ReverendDanTPF |
12-22-2018 09:35 AM |
FS: 2003 Acura CL Type-S AT-5 192k miles
Alas, I'm getting rid of my beloved Blacura after 8 years of faithful service because I got a newer used car. My loss is your gain. As you can tell, I'm sentimental about her, so immaculately maintained. Everything works, nothing needs fixing. I have every single service record for the last 8 years.
All OEM except: - I've got upgraded EBC brakes (RedStuff pads & slotted rotors) and Continental tires on it. Fancy-schmancy!
- The Legend caliper upgrade
The long story... - The most comfortable bolstered, heated leather seats you'll ever sit in (with two different memory settings that remembers all your tiny seat and mirror adjustments for you and a friend)!
- Perfect balance between powerful/sporty and practical/comfortable. Great value.
- Bose audio.
- Electric sunroof.
- Electric everything.
- The right side mirror tilts down when you throw it in reverse, to make parallel parking easier -- thoughtful little feature!
- Automatic climate control -- just set the temperature you want.
- Honda's legendary 3.2-liter/260-horsepower/232-ft-lbs-torque SOHC VTEC V-6 J32A2 engine. That alphabet soup means it will run for another 191k miles with proper maintenance.
- 0-60 took just 6.4 seconds when it was new. It's happiest on the highway. You'll be getting 27-29 miles per gallon and humming along barely clearing 2k rpms at top highway speeds.
- Automatic 5-speed transmission, with a manual mode if you want to do your own shifting.
- Xenon headlights (the fancy-schmancy, super-bright, blueish kind)
- Vehicle stability assist, traction control, and ABS! (So, even though it's basically a heavy front-wheel drive muscle car, you can actually throw it into corners if you want and feel completely safe in the rain/snow/ice!)
- This is the last model year for the CL, so they made small changes and worked out all the kinks from the previous years. Acura doesn't even make a coupe anymore, so this is a rare find. Last of its kind.
- 192k (mostly highway) miles. I've driven it to Chicago and back a number of times, so that's why the mileage is so high. But, it's a Honda, so it'll run forever.
Message me! Looking forward to finding a good home for my Blacura!
