
Old Jan 26, 2015 | 08:35 PM
  #524
duncanjerry's Avatar
cams?
Do you have a part number for the cams you used? How are they holding up? Did you ever get the knock sensor issue worked out? Thanks....
Old Jan 27, 2015 | 12:52 AM
  #525
KenB350z's Avatar
They were K20a3 stage 2 turbo cams.
Old Jan 27, 2015 | 12:57 AM
  #526
KenB350z's Avatar
Part# BC0051
Old Jan 27, 2015 | 06:20 PM
  #527
kraz3RdX's Avatar
Spoke to skunk 2... They said we can use all motor cams, just going to have vtec engaged on the exhaust side which leades to shitty gas mileage... Ok so k20 cams do fit in there
Old Jan 27, 2015 | 06:21 PM
  #528
kraz3RdX's Avatar
Starting this weekend with front mount and piping with rrc intake manifold... And bov
Old Jan 27, 2015 | 08:09 PM
  #529
KenB350z's Avatar
Yeah, I was going to do Killer cams. But, my Stage 2 turbo BC cams were good enough for now. They caused the knock sensor to go wild though.
Old Jan 28, 2015 | 02:40 PM
  #530
kraz3RdX's Avatar
woooooorrrd... i didnt know this but when you remove the turbo manifold you can use a k20 turbo manifold... i might use the k24z3 cams, about the same lobes, but i think they are a little more aggresive. but going to so the k20 sidewinder with 60-1.... intercooler i might get creative with.. will post pictures up when im done
Old Jan 29, 2015 | 09:40 AM
  #531
KenB350z's Avatar
Well I didn't remove the turbo manifold. I only took off the turbo when I upgraded it. The manifold has coolant running through it. I'm sure the coolant lines can be bypassed. I'm not sure about the fitment of the k20 exhaust/turbo manifold matching up with k23 head. This hasn't been tested yet.
Size:  130.6 KBName:  DSC_0801_zpsazjxoguf.jpg
Size:  73.5 KBName:  DSC_0800_zpswoldgowb.jpg
Old Jan 29, 2015 | 04:09 PM
  #532
FLETCH
good luck.
Old Jan 29, 2015 | 08:25 PM
  #533
KenB350z's Avatar
In order for the RDX to run a front mount intercooler, there will be some serious cutting required. The underside isn't open like the Civic's and RSX's. I wish it were, because that would have been one of the first mods for the RDX in my opinion.
Old Jan 30, 2015 | 11:15 AM
  #534
kraz3RdX's Avatar
Im installing the intercooler piping and bov with flashpro today... Will post pictures
Old Jan 30, 2015 | 11:16 AM
  #535
kraz3RdX's Avatar
Grill is going back on also
Old Jan 30, 2015 | 11:26 AM
  #536
kraz3RdX's Avatar
there is plenty of room... vertical flow FTW!!! lol
Old Jan 30, 2015 | 11:42 AM
  #537
kraz3RdX's Avatar
question, about the coolant passage, does it flow internally thru the motor? cuz the lines i would just by pass them... not really going to pull my hair on it... i notice the gasket has ports for it i believe
Old Jan 30, 2015 | 11:44 AM
  #538
KenB350z's Avatar
The piping doesn't wrap around as smooth as it would if it were a RSX or Civic. And what do you plan on doing with the map sensor that is on the TMIC?
Old Jan 30, 2015 | 04:55 PM
  #539
rdxchris710's Avatar
RDX faN BoY
Man looks like a 20g would bolt right to the stock manifold.
Old Jan 30, 2015 | 05:17 PM
  #540
KenB350z's Avatar
You will need an adapter, because it is not a prefect square.
Old Jan 30, 2015 | 05:43 PM
  #541
KenB350z's Avatar
Ok, it looks like this was just put in that space. Also that grill will need serious trimming, hopefully your trans cooler will still get sufficient airflow, and if you plan to run the piping that way; yes, you will need to cut. Unless you plan on running 1-to-1 1/2 inch piping through the small space. I'm not just saying this for nothing, I've had my bumper off plenty of times and consider the FMIC a million times. But, with all the sensor surrounding the TMIC and the small spaces, it just wouldn't work effectively. But if you can figure it out, then kodos to you.
Old Jan 30, 2015 | 07:56 PM
  #542
jay0707's Avatar
if kraz3RdX really work it all out.. then he gonna be the first to ever make it happen Front intercooler . one word SEXY ! i am so looking forward for that end project
Old Jan 30, 2015 | 07:58 PM
  #543
jay0707's Avatar
hey ken have you thought of upgrading the inside turbo wheels ? or upgrading bigger? 15-18?
