SOLD: VLEDs LED DRL Kit with Harness 9005 HB3 5K MT-G2 3000LM
For SaleLights
Price
$50
- Location San Diego, CA, 92103, USA
- Condition Used
- Compatibility
Make | Model | Year |
Acura | TL | 1999 - 2014 |
Description:
This kit should fit any car which uses the 9005/HB3 bulb in the DRL slot. I had these in my 3G TL. Took them out because they're too bright for me. They work and I tested it after uninstalling to make sure of it (as pictured). The harness and load resistors are included here as well: everything you'll need to install. The 25 Ohm resistor goes to the driver side connection and the 6 ohm goes to the passenger side. I labeled the connectors to make it easy to install. The setup is a few years old but the lights have little wear because I always used my low-beams instead of the DRLs during daytime driving. You can contact me via PM on the forum, email (hirnyjv@gmail.com) which is also my hangouts, or call/text (PM me and I will send you my cell number).
$50 shipped for the LEDs + harness. I'll cover paypal fees and shipping costs to the lower 48.
Thanks!
-Vlad
Edit - just saw your sig. If you plan to install these in your 07 then they'll pop into the DRL slot no problem. I had them in my 08 - same headlamp assembly.
