FS: Memphis PR1.1000
Memphis PR1.1000
I used this amp for 3 months and decided to go a different route (4ohm). It was a great amp and will put out rated power. It works perfectly, looks flawless (not a scratch, nic, dent on it) and will make you happy! I accept Paypal or any local sale, obviously. No trades please. If you would like any other pics, angles, anything in particular then just let me know. Thanks!! $220shipped UPS Ground
Specs:
RMS Pwr 4 Ohm: 300W
RMS Pwr 2 Ohm: 600W
RMS Pwr 1 Ohm: 1000W
THD(@ 4 Ohm): <0.1%
(@ 1 Ohm): <0.5%
Signal to Noise Ratio: >90db
Damping Factor: >180
Frequency Response ±0.5dB: 20hz-400hz
LPF Crossover Frequency:50hz-350hz
Bass Boost: 0-18db @ 45hz
Adjustable Sensitivity Range
Low Level: 200mV-6V
Input Impedance
Low Level:22k Ohms
Fuse: 30AMP x 4
Dimensions (W x H x D): 10" x 2.3" x 14.6"
Specs:
RMS Pwr 4 Ohm: 300W
RMS Pwr 2 Ohm: 600W
THD(@ 4 Ohm): <0.1%
(@ 1 Ohm): <0.5%
Low Level: 200mV-6V
Input Impedance
Low Level:22k Ohms
Fuse: 30AMP x 4
AndrewS
19
03-14-2024 06:59 PM
