Remove third brake light housing?
9th Gear
I took my ILX in to have it tinted last week - left it sitting in the garage afterward while the tint cured. I just drove it again for the first time yesterday, and noticed that the housing for the third/high mount brake light seems to be sagging - it's no longer in contact with the rear window. It's a little annoying, as there's now light leakage down onto the back deck.
I figured just a clip was loose, or not fully seated, or something ... but I pushed and shoved the hell out of it, and nothing seems to be 'clicking home'. So I figured the next step is to pull the housing off and make sure all clips are still in tact, etc.
Has anyone attempted to remove the third brake light housing? Any tips or trick I should know about? I'm a little nervous that I'm just gonna snap the damn thing right off, LOL. Thanks in advance!
[Rush] (11-02-2017)
9th Gear
#20 is described as "Clip, Snap fitting"
#21 is descbribed as "Clip, door lining"
which narrows down your pulling efforts even more
https://www.acuraoemparts.com/auto-p...illight-1-scat
9th Gear
I've also been staring at this pic I found of a used third brake light to try to make sure I understand how it all fits together.
It looks like the housing is affixed to the interior roof by those two 'door lining clips', and also affixed to the third brake light by the two 'snap fitting clips'. And then the third brake light itself is affixed to the interior roof by a couple of screws. I'm wondering if I need to get a long flathead screwdriver to spring the two 'snap fitting clips' loose -- I think that should break the link between the housing and the third brake light, so then I can just yank on the two 'door lining clips' until the housing comes loose?
justnspace (11-02-2017)
9th Gear
Plastic trim tools are your best friends for things like this.
The following 2 users liked this post by thoiboi:
justnspace (11-02-2017),
[Rush] (11-02-2017)
That kit has been a lifesaver for me, well, money saver
9th Gear
Just giving an update ...
Turned out to be super easy. Pulled straight down on the part of the light cover that was by the headliner, and those two 'door lining' clips popped loose. Next step was to unscrew the two bolts that held the third brake light to the roof. Then unclipped the wiring harness -- the whole piece came right off after that.
Turns out the two little 'hooks' on my third brake light had slipped off the edge of the roof line, making the whole thing sag. Just rehooked 'em, rebolted, reclipped the wiring harness, and it's all good!
justnspace (11-03-2017)
