FS: 07-08 Type S Brembo Brake Direct Bolt On Conversion Kit for 2015-20 ACURA TLX
For SaleBrakes
Price
$1,200• OBO
- Location North Haven, CT, 06473, USA
- Condition New
- Compatibility
Make | Model | Year |
Acura | TLX | 2015 - 2020 |
Description:
Great upgrade for Sale I never installed, wife taking over car, I have 2023 Type S on Order. Kit on Sale on Ebay. All Brand New. $1200
07-08Type S Brembo Brake Direct Bolt On Conversion Kit for 2015-20 ACURA TLX | eBay
This is Acura OEM Brembo Big Brake Direct Bolt Kit for 2015-2020 Acura TLX.
This kit uses Acura parts from the 2007 - 2008 TL Type S. (Type S Caliper, Type S Rotor, and Type S Brake pads)
The kit includes parts from the 2020 TLX (Caliper Bolts-requires shorter bolts which the ones from 2020 TLX will work, Oil Bolt, and Oil Gaskets)
The caliper is machined to center to the rotor which is also from the. The rotor will fit on hub as it is the same 5 x 114 bolt pattern and has the same 64mm hub centric hole. The brake line from the 2020 TLX will work, new components included in kit for redundancy.
The kit also requires you to modify the brake dust shield for the caliper to be mounted.
The caliper will not clear stock wheels all sizes, spacer must be used.
Aftermarket Wheels might Clear others might not, depends on the wheel design and might require spacer
The minimum size of wheels the calipers will clear are 17 inches diameter. Typically lower offset wheels clear easier.
Every wheel design does play a big factor in clearing the calipers. The approximate clearance you need is 2 1/4 to 2 1/2 inches from the rotor to the wheel spokes.
