NY/NJ New Jersey & New York
Honda/Acura Mechanic in North NJ
Old 03-26-2013, 09:59 PM
acrdr's Avatar
Hi everyone
my name is Paul and i have been working for Honda and Acura as a mechanic for over 10 years
I am located in Clifton NJ
If anyone here needs any work done to their Honda/Acura .
I will be more than happy to help you out
I have a nice size garage at home that i work out of
Anything from Maintenance to Upgrades.
And if i cant do the work i will try to point you in thr right direction.
acrdr is offline
The following 5 users liked this post by acrdr:
Danny Kaplan (08-06-2018), DeathMetal (07-21-2015), DMZ (09-30-2014), FuriousSam (07-31-2014), guugoo (08-01-2014)
Old 03-27-2013, 12:49 AM
PyroDave's Avatar
hi paul
PyroDave is offline
Old 03-31-2013, 09:18 AM
acrdr's Avatar
For a limited time only
Trans service $ 50
VTM-4 $ 50
Power Steering Flush $50
V6-Timing belt kit$ 450 (new timing belt ,water pump,drive belt,new coolant)
acrdr is offline
Old 04-03-2013, 02:37 PM
2000UA5's Avatar
would you do custom exhausts?
2000UA5 is offline
Old 04-04-2013, 10:48 AM
emeka206's Avatar
How much to change my clutch spring? Or maybe the entire clutch master and slave cylinder?
emeka206 is offline
Old 04-04-2013, 01:31 PM
4th Gear
drulove's Avatar
Thanks for making yourself available to the community. Do you have a fender roller?
drulove is offline
Old 04-06-2013, 12:43 PM
acrdr's Avatar
Smile
No i dont do any type of welding yet
So far i can offer dealer type of work at great prices
acrdr is offline
Old 04-07-2013, 07:59 AM
HeartTLs's Avatar
I know this isn't exactly dealer type work per say but would you be able to install coilovers with EDFC controller?
HeartTLs is offline
Old 05-05-2013, 08:09 PM
integrakiet's Avatar
How much for oil change?
integrakiet is offline
Old 05-13-2013, 11:09 AM
acrdr's Avatar
Hey everyone
I'm sorry i have not responded to any PM lately
I just had a new family member come into our lives ,Baby boy , so i have been busy with him and did not have any time to do anything else
Now its slowly getting easier so i will be able to do work in my garage
So if you guys are still interested
Let me know
Thank you
acrdr is offline
Old 05-18-2013, 03:51 PM
05 WDP 6MT
BoricuaTL's Avatar
would you be available to drive out somewhere to check out a car (for a fee of course)
my mechanic said my valves are bent but i want a second opinion before i proceed with those repairs. its a half hr drive from clifton
BoricuaTL is offline
Old 06-06-2013, 08:52 AM
offaoffaoffa's Avatar
Met up with OP to do minor maintenance, great guy
offaoffaoffa is offline
The following 3 users liked this post by offaoffaoffa:
acrdr (06-19-2013), deematic (11-23-2013), DMZ (06-13-2015)
Old 06-06-2013, 05:53 PM
acrdr's Avatar
Thanks for the opportunity to help you out
Hope everything is good
acrdr is offline
Old 06-08-2013, 10:06 PM
Blaze9's Avatar
Do you do any body repair? Specifically front bumper? Needs to be buffed and repainted.
Blaze9 is offline
Old 06-14-2013, 06:53 PM
apinwp09GBTSX's Avatar
Super cool guy went in for a routine transmission drain and fill!! accommodated my busy schedule and didn't even get pissed off for me moving my appointment... will be going to him for any routine stuff for the car
Don't forget to pm about the rotors and camber kit!!
apinwp09GBTSX is offline
acrdr (06-19-2013)
Old 06-19-2013, 11:41 AM
acrdr's Avatar
Tirerack.com will have the best selection as far as i know
It all depends on your budget
acrdr is offline
Old 08-12-2013, 05:10 AM
4th Gear
Hamblaster's Avatar
I'm Paul Too! Who does the best buyable J32 builds in the country Bro? Looking for 350+ horses for the street, 2001 CLS. TNX Hamblaster
Hamblaster is offline
Old 08-12-2013, 11:10 AM
acrdr's Avatar
Hi when it comes to engine building ,i dont know anyone at this time
but if i come across anyone reliable i will let you know
acrdr is offline
Old 08-20-2013, 12:00 AM
Being an Acha Bacha in
Elegant TYPE S's Avatar
whats does your transmission service include?
