NY/NJ New Jersey & New York
NY/NJ/PA/CT/MA/RI Chat Thread Part VII
Old 09-08-2010, 09:55 AM
  #5521
Chapter Leader (New England)
JMillerUA6's Avatar
Kev I'm down for this no matter what, even if it's just me and you that go, lol.
Old 09-08-2010, 09:59 AM
  #5522
'13 Hyundai Sonata
TLin401's Avatar
Originally Posted by Yumcha
Is that the sequel to Inception...?
The Camry failed because it needed a catalytic converter.
  #5523
'13 Hyundai Sonata
TLin401's Avatar
That's a true friend right there.
Old 09-08-2010, 10:04 AM
  #5524
JMillerUA6's Avatar
I'm all about some spirited driving on mountain roads whenever I get the chance.....
Old 09-08-2010, 10:25 AM
  #5525
Nismo TL yo!
6spdtl-s's Avatar
potentially in for cruise. radar detectors will be needed.
when is it again? i didnt consider it at first but now im thinking about it.
Old 09-08-2010, 10:30 AM
  #5526
JMillerUA6's Avatar
The 25th
Old 09-08-2010, 10:33 AM
  #5527
Nismo TL yo!
6spdtl-s's Avatar
as long as I'm free, I'll probably attend.
Old 09-08-2010, 10:35 AM
  #5528
Blazing GT's Avatar
dont even bother asking the ppl from NYC lmaoo if it is 2 hours away from carries lmao
Old 09-08-2010, 10:36 AM
  #5529
OOOOOH
GoldnKnight22's Avatar
Sept. 25th
CT ppl... say you leave Hartford/wherever at 8am, we'd be cruising by 10 at the latest, and you'd be home by 5pm, I reckon.
Hell, if it's 2 or 3 cars, I'm def in. Just means we'd be able to stay together better and attract less attention.
I don't want to make it difficult for those that really want to come either. It's tough to make it work, I researched the BEST scenic/driving roads in Mass/VT for weeks.... but you can only get so many of them to connect in with each other.
Unfortunately, most of them are up further in VT which isn't reasonable for any of us, lol.
Old 09-08-2010, 10:37 AM
  #5530
Sun1914's Avatar
hey guys...quick question...getting multi answers.
So my car has a wierd noise when riding coming from the front my mech says i need a wheel alignment...and i agree what I want to ask you guys is - Is a camber kit necessary? I honestly dont care for these tires they are about 75-80 % of the meat still there but there coming off for the winter so my main concern is the ride it self. Will a good wheel alignment end the sound and fix my ride or is it a MUST i get a camber kit (front and rear) in order to correct my issue?
Please advise asap...I would like to take the car today to get fixed.
Old 09-08-2010, 10:42 AM
  #5531
OOOOOH
^^ Front, definitely no. Rear, optional. I'm running -3.1* in the rear without a camber kit. Just make sure you get an alignment and the TOE is zero'd out. That's the important part.
But I'm not sure that will solve a noise..... waht kind of noise? Could be the wheel balance too.
  #5532
JMillerUA6's Avatar
Camber isn't going to create any noises or vibrations. The one adjustment you need to really worry about after you lower your car is the toe angle.
What kind of noise is it that you're hearing? Unless your toe is WAY out of whack and your tires are scalloped or have flat spots, I doubt the noise you're hearing has anything to do with your alignment.
EDIT....I'm at -3* in the rear and I have no issues.
Old 09-08-2010, 10:48 AM
  #5533
Sun1914's Avatar
its more of a vibrations...it may be the balance.
My tires are worn on the inside more...
I work close to about 5 Mavis's might take it there or if anyone knows a good place in Westchester County I'm open to suggestion.
Old 09-08-2010, 12:38 PM
  #5534
Nismo TL yo!
6spdtl-s's Avatar
could be your axles. i had/have a similar issue.
Old 09-08-2010, 12:46 PM
  #5535
JMillerUA6's Avatar
My axles are going to need to be replaced soon too. They click sometimes, and I have a minor vibration under load.
Old 09-08-2010, 12:47 PM
  #5536
Nismo TL yo!
6spdtl-s's Avatar
yep, mine do too on a cold start when turning. i still have my replacements just sitting around. Dan where are you??!?!??!
Old 09-08-2010, 12:53 PM
  #5537
OOOOOH
LOL, yeahhh...... So I used to have the clicking noises when turning at low speeds (esp. when cold). After reading up, seemed like a pretty common occurence, not necessarily meanign the cv-joints or axles were bad. Somehow, it just went away all of a sudden and haven't heard it for a long time....
I now have the drivetrain vibration under load, however. It's only in lower rpms. Hadn't narrowed it down to axles yet... I'd like to confirm with one of you that we have the same issue, haha. I've also thought about it having to do with being so low, that it screwed up the geometry a little too much with the axles/cv's.
