AcuraZine - Acura Enthusiast Community (https://acurazine.com/forums/)
-   ILX Problems & Fixes (https://acurazine.com/forums/ilx-problems-fixes-427/)
-   -   OBDII scanner codes question (https://acurazine.com/forums/ilx-problems-fixes-427/obdii-scanner-codes-question-985939/)
sportyluis Feb 19, 2020 09:58 PM
Hi,
I'm trying to do more work on my car myself so I bought an OBDII scanner and just ran it on the car. I received three error codes but I'm not sure what they mean or possible fixes.
Code 85-01 VSA Signal Failure. What does this mean and is there a fix? I googled this and didn't find anything on the topic that was useful
Code B1227 Ambient temperature Sensor Open and B2983 R/F Motor Lock Error: When I googled these codes they seem to be linked. It mentioned some loose connections or poor connections for the temperature control. Can someone help expand on this? I had just started the car in - 4 degrees Celsius so not sure if that affects the reading.
Thanks in advance all!
© 2026 MH Sub I, LLC dba Internet Brands
