Ferrari F2005 unveiled
[25/02/05 - 12:20]
http://f1.racing-live.com/en/headlin...25122353.shtml
Ferrari unveil the F2005
Characteristics and technical specifications
![](http://f1.racing-live.com/photos/imgactu/05/ferrari-launch-dr_250205_220x154.jpg)
Ferrari today unveiled its 2005 challenger the F2005 at the team’s base at Maranello. The F2005 is the 51st single-seater built by Ferrari specifically to compete in the Formula One World Championship.
The design, which bears the internal code number 656, represents Ferrari’s more exhaustive interpretation of the 2005 technical regulations. The main elements, relating to aerodynamics are more advanced than on the F2004 M.
The chassis is lighter, despite the need to strengthen the lateral anti-intrusion panels within the monocoque to increase its ability to meet the requirements of the crash-test, which is stricter than in the past. The shape has been revised, with modifications to the opening of the side pods and the area around the turning vanes. The side pods have been adapted to accommodate the new cooling system.
The engine cover has been redesigned, as have the aerodynamic devices on the side pods, with a secondary winglet introduced in the area of the roll-hoop. The layout of the exhausts is fundamentally different to that of the previous car, eliminating the aerodynamic profile which characterised the rear section, which is now almost entirely integrated within the bodywork.
While retaining the longitudinal architecture for the transmission, the entire rear end has been changed in an attempt to get the most out of the size of the gearbox, which is smaller than its predecessor and made from titanium and carbon fibre. Naturally, the limitations introduced by the new regulations were taken into account during the design stage.
The rear suspension has been revised, with the twin aims of improving the car’s dynamics in order to optimise the efficiency of operation for the Bridgestone tyres, while also improving the aerodynamic efficiency of the rear. The floor of the car has also been substantially redesigned to fit in with the new dimensions of the gearbox and comply with the new regulations. Two areas that benefited from a major effort during the design stage were the braking and electronics systems, this work carried out in conjunction with technical partners.
The 055 engine is load-bearing and mounted longitudinally. The internal components derive from the last version of the 053, currently fitted to the F2004 M. The main changes centre on the mounting points to chassis and gearbox. Its designers aimed to come up with an engine able to maintain a sufficient level of performance, doubling its life given that the sporting regulations introduced this year require the use of the same engine for two consecutive race weekends. As always, Shell’s help has been invaluable in the definition of fuel and lubricants to best meet the set targets.
The F2005 represents the final evolution in a line of Ferrari Formula 1 cars fitted with a ten cylinder engine. As usual, right from the design stage, much attention was paid to performance and optimisation of the materials used as well as quality control, in order to increase performance levels with maximum safety, all within the framework of the new rules introduced this year.
![](http://f1.racing-live.com/photos/imgactu/05/ferrari-launch-dr_250205_220x165.jpg)
Will this car take Schumacher to his eighth
World Championship?
Chassis
Carbon-fibre and honeycomb composite structure
Ferrari longitudinal gearbox limited-slip differential
Semiautomatic sequential electronically controlled gearbox
Number of gears 7 + reverse
Ventilated carbon-fibre disc brakes
Independent suspension, push-rod activated torsion springs front and rear
Length 4545 mm
Width 1796 mm
Height 959 mm
Wheelbase 3050 mm
Front track 1470 mm
Rear track 1405 mm
Weight with water, lubricant and driver 605 kg
Wheels (front and rear) 13”
Engine Type 055
Number of cylinders V10
Cylinder block in cast aluminium
Number of valves 40
Pneumatic distribution
Total displacement 2997 cm3
Magneti Marelli digital electronic injection
Magneti Marelli static electronic ignition
E.A.
Source Ferrari
World Championship?
Chassis
Length 4545 mm
Width 1796 mm
Height 959 mm
Wheelbase 3050 mm
Front track 1470 mm
Rear track 1405 mm
Engine Type 055
Number of valves 40
E.A.
Source Ferrari
_____ like a rabbit
i think the "will" goes after the "this car" and the ? should be a !, and the cars looks like the last one, and the one before that, and so on....
Registered AssHat
Originally Posted by Lung Fu Mo Shi
If you say so. I see very significant changes in the aero package.
Maybe he was just commenting on tha fact the car is red... I agree the F2004M and F2005 differ a great deal from the cars of the past, which all look very different to me. If the cars were painted one color it would be easier for the casual observer to notice.
Vandy
maharajamd
Console & Computer Gaming
09-24-2015 03:31 PM
