Sup people - need TL purchase advice
I've decided to move on my from Saab to a TL Type-S and from my reading the timing belt is recommended at 105k miles. I have my eye on a nice one that has supposedly been serviced regularly at an Acura dealer, but they claim there's no such thing as a 105k mile service, so I'm looking for a source on that. My Google-fu has been weak thus far.
Thanks!
Thanks!
Latent car nut
Received 2,013 Likes
Thanks!
Thanks!
The above said, there is a "Maintenance Minder" system on the car which will call for a timing belt service automagically via a code displayed on the dash (I believe the code one typically sees is B4, although depending upon how things have been reset over time, I believe A4 is also possible), and that code typically pops 105,000 miles after the previous reset.
Long story short, Honda recommends the belt be replaced a minimum of every 105,000 miles, and if a Honda/Acura Service Department doesn't know that, time for a new dealer.
longbowfosho (01-12-2019)
Thanks for the clarification.
Is there anything else I should look at on these? They've already done the timing belt and tensioner, water pump, a/c compressor bolt recall, new battery and even had the dash and center console replaced. Any suspension trouble spots? Common electrical gremlins? I'm coming from a Saab, so I always expect something to be quirky lol
Latent car nut
If the car has an automatic transmission, it is often recommended by the collective here to have the ATF (Honda DW-1 only) replaced three times in quick succession (known as a 3x3 fluid change), and have the 3rd and 4th gear pressure switches changed as well. Beyond that, these cars are pretty robust; some members here have over 300,000 miles on the clock and the cars are still going strong.
Latent car nut
Not sure what you're asking.
ODUB
1G TSX Photograph Gallery
02-19-2006 12:03 AM
scoobywu
11-14-2003 11:05 PM