Elegant TYPE S is offline
Old 08-21-2013, 10:03 AM
acrdr's Avatar
Hi
trans service
drain and fill service
drain old fluid and refill with up to 3 quarts of honda ATF DW-1 fluid
new drain bolt washer
$50
If you want to do the 3x3 fluid change its $100 plus your fluid
acrdr is offline
Old 09-22-2013, 10:43 AM
5th Gear
classico's Avatar
Paul is a great guy. He work on my Acura Legend.
classico is offline
The following 3 users liked this post by classico:
acrdr (10-08-2013), deematic (11-23-2013), DMZ (09-30-2014)
Old 10-08-2013, 10:43 AM
acrdr's Avatar
trans service is basically drain and fill your trans fluid with 3 quarts of acura dw-1 atf
acrdr is offline
Old 10-08-2013, 10:55 AM
acrdr's Avatar
So finally came time to work on my wifes 04 MDX
with 186k on the clock
i did the following
t-belt kit with new tensioner
new radiator (started to leak on the bottom ) with new rad hoses
new front engine mount
valve adjustment with new spark plugs ,new valve cover gaskets
coolant cross over pipe gaskets (wasnt leaking but i figured with the manifold off it was easy access
new thermostat
cleaned out the gear on my starter (it was making noise at start up)
put in aftermarket trans cooler to by pass the radiator cooler
cleaned out throttle body and intake manifold from carbon build up
restored headlights
will post pics
acrdr is offline
Old 10-08-2013, 11:33 AM
acrdr's Avatar
Headlight restoration
1.Before
2.during
3.After
acrdr is offline
Old 10-08-2013, 11:39 AM
acrdr's Avatar
some pics of engine maitnance
acrdr is offline
Old 10-23-2013, 11:40 AM
New Member
mkma05's Avatar
hi, looking for a mechanic for maintenance stuff for my wife's mdx. how much for an A1 service. i'm a couple towns over
mkma05 is offline
Old 10-25-2013, 08:58 AM
acrdr's Avatar
Pm sent
acrdr is offline
Old 11-23-2013, 04:48 PM
deematic's Avatar
Paul just completed the sooner than needed 105k maintenance for my 2003 Acura CL-S. (prepping for sale soon)
As well as headlight restoration/brake work/transmission fluid flush and other odds and ends he noticed and informed me about...and worked with me to take care of.
I highly recommend Paul and his work he sweats the details and does incredible work.
Some "clickable" pics below of my headlight restoration and motor maintenance.
deematic is offline
Old 11-23-2013, 04:57 PM
acrdr's Avatar
Thank you for giving me the opportunity to work on your car
acrdr is offline
Old 11-26-2013, 09:38 AM
初めまして
03uc1's Avatar
Congratulations on the baby boy
It's really great to have a Honda/Acura mechanic offering their services to us here
03uc1 is offline
The following 2 users liked this post by 03uc1:
acrdr (11-26-2013), DMZ (07-04-2015)
Old 12-08-2013, 09:34 PM
jerzey111's Avatar
Hey paul, Just sent pm about schedule/appt
jerzey111 is offline
Old 12-09-2013, 09:18 PM
3rd Gear
nykonite's Avatar
Hey Paul, I was planning on changing the DRL's, Fog lamps to HID and the Switchbacks to LED. I was wondering if you could do it and if so, let me know the damage. Thanks.
nykonite is offline
Old 12-10-2013, 08:39 PM
jerzey111's Avatar
Just met up w Paul, great guy, def going back when i need some more work done
The following 2 users liked this post by jerzey111:
acrdr (12-12-2013), DMZ (07-04-2015)
Old 12-24-2013, 11:13 AM
acrdr's Avatar
Merry christmas and happy New Year to all
acrdr is offline
Old 01-02-2014, 03:30 PM
8th Gear
commandoinaction's Avatar
Hey Paul, I sent you a PM. Happy New Year!
commandoinaction is offline
Old 01-06-2014, 12:24 AM
The Dark Knight's Avatar
hey paul
i got 78k on my 2009 acura tsx
i've just routinely changed the oil, oil filter, drain/filled the atf, new tires and new brakes so far while i've had the car.
i think i'm supposed to do a coolant drain too? i bought the fluid but haven't done it yet.
anything you recommend my car needs for maintenance?
The Dark Knight is offline
Old 01-06-2014, 03:13 PM
acrdr's Avatar
Originally Posted by The Dark Knight
hey paul
since you are doing the coolant drain and fill
replace the radiator hoses ,over time they dry out (just a precaution)get that out of the way at the same time
cabin filter been replaced ?
whats good about those cars is that they have minimal maintenance.
check your front lower control arm bushings (compliance bushings ) the tear over time
acrdr is offline
Old 01-07-2014, 09:42 AM
New Member
mif2112's Avatar
105k maintenance
Hi Paul,
I have a 2003 TL-S. How much do you charge for the 105k mile service (new timing belt, water pump, drive belt, etc.)?
mif2112 is offline
Old 01-07-2014, 11:05 AM
acrdr's Avatar
Originally Posted by mif2112
Hi Paul, I have a 2003 TL-S. How much do you charge for the 105k mile service (new timing belt, water pump, drive belt, etc.)?
Hi
For a timing belt ,water pump , drive belt , coolant $450
I also recommend replacing timing belt tensioner which is $100 extra parts only
Best would be for me to look the car over
acrdr is offline
ek26TL (07-18-2014)
Old 01-07-2014, 09:20 PM
stuck in traffic...
vester1986's Avatar
pm sent
vester1986 is offline
Quick Reply: Honda/Acura Mechanic in North NJ
