Keyless Entry Question.......
Old Oct 28, 2009 | 02:20 PM
kristopher's Avatar
Thumbs down Keyless Entry Question.......
Hey guys, i have an 02 RSX Prem. and i was wondering what my options are for a new keyless entry......I recently lost my car keys on a drunkin tangent and the dealership wants a whopping 250 dollars for a replacement....
This is after i already bought the RSX in 02 and a 07 RDX for my wife from the same dealership........
Can you buy used ones and have them re-programed or just go to a custom shop and get an aftermarket one......
Any advice is welcome......
Old Nov 2, 2009 | 11:53 AM
97BlackAckCL's Avatar
Regional Coordinator
(Mid-Atlantic)
Yep, just buy one off ebay, most of them come with programming instructions, if not you can find them around the net
Old Nov 15, 2009 | 12:40 PM
azngotmilk's Avatar
6th Gear
yeah try to get it anywhere (ebay, forums, oem sites)
if you're wondering how to program it, this is from the helms
just make sure you're inside the car with everything closed
Originally Posted by Helms
1. Turn the ignition switch ON (II).
2. Within 1 to 4 sec., push the transmitter lock or unlock button with the transmitter aimed at the receiver under the audio unit.
3. Within 1 to 4 sec., turn the ignition switch OFF.
4. Within 1 to 4 sec., turn the ignition switch ON (II).
5. Within 1 to 4 sec., push the transmitter lock or unlock button with the transmitter aimed at the receiver under the audio unit.
6. Within 1 to 4 sec., turn the ignition switch OFF.
7. Within 1 to 4 sec., turn the ignition switch ON (II).
8. Within 1 to 4 sec., push the transmitter lock or unlock button with the transmitter aimed at the receiver under the audio unit.
9. Within 1 to 4 sec., turn the ignition switch OFF.
10. Within 4 sec., turn the ignition switch ON (II).
11. Within 1 to 4 sec., push the transmitter lock or unlock button with the transmitter aimed at the receiver under the audio unit.
12. Confirm you can hear the sound of the door lock actuators. Within 1 to 4 sec., push the transmitter lock or unlock button again.
13. Within 10 sec., aim the remaining transmitters (up to two additional ones) whose codes you want to store at the receiver, and press the transmitter lock or unlock buttons. Confirm that you can hear the sound of the door lock actuators after each transmitter code is stored.
14. Turn the ignition switch OFF, and pull out the key.
15. Confirm proper operation of the transmitters.t
Old Nov 23, 2009 | 01:36 AM
Schrick99TL's Avatar
3rd Gear
viper
Does this same programming work with the Viper alarm system locking remote?
MrHeeltoe
20
Feb 23, 2023 01:54 PM
Jul 16, 2017 07:33 AM
MrHeeltoe
Sep 29, 2015 10:43 PM
MrHeeltoe
Sep 28, 2015 05:43 PM