I know it's not the clutch (thankfully)... because when i put it up to 5th/6th and step on it, it's still smooth and the revs slowly increase as they should with the car speed.
Old 09-08-2010, 01:24 PM
  #5538
JMillerUA6's Avatar
I think you pretty much hit the nail on the head right here.
Old 09-08-2010, 01:27 PM
  #5539
Sun1914's Avatar
yeah so i went to Mavis and after waiting for about 40 mins dude and I go for a test drive and he says its my wheel bearing. I was gonna have them do it but the price was insane. I'll do it myself...it'll take me a lil longer but way cheaper...or i'll get my mech friend to do it.
it'll cost me the part, some beer and pizza pie...cant beat that
Old 09-08-2010, 01:57 PM
  #5540
JMillerUA6's Avatar
Front wheel bearing? You won't be able to do it yourself unless you have a shop press. Those bearings have to be pressed into the hub.
Old 09-08-2010, 02:11 PM
  #5541
Sun1914's Avatar
Looks like its gonna be my Mech's job then. Thanks for the heads up JM
Old 09-08-2010, 02:12 PM
  #5542
Sun1914's Avatar
Is it just me or whenever you find out whats wrong with the car it starts to sound worst? LMAO
It was annoying before but now its driving me crazy
Old 09-08-2010, 02:15 PM
  #5543
JMillerUA6's Avatar
In my experience I've never had a wheel bearing cause a vibration though. Typically they make kind of a rumbling noise that gets faster as you increase speed. But never a vibration.
Old 09-08-2010, 02:38 PM
  #5544
Sun1914's Avatar
Besides the sound is there anyother way to diagnois my problem before i purchase a bearing?
the sound is sort of a helicopper sound...and it gets faster as I excelerate.
Old 09-08-2010, 03:33 PM
  #5545
Registered Member
DaChef320's Avatar
Bring it to a shop and get it checked out
Old 09-08-2010, 04:18 PM
  #5546
JMillerUA6's Avatar
Yup, wheel bearing.
Old 09-08-2010, 04:24 PM
  #5547
Sun1914's Avatar
thanks JM...I'm a get it fixed tonight. Not like you guys really care but i'll let you know how it went anyway. lol
Old 09-08-2010, 05:20 PM
  #5548
JMillerUA6's Avatar
Just an FYI....part should be about $50, labor should be about an hour, maybe a tad more.
Old 09-09-2010, 08:09 AM
  #5549
Nismo TL yo!
6spdtl-s's Avatar
axles confirmed. I have the same issue. the axles are just at an awkward angle with the drop. When I raised up the front end of the car, the vibrations were alleviated a bit. A drop will also wear out the cv joints prematurely, leading to the clicking. Seems to only be when they are cold though. I remember mine clicked when it was cold out before i was dropped.
Old 09-09-2010, 09:24 AM
  #5550
KaMLuNg's Avatar
Received 1,090 Likes on 767 Posts
howdy y'all...
Old 09-09-2010, 09:55 AM
  #5551
OOOOOH
Cool.....
So Justin, Steve, keep me in the loop if either of you end up replacing axles or cv's. I wanna hear your experience.
*Excited for the Epic Cruise*
Old 09-09-2010, 09:57 AM
  #5552
Nismo TL yo!
6spdtl-s's Avatar
i have had the axles for a while now, havent gotten around to installing them since it doesnt bother me that much. It was a b*tch to find one of the sides. forgot which one. if you need one let me know, I'll try to get mine installed so you can have mine refurbed (unless you want to pay Acura's price).
Old 09-09-2010, 10:15 AM
  #5553
JMillerUA6's Avatar
My car has gotten lower I think.......maybe becasue my front struts are shot.......need coilovers soon.
My front lip is JUST above lighter height off the ground, so about 2.75". Shit is getting old....
Old 09-09-2010, 10:30 AM
  #5554
JMillerUA6's Avatar
Kevin did you send out invites yet?
Old 09-09-2010, 10:34 AM
  #5555
Nismo TL yo!
6spdtl-s's Avatar
buff cars this weekend?
Old 09-09-2010, 10:37 AM
  #5556
JMillerUA6's Avatar
Yeah, I'm free all day Sat. My car could use a good detailing, and I could stand to ingest some brewskis.
Old 09-09-2010, 10:38 AM
  #5557
'13 Hyundai Sonata
TLin401's Avatar
Old 09-09-2010, 10:42 AM
  #5558
JMillerUA6's Avatar
Whats up Mike
Old 09-09-2010, 10:50 AM
  #5559
'13 Hyundai Sonata
TLin401's Avatar
Not too much.
Living the single life...
Old 09-09-2010, 10:53 AM
  #5560
Nismo TL yo!
6spdtl-s's Avatar
I will be at the Uconn football game most of the day saturday, but if im back around and able to drive, I'll give you a call. sunday is free though.
Quick Reply: NY/NJ/PA/CT/MA/RI Chat Thread Part VII