Old Jan 30, 2015 | 08:35 PM
  #544
protoRDX's Avatar
Well, technically its not the first FMIC setup for RDX.
Old Jan 30, 2015 | 09:28 PM
  #545
jay0707's Avatar
really? i thought it couldnt be done cause of all those stuff on the way or maybe its just not worth the money to do it
Old Jan 30, 2015 | 10:30 PM
  #546
KenB350z's Avatar
I'll have to do a vid, because most of you have for got what my mods are.
Old Jan 31, 2015 | 08:36 AM
  #547
KenB350z's Avatar
I currently have an upgraded turbo with 17t wheel from EverGreen turbo.
OEM vs EG
EG vs OEM
Old Jan 31, 2015 | 07:05 PM
  #548
jay0707's Avatar
OEM vs EG
EG vs OEM
hey ken thanks for reply back. may i ask how you pay for that ? and what i need to do if i want to have a upgrade like yours ? part number any other parts need upgrade to make it work ?
Old Jan 31, 2015 | 07:21 PM
  #549
protoRDX's Avatar
1)
- setup #1
тюнинг двигателя и не только он - International Acura Club
- setup #2
RDX 2010 обвес - International Acura Club
And there are more of them.
2) FMIC is adding a huuuuge lag.
3) FMIC is very expensive.
Old Jan 31, 2015 | 07:30 PM
  #550
KenB350z's Avatar
Charlie B.
Evergreen Turbo Co.
11177 Southeast 29th Avenue
Ocala, FL 34480
(352) 347-7837
Our turbo part number is:TD04HL-15TK31-VFT 49389-01031
All you do is contact them and let them know you are sending the turbo, pay through paypal, over the phone, etc.. He will provide the parts. Here is the first RDX turbo upgrade that EverGreen did (my turbo). GTX wheel, clipped exhaust side, rebuild.
Old Jan 31, 2015 | 08:20 PM
  #551
KenB350z's Avatar
1)
- setup #1
- setup #2
Yeah, those don't look friendly at all. Almost all custom and I'm sure lags like crazy, little turbo and long piping!
Old Jan 31, 2015 | 08:36 PM
  #552
protoRDX's Avatar
You need to rev up to 4,5k rpms to get on positive spool.
Old Jan 31, 2015 | 08:43 PM
  #553
jay0707's Avatar
thanks ken. can i know how long it take for them to finish the job ? like if i get the parts would i be able to get the upgrade done in one day ? because i need it for work . and how much psi are you running with those now ? my stock im hitting 14psi at the moment and maybe i need turbo upgrade after i got those 600cc injectors/boost gaude done this friday.
Old Jan 31, 2015 | 09:16 PM
  #554
KenB350z's Avatar
Geez...
Old Jan 31, 2015 | 09:24 PM
  #555
KenB350z's Avatar
I think it took 3-4 weeks. He may not work on it if you provide the parts. Because people in the pass bought cheap chinese parts and their turbos broke and blame him. But, it wasn't him it was their cheap parts, so he would have to order the parts, highly suggested. If you were going to do this, I would recommend buying an extra RDX turbo and send it to him.
Old Feb 1, 2015 | 07:15 AM
  #556
jay0707's Avatar
I wonder if 18t would work.
Old Feb 1, 2015 | 08:59 AM
  #557
KenB350z's Avatar
I don't think so, our turbo is weird. I have already tried to get that kind of wheel in; however, he didn't recommend it.
"Got the turbo in...thats a TD04 not seen with those end housings...crazy....been trying to find a billet comp wheel....not found one yet....I'll update you tomorrow....your bearings did have some wear on them...so good you got into it now....what is the time frame to have this back...could take a week waiting on billet comp when I find it."
"Hi Ken,
Ok there must be different versions of this turbo? Can you get the actual part number off his turbo...I am curious as to what his PN is vs. yours.... one thing I don't recall building that turbocharger and I am not in the city he describes..altho it is my cell number?? why he has that insted of my 800 is odd....anyways the 18T replacement wheel is same profile as his turbo by his post...and in billet...but it does not match yours...this is gotten interesting to know what the facts are and if there are really two different turbos...if there is two different turbos..his is a larger comp side which is what you want.
let me know
Charlie"
"So, what size wheel are you able to fit in the RDX turbo?, 17t would be the safest."
Old Feb 1, 2015 | 09:53 AM
  #558
KenB350z's Avatar
Old Feb 1, 2015 | 10:21 AM
  #559
KenB350z's Avatar
good luck.
I see.
Old Feb 1, 2015 | 10:43 AM
  #560
FLETCH
the dude from Europe / Russia still isn't making 300 WHP....
