View Poll Results: Opinion on "Peak Oil" Theories...
I don't know, need to do more research
9.09%
High energy prices will self correct and we'll see fresh lows
18.18%
The era of cheap fossil fuels is over and we're staring at the abyss
57
64.77%
I don't give a fuzz, my next car will be a gas guzzling SUV
7.95%
Voters: 88. You may not vote on this poll
Your opinion on "Peak Oil" Theory
#242
Moderator Alumnus
Oil companies are moving quickly to tap shale oilfields in Texas that could increase domestic oil production by 25 percent over the next decade.
According to a report in the New York Times, more than a dozen companies will drill up to 3,000 wells in the next 12 months at Eagle Ford and other sites. Just five years ago the fields were thought to be worthless.
Despite concern about the environmental dangers of fracking, oil companies are betting the government won't stop such a big boost to reserves.
Texas shale is up to three times larger than Alaska's Prudhoe Bay, the last great onshore oil discovery in the U.S.
http://www.businessinsider.com/texas...le-ford-2011-5
#243
The sizzle in the Steak
Well with oil prices going well north of $100, fraking will start to make sense.....if prices drop.....fraking might not work out so much.
IIRC, conventional drilling is much cheaper than fraking.
So in the end, the consumer will pay about the same amount for oil products.
#244
Moderator Alumnus
#245
^^^ or the price of oil (inflation) will continue to rise....either way the price of gasoline will stay the same for the consumer....if not higher.
#246
I feel the need...
Get Ready for $150 Oil
.....The dynamics of both the first (2007-08) leg of the bull market and the second leg, likely to begin this year, are essentially the same. The thirst for oil by non-OECD nations puts pressure on supply, and the increase in output from non-OPEC producers is inadequate to quench this demand.
Since 2000 -- despite the post-9/11 economic downturn, the global stock-market swoon of the early 2000s, the 2008 financial crisis and the 2008-2009 Great Recession -- global oil consumption has advanced by a yearly average of 1.1 million barrels per day, while non-OPEC output has risen by a yearly average of less than 0.6 million per day. In 2000, non-OECD demand amounted to 37.7%, or a little over a third, of the world's consumption; now, it amounts to 48.5%, or nearly half.
The upswing in demand is adding urgency to concern about the availability, or lack thereof, of spare capacity, technically defined as crude that can be produced on a sustained basis within 30 to 45 days. Perhaps the most important thing to know about spare capacity is that only the OPEC producers have any. The non-OPEC gang is probably already pumping out all it can.....
#247
I feel the need...
There Will Be Oil, But At What Price?
By Chris Nelder and Gregor Macdonald
http://blogs.hbr.org/cs/2011/10/ther...wjLTyVC0.email
Daniel Yergin's typically sunny outlook on oil in his recent Wall Street Journal piece, "There Will Be Oil," suggested that technology and new energy discoveries would avert any of the economic disasters portended by peak oil. We found Mr. Yergin's dismissal of these risks premature and repetitive. After all, he has asserted since 2004 that global oil production was nothing to worry about, and that there would be few effects on the economy.
We counter that managers who would see their businesses survive the next few decades of extreme economic volatility will need to develop some literacy about oil and its complex relationships with the economy. They would be wise to consider the long list of peak oil analyses by the world's militaries, and they would take heed of the sobering outlook offered by veteran analyst Robert Hirsch for the Department of Energy. And we must correct some of Mr. Yergin's assertions.
Conventional crude ended its 150-year-long growth trajectory in 2004 and flattened out around 74 million barrels per day. Crude supply did not budge when oil prices tripled from 2004 to 2008, but global demand remained firm, shrugging off a recessionary dip in 2009. All the growth in supply since then was not crude but unconventional liquids, including natural gas liquids, biofuels, refinery gains, synthetic oil from tar sands, and other marginal resources. These liquids are by no means equivalent to crude. Yergin's calming charts include these unconventional liquids and hide the fundamental issue of the depletion of mature fields. They also hide the declining energy density, higher cost, and lower flow rates of these new resources.
As Shell, Chevron, Total, the IEA, and a host of other serious observers have openly declared since 2005, the age of cheap and easy oil has ended....
#248
I work for "Big Oil". It has been my career field during the last four decades. Here's a summary of my actions over the last ten years.
Planted fruit trees ALL OVER my suburban lot. Designed garden spaces as well.
Installed double-paned energy efficient windows in my FLORIDA home.
Installed new weatherstripping on all doorways and sealed all electrical outlets for loss.
Installed additional roof ventilation to cool attic during the hot summers.
Installed new blown glass insulation to achieve R-38 throughout the entire attic space.
Replaced ALL appliances with Energy Star models AND installed cutoff switches on all electronics to eliminate "vampire" loss.
Installed new two-stage heat pump, 20 SEER, and replaced all existing ducting with new efficient ducting. I had a specialist perform a blower test to ensure proper sealing of the new HVAC system. We are now at a 4% total loss, earning a 3 Star rating.
Turned conventional hot water heater to the minimum setting of 120 degrees. It will be replaced within the next few months with a hybrid system OR a solar system ... decision pending on type of technology to embrace.
Just purchased our first sedan (2012 TL) since the 90's ... we WERE buying SUVs like everyone else.
Oil companies sell on margin. IF it costs less, the gross profit per barrel is lower. IF it costs more, the gross profit per barrel is higher.
At this point, I have managed to move our four-bedroom all-electric home into an average utility expense of $150/month. We have two offices, his and hers, and a nice home theater ... we aren't doing without. Of course, it wasn't cheap to get to this point. My neighbors are all tossing $300-350/month into the utility coffers to enjoy the same creature comforts or less.
I am not going to try to predict the future, but I am playing the smart bet. In a way, this is no different than the theory behind Pascal's wager.
#249
I feel the need...
Saudi oil well dries up
If Citigroup is right, Saudi Arabia will cease to be an oil exporter by 2030, far sooner than previously thought.
A 150-page report by Heidy Rehman on the Saudi petrochemical industry should be sober reading for those who think that shale oil and gas have solved our global energy crunch.
I don't wish to knock shale. It is a Godsend and should be encouraged with utmost vigour and dispatch in Britain. But it is for now plugging holes in global supply rather than covering the future shortfall as the industrial revolutions of Asia mature.....
#250
More vindication.
09-17-2015 09:01 PM
