MA + RV6 Jpipe
MA + RV6 Jpipe
Has anyone from Mass had trouble passing emissions/inspection with the RV-6 V3 Jpipe?
^you shouldnt.
there are no sensors on the 3rd cat.
which means you will not get a CEL.
which means when they hook up the OBDII scanner, it will pass.
visual inspection - the jpipe pretty much looks factory.
tail pipe sniffer- you still have the two primary cats in place right?
Ya this is my first performance mod. I should be fine but in MA you never know haha
Joneill44 (07-27-2012)
Former Sponsor
I have had my set up on for a couple of years now without any issue and I travel on route 3 (Bedford, MA/Nashua, NH local) all the time. My set up is ATLP J-pipe with RV-6 resonated test pipe plus ATLP base exhaust (non-resonated).
TimmieT
the PCD's will come with defouler attachment for the lower o2 sensors on the pre cats. it shouldnt pull up any codes, but the smell is pretty strong, i have xlr8 v2 j-pipe and rv6 pcd's. smell was soo bad i had a 200cell metallic cat convertor welded after the j-pipe. i suggust you spend a little more money and get the HFPCD's
I have had PCD's in Mass and pass inspection with no problem.....no CEL with defoulers installed.....Mass has no sniffer test so you should be good at any local gas station that does stickers!! ...they could be dicks and check your engine bay but that rarely happens....
08_UA7_Gr33k
02-11-2016 02:17 PM
SiClone
10-01-2015 10:22 PM
08_UA7_Gr33k
09-27-2015 01:56 PM
