AcuraZine - Acura Enthusiast Community (https://acurazine.com/forums/)
-   Integra (https://acurazine.com/forums/integra-188/)
-   -   AC problem (https://acurazine.com/forums/integra-188/ac-problem-943549/)
Chiroboy314 03-26-2016 05:50 AM
AC problem
Not really sure what is it but my AC is blowing out warm air. I tried to recharge it but it didn't work. Compressor perhaps? I don't hear it kicking on.
knavekid 03-27-2016 08:50 PM
Find yourself a factory service manual and follow the troubleshooting steps. It could be a simple as a loose connector or a fuse or relay failure. Trying to recharge it with the compressor not running could cause additional problems. If it was a refrigerant problem that a recharge would fix, it would slowly get worse due to a slow leak. If it simply stops working, the cause is likely a severe system breach like a broken or damaged coolant line, a failed compressor, or an electrical or sensor problem.
